Home » Language IDEs » C / C++ IDE (CDT) » Build error with own toolchain
Build error with own toolchain [message #159123] Sun, 27 November 2005 12:22 Go to next message
Originally posted by: jan.potthast.name
I created my own toolchain as described in the "Managed Build System
Extensibility Document" under Chapter 6 "Example Tool Integration".
When I rebuild the project I get the following message:
**** Full rebuild of configuration Test Release for project Test1 ****
Nothing to build for project Test1
No makefile is generated in the project folder. I do not know where to look
for the error.
Thanks for your help
Greetings
Jan Potthast
Re: Build error with own toolchain [message #160830 is a reply to message #159123] Tue, 20 December 2005 22:21 Go to previous message
Originally posted by: crecoskie.ti.com
Chances are you are somehow generating an exception when the Managed Build
System attempts to generate the makefiles. Without seeing an error log of
some kind I can't speculate as to what the specific error would be.
Try debugging CDT and setting a Java Exception Breakpoint on
NullPointerException. See if that leads you anywhere.
- Chris
Jan Potthast wrote:
> for the error.
> Greetings
> Jan Potthast
Previous Topic:mixed C and C++ projects compile
Next Topic:Excluding Folders in a Managed Make C/C++ Project
Current Time: Thu Oct 30 04:04:44 EDT 2025
Powered by FUDForum. Page generated in 0.05403 seconds
