Publishing a Report [message #158949] |
Sun, 07 May 2006 19:40 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: p.freudenberg.btopenworld.com
I have created my test.rptdesign report against an Access database, it
previews well in the report designer. I want to publish it; the file is
copied to the Tomcat report directory within the BIRT webapp, I type the
URL http://localhost:8080/birt/test.rptdesign but all that is displayed is
the mark-up, the page isn't rendered (Tomcat has been started).
I validate the HTML at http://validator.w3.org/ and it tells me there are
16 errors, principally there's no DOCTYPE. I look into this and I find out
I need a PHD to sort this out at
http://blogs.sun.com/roller/page/vkraemer?entry=birt_and_gla ssfish.
Is it so difficult to publish a report? I don't want to and can't develop,
I just want to use the report designer application and publish the reports
I create.
Thanks for any assistance.
Paul
Re: Publishing a Report [message #159479 is a reply to message #158949] |
Tue, 09 May 2006 09:56 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Paul,
What driver are you using to access Access?
Make sure that this driver has been copied to the WebApp.
In 2.0.1 this should be
Web Viewer Example\plugins\org.eclipse.birt.report.data.oda.jdbc\driver s
In 2.1 this should be
WebViewerExample\WEB-INF\platform\plugins\org.eclipse.birt.r eport.data.oda.jdbc_2.1.0.N20060430-1302\drivers
Jason
"Paul" <p.freudenberg@btopenworld.com> wrote in message
news:7c161c4d81b954a5801b769308c89d54$1@www.eclipse.org...
> I create.
> Paul
FUDForum. Page generated in 0.03703 seconds
