Defining a server on another host [message #159193] |
Mon, 06 February 2006 13:55  |
When I try to define a new server, there is a text field for the host
name. However, if I type in anything other than localhost and scan for
server types, all I get is Apache and Geronimo 1.0. If I push on a bit
further, I get a list of Tomcat versions.
Where does WTP get this list of server types from? It's not the same list
as when host=localhost.
Is it even possible to define a server that is on a host different than
your development box?
Re: Defining a server on another host [message #159478 is a reply to message #159455] |
Tue, 07 February 2006 15:02   |
>> list as when host=localhost.
>> than your development box?
> I also am encountering this problem. There is a similar question posted
> in eclipse.newcomer, but there is no response there either.
> I would like to be able to either:
> 1) (preferred) Point at my Tomcat 5.5 instance on my development box.
> 2) or, work with the Sun App Server that already resides on my Windows
> PC (localhost)
> Is there now, or will there eventually be, a way to do either of these
> options?
Ok -- I found older threads that state that currently remote servers are
not supported. But there was a post (Oct 18, 2004 from Tim deBoer) that
said Servers on Mapped Network drives could be supported.
My remote Tomcat server is on a mapped drive, but I don't see how I can
set it up, because the New Server dialog wipes out the server type list
as soon as I enter a host name other than localhost.
Is there anything I can do to get Tomcat 5.5 to show up in the server
type list for my remote server?
Re: Defining a server on another host [message #159678 is a reply to message #159478] |
Wed, 08 February 2006 11:24   |
>> PC (localhost)
>> options?
If remote servers are not supported then the UI is flawed because it
implies you can define a server for any host.
You can work with Sun's AppServer on localhost:
https://glassfishplugins.dev.java.net/specifications/introdu ction.html
I was thinking of mapping the Appserver directory on my Sun with Samba to
my Windows box running Eclipse, but I wasn't sure if WTP only manipulated
files, or if it also tried to execute commands.
Re: Defining a server on another host [message #159897 is a reply to message #159678] |
Thu, 09 February 2006 11:44   |
>>>> host name. However, if I type in anything other than localhost and
>>>> scan for server types, all I get is Apache and Geronimo 1.0. If I
>>>> push on a bit further, I get a list of Tomcat versions.
>>> posted in eclipse.newcomer, but there is no response there either.
>>> Windows PC (localhost)
>>> these options?
>> are not supported. But there was a post (Oct 18, 2004 from Tim
>> deBoer) that said Servers on Mapped Network drives could be supported.
>> can set it up, because the New Server dialog wipes out the server type
>> list as soon as I enter a host name other than localhost.
> to my Windows box running Eclipse, but I wasn't sure if WTP only
> manipulated files, or if it also tried to execute commands.
Hey Eric,
Thanks for the glassfish link. That will be a big help.
FUDForum. Page generated in 0.04886 seconds
