Home » Eclipse Projects » GEF » Feedback from Model regading disallowed actions
Feedback from Model regading disallowed actions [message #159176] Tue, 23 November 2004 00:13 Go to next message
Originally posted by: ranjit.notMyId.com
My model container class checks if a child can be added to it.
Is there any way I can reflect that in the front end so that the child
part doesn't get added to the container part on the GEF canvas and
preferably pops up an error message (which will be sent by the model class).
I am guessing that I will have to override the addChild of the
AbstractEditPart corresponding to the container model class. I can then
check the validity of the child addition and accordingly just ignore
calling the super.addChild if the add is not allowed.
But I am still not sure how can I show the error feedback.
Any suggestions for me?
Re: Feedback from Model regading disallowed actions [message #159222 is a reply to message #159176] Tue, 23 November 2004 11:33 Go to previous messageGo to next message
You should prevent these interactions earlier. Return an unexecutable
command instead of the default create. The feedback will be the NOT cursor.
"Ranjit" <ranjit@notMyId.com> wrote in message
news:cnugsq$a7d$1@www.eclipse.org...
class).
> Thanks
Re: Feedback from Model regading disallowed actions [message #159254 is a reply to message #159222] Tue, 23 November 2004 13:11 Go to previous messageGo to next message
Hi Randy,
Thanks for the reply.
However, the only way I can check if a child can get added is during
runtime.
The container model would check for existing children and the new child to
be added and then decide if it can take in the new child.
Can you please give me some more detail about the unexecutable
command/default create that you mentioned?
Thanks.
"Randy Hudson" <none@us.ibm.com> wrote in message
news:cnvop3$p52$1@www.eclipse.org...
> cursor.
> class).
>> Thanks
Re: Feedback from Model regading disallowed actions [message #159270 is a reply to message #159254] Tue, 23 November 2004 14:11 Go to previous messageGo to next message
Originally posted by: Lamont_Gilbert.rigidsoftware.com
The EditPart (container in this case) typically has access to the model,
and can query it to find out if the child is acceptable during command
creation.
Ranjit wrote:
> Hi Randy,
> runtime.
> Thanks.
>>cursor.
>>class).
>>>Thanks
Respectfully,
CL Gilbert
"Verily, verily, I say unto you, He that entereth not by the door() into
the sheepfold{}, but climbeth up some other *way, the same is a thief
and a robber."
GnuPG Key Fingerprint:
82A6 8893 C2A1 F64E A9AD 19AE 55B2 4CD7 80D2 0A2D
For a free Java interface to Freechess.org see
http://www.rigidsoftware.com/Chess/chess.html
Re: Feedback from Model regading disallowed actions [message #159277 is a reply to message #159254] Tue, 23 November 2004 14:18 Go to previous messageGo to next message
In your create command, override canExecute and run the checks on the
container. A good model should support checking whether or not something
can be added without actually calling add() and catching some exception.
news:cnvufs$6hf$1@www.eclipse.org...
> Hi Randy,
> runtime.
> Thanks.
> > cursor.
> > class).
> >> Thanks
Re: Feedback from Model regading disallowed actions [message #159285 is a reply to message #159277] Tue, 23 November 2004 19:07 Go to previous messageGo to next message
Thanks for the precise answer.
Infact my container does have a method that will tell if it can accept a
child of a particular type I was just not sure where to call it.
Now I do :), thanks again.
>>Hi Randy,
>>runtime.
>>Thanks.
>>>cursor.
>>>class).
>>>>Thanks
Re: Feedback from Model regading disallowed actions [message #159293 is a reply to message #159270] Tue, 23 November 2004 19:08 Go to previous message
In fact that was precisely what I was think but was not sure where to do
the check. I get that I should do it in the command creation. thanks for
the pointer.
> creation.
> Ranjit wrote:
>> Hi Randy,
>> runtime.
>> child to be added and then decide if it can take in the new child.
>> Thanks.
>>> cursor.
>>> class).
>>>> Thanks
Previous Topic:gef plugin requirements
Next Topic:Embedding Texteditor into GEF?
Current Time: Sat Oct 25 03:52:10 EDT 2025
Powered by FUDForum. Page generated in 0.06595 seconds
