Home » Modeling » GMF (Graphical Modeling Framework) » ConcurrentModificationException
ConcurrentModificationException [message #158801] Thu, 08 November 2007 04:54 Go to next message
Originally posted by: trommas.yahoo.com
I get a java.util.ConcurrentModificationException (when Loading a
Resource, and then setting a relation between a element in the current
editor - and one in the loaded resource.) Everything is seems to be
setup correct.
Does anyone know this error?
Tomas Zijdemans
Re: ConcurrentModificationException [message #158815 is a reply to message #158801] Thu, 08 November 2007 05:34 Go to previous messageGo to next message
Originally posted by: external.deyaa.adranale.de.bosch.com
This problem is related to the java.util package not GMF.
The most common occurance of this exception is when you are using a
java.util.iterator and at the same time try to modify the collection like
deleting an element. This happens because the iterator doesnot allow
modification on the collection while it is using it.
I hope this will be helpful
Re: ConcurrentModificationException [message #158847 is a reply to message #158815] Thu, 08 November 2007 06:20 Go to previous messageGo to next message
Thanks for helping!
Hmm.. strange. I've searched my code and the only iterators are those
who get generated (and I'm not using any of them). Could it be something
else?
Maybe this is because I use diagram partitioning?
Tomas Zijdemans
> like deleting an element. This happens because the iterator doesnot
> allow modification on the collection while it is using it.
Re: ConcurrentModificationException [message #158910 is a reply to message #158847] Thu, 08 November 2007 07:03 Go to previous messageGo to next message
I really don't understand. I get this error everywhere. Even with
completely non-customized code. This used to work :(
Any ideas at all is appreciated!
Tomas Zijdemans
Tomas Zijdemans wrote:
> Thanks for helping!
> else?
> Tomas Zijdemans
Re: ConcurrentModificationException [message #158954 is a reply to message #158910] Thu, 08 November 2007 08:09 Go to previous messageGo to next message
Tomas,
When you ask questions about an exception, it's generally a good idea to
show the full stack trace. With Java 5.0's new for-each loops, you
might be using and iterator without even knowing it. Many people assume
this concurrent modification exception is a threading issue when
generally it is not...
> Tomas Zijdemans
>> Thanks for helping!
>> something else?
>> Thanks,
>> Tomas Zijdemans
Re: ConcurrentModificationException [message #159023 is a reply to message #158954] Thu, 08 November 2007 09:57 Go to previous messageGo to next message
I have been unsuccessful so far in generating a stacktrace (when I run
it in the debugger, the resource is only set up "one-way" - so I can't
reproduce the error).
The two diagrams are loaded and the relation is set in one of them. When
I switch my view to the second editor - the error occurs. The first
editor crashes. When I try to open it I get this:
org.eclipse.core.runtime.CoreException: ERROR
org.eclipse.gmf.runtime.diagram.ui.resources.editor.parts.Di agramDocumentEditor.createPartControl(DiagramDocumentEditor. java:1458)
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed itorAreaHelper.java:263)
org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito rManager.java:1405)
org.eclipse.ui.internal.EditorManager$5.runWithException(Edi torManager.java:939)
org.eclipse.ui.internal.StartupThreading$StartupRunnable.run (StartupThreading.java:31)
I suspect it appears because of the diagram partitioning.
Any help is really appreciated :)
Best Regards,
Tomas Zijdemans
Ed Merks wrote:
> Tomas,
>> Thanks,
>> Tomas Zijdemans
>>> Thanks for helping!
>>> something else?
>>> Thanks,
>>> Tomas Zijdemans
Re: ConcurrentModificationException [message #159046 is a reply to message #159023] Thu, 08 November 2007 11:38 Go to previous messageGo to next message
Hello Tomas,
> entEditor.createPartControl(DiagramDocumentEditor.java:1458)
Looks like document provider was not able to load diagram. Can you please
check if the diagram file you are openning was not corrupted on prev. step?
(just open it with text or XML editor to see if the file looks like a valid
XML).
Alex Shatalin
Re: ConcurrentModificationException [message #159090 is a reply to message #159046] Thu, 08 November 2007 15:45 Go to previous messageGo to next message
Thanks for your time Alex.
> please check if the diagram file you are openning was not corrupted on
> prev. step?
I am quite sure it got corrupted. Attaching it below.
Two concerns arise:
1. "xmlns:notation="http://www.eclipse.org/gmf/runtime/1.0.1/notation"
Does this mean I have GMF 1 installed ???
2. I am using diagram partitioning (the referenced diagram - from this -
is a subdiagram). I got a feeling there may be a bug when one loads a
resource into a subdiagram. The reason for this is that these diagrams
work flawlessly in an EMF generated editor.
<notation:Diagram xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI"
xmlns:org.ueml.uemlbase="http:///org/ueml/uemlbase/uemlbase.ecore"
xmi:id="_Ct7doI4JEdyOuuMRtlsA_w" type="Uemlbase"
name="default12.editor_diagram" measurementUnit="Pixel">
<children xmi:type="notation:Node" xmi:id="_DJpJQI4JEdyOuuMRtlsA_w"
type="2003">
<children xmi:type="notation:Node" xmi:id="_DJpJQ44JEdyOuuMRtlsA_w"
type="5003"/>
<styles xmi:type="notation:ShapeStyle"
xmi:id="_DJpJQY4JEdyOuuMRtlsA_w"/>
<element xmi:type="org.ueml.uemlbase:ClassNode"
href="default15.editor#//@classes.0"/>
<layoutConstraint xmi:type="notation:Bounds"
xmi:id="_DJpJQo4JEdyOuuMRtlsA_w" x="559" y="59"/>
</children>
<styles xmi:type="notation:DiagramStyle"
xmi:id="_Ct7doY4JEdyOuuMRtlsA_w"/>
<element xmi:type="org.ueml.uemlbase:A_DiagramElement"
href="default15.editor#/"/>
</notation:Diagram>
Re: ConcurrentModificationException [message #159179 is a reply to message #159090] Fri, 09 November 2007 04:25 Go to previous messageGo to next message
I've reversed to not using diagram partitioning, but the problem still
occurs..
Running out of ideas.
Tomas Zijdemans
>> prev. step?
> Two concerns arise:
> type="2003">
> type="5003"/>
> </children>
> </notation:Diagram>
Re: ConcurrentModificationException [message #159196 is a reply to message #159179] Fri, 09 November 2007 05:44 Go to previous messageGo to next message
I've found some new triaging info.
The error only occurs on the first relation I set. All subsequent
relations are created without errors.
Could this mean that there is a collection which doesn't get initialized
properly?
(Both elements have an abstract superclass. It is their super classes
which have a relation to each other. Could this be the cause?)
Best Regards,
Tomas Zijdemans
> occurs..
> Tomas Zijdemans
>>> on prev. step?
>> Two concerns arise:
>> - is a subdiagram). I got a feeling there may be a bug when one loads
>> a resource into a subdiagram. The reason for this is that these
>> diagrams work flawlessly in an EMF generated editor.
>> <?xml version="1.0" encoding="UTF-8"?>
>> type="2003">
>> xmi:id="_DJpJQ44JEdyOuuMRtlsA_w" type="5003"/>
>> </children>
>> </notation:Diagram>
Re: ConcurrentModificationException [message #159260 is a reply to message #159090] Fri, 09 November 2007 08:16 Go to previous messageGo to next message
Hello Tomas,
No. Notation model was not changed in GMF for quite a long time..
Can oyu debug DocumentProvider call to see why corresponding information
can not be loaded from the diagram file? (The files you attached looks normal..)
Alex Shatalin
Re: ConcurrentModificationException [message #159276 is a reply to message #159260] Fri, 09 November 2007 08:47 Go to previous messageGo to next message
Thanks for helping Alex! (I got a deadline coming up, so I'm in a bit of
a hurry on this one)
I started the editor again to view where in the DocumentProvider I
should start, but then everything worked again !! - This bug truly has
me baffled! Now i can't reproduce the DocumentProvider error without
making completely new diagrams.
I tried debugging the relation with breakpoints, but everything seemed
normal. So it's a mystery where the Concurrent Exception originates from..
Tomas Zijdemans
> Hello Tomas,
> normal..)
> Alex Shatalin
Re: ConcurrentModificationException [message #159300 is a reply to message #159276] Fri, 09 November 2007 09:35 Go to previous messageGo to next message
Tomas,
You might not know about it, but in the breakpoints view you can set a
breakpoint that will stop when a particular exception is about to be
thrown. Look for the "J!" button...
> of a hurry on this one)
> from..
> Tomas Zijdemans
>> Hello Tomas,
>> information can not be loaded from the diagram file? (The files you
>> Alex Shatalin
Re: ConcurrentModificationException [message #159507 is a reply to message #159300] Sun, 11 November 2007 12:22 Go to previous messageGo to next message
Thanks for the tip, will check it out. After a week hammering at this
error, I've lost all faith in my ability to create multiple editors and
make them function together. I get this error, and Load Resources shows
nothing in "Browse workspace".
So thought I would ask you guys what needs to be done.
Here is what I do:
1. Single ecore and genmodel (with one root element for each editor)
2. Derive tooling, graph and map for each editor.
3. Derive a generator with these attributes set unique:
- File extensions
- Model ID
- Visual ID
- Plugin ID
- Editor ID
Any input is, as always, greatly appreciated :)
Best Regards,
Tomas Zijdemans
Ed Merks wrote:
> Tomas,
>> from..
>> Thanks,
>> Tomas Zijdemans
>>> Hello Tomas,
>>> Alex Shatalin
Re: ConcurrentModificationException [message #159515 is a reply to message #159507] Sun, 11 November 2007 13:01 Go to previous messageGo to next message
Hmm. It seems I have got things working. And I have a definitive source
of the error. Either I have misunderstood something, or there is a bug
in GMF.
As previously stated, everything works in EMF. This just occurs in GMF.
Scenario:
- A is super of B. B is super of C and D. (A and B should be abstract,
but this does not seem to effect anything)
- If root can contain A's, and an editor for C and another for D is
created - the error occurs.
- If root can contain C's and D's, and an editor for C and another for D
is created - the error does not occur.
Tomas Zijdemans
> Here is what I do:
> - File extensions
> - Model ID
> - Visual ID
> - Plugin ID
> - Editor ID
> Best Regards,
> Tomas Zijdemans
> Ed Merks wrote:
>> Tomas,
>>> has me baffled! Now i can't reproduce the DocumentProvider error
>>> without making completely new diagrams.
>>> seemed normal. So it's a mystery where the Concurrent Exception
>>> originates from..
>>> Thanks,
>>> Tomas Zijdemans
>>>> Hello Tomas,
>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159604 is a reply to message #159515] Mon, 12 November 2007 06:05 Go to previous messageGo to next message
Originally posted by: jan.herriger.gmx.de
If you have node mappings to supertypes (A and B), you should define
domain specialisations for them (new "constraint" inside the mapping).
The body should be:
oclIsTypeOf(A)
> in GMF.
> Scenario:
> Tomas Zijdemans
>> and make them function together. I get this error, and Load Resources
>> shows nothing in "Browse workspace".
>> Here is what I do:
>> - File extensions
>> - Model ID
>> - Visual ID
>> - Plugin ID
>> - Editor ID
>> Best Regards,
>> Tomas Zijdemans
>> Ed Merks wrote:
>>> Tomas,
>>> a breakpoint that will stop when a particular exception is about to
>>> be thrown. Look for the "J!" button...
>>>> bit of a hurry on this one)
>>>> originates from..
>>>> Thanks,
>>>> Tomas Zijdemans
>>>>> Hello Tomas,
>>>>>> 1.
>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159657 is a reply to message #159604] Mon, 12 November 2007 07:50 Go to previous messageGo to next message
Thanks for answering. I do not have nodemappings to supertypes.
I've done a reinstall of eclipse and gmf 2.0.1.
Created a root with two elements that relate to each other. Derive a
diagram for both. Run it, and still get the same error!!
> The body should be:
> oclIsTypeOf(A)
>> source of the error. Either I have misunderstood something, or there
>> is a bug in GMF.
>> GMF. Scenario:
>> D is created - the error does not occur.
>> Regards,
>> Tomas Zijdemans
>>> Here is what I do:
>>> - File extensions
>>> - Model ID
>>> - Visual ID
>>> - Plugin ID
>>> - Editor ID
>>> Best Regards,
>>> Tomas Zijdemans
>>> Ed Merks wrote:
>>>> Tomas,
>>>>> originates from..
>>>>> Thanks,
>>>>> Tomas Zijdemans
>>>>>> Hello Tomas,
>>>>>>> 1.
>>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159666 is a reply to message #159657] Mon, 12 November 2007 08:01 Go to previous messageGo to next message
Tomas,
I still haven't seen a full stack trace showing the error. You should
be able to get it from the Error log view. Have you been able to get
the debugger to stop at the point when the exception is thrown using an
exception breakpoint?
>> mapping). The body should be:
>> oclIsTypeOf(A)
>>> is a bug in GMF.
>>> GMF. Scenario:
>>> abstract, but this does not seem to effect anything)
>>> for D is created - the error does not occur.
>>> Regards,
>>> Tomas Zijdemans
>>>> this error, I've lost all faith in my ability to create multiple
>>>> editors and make them function together. I get this error, and Load
>>>> Resources shows nothing in "Browse workspace".
>>>> Here is what I do:
>>>> - File extensions
>>>> - Model ID
>>>> - Visual ID
>>>> - Plugin ID
>>>> - Editor ID
>>>> Best Regards,
>>>> Tomas Zijdemans
>>>> Ed Merks wrote:
>>>>> Tomas,
>>>>> set a breakpoint that will stop when a particular exception is
>>>>> about to be thrown. Look for the "J!" button...
>>>>>> I should start, but then everything worked again !! - This bug
>>>>>> truly has me baffled! Now i can't reproduce the DocumentProvider
>>>>>> error without making completely new diagrams.
>>>>>> originates from..
>>>>>> Thanks,
>>>>>> Tomas Zijdemans
>>>>>>> Hello Tomas,
>>>>>>>> 1.
>>>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159680 is a reply to message #159666] Mon, 12 November 2007 08:30 Go to previous messageGo to next message
Thanks for helping Ed. I found the breakpointtype you spoke of,
reproduced the error, and copied the Stack. So here it is:
Thread [main] (Suspended (exception ConcurrentModificationException))
BasicEList$EIterator<E1>.checkModCount() line: 1378
BasicEList$EIterator<E1>.doNext() line: 1326
BasicEList$EIterator<E1>.next() line: 1312
UemlbaseDocumentProvider.doSynchronize(Object, IProgressMonitor) line: 402
AbstractDocumentProvider$1SynchronizeOperation.execute(IProg ressMonitor)
line: 983
AbstractDocumentProvider$1SynchronizeOperation(AbstractDocum entProvider$DocumentProviderOperation).run(IProgressMonitor)
line: 66
UemlbaseDocumentProvider(AbstractDocumentProvider).executeOp eration(AbstractDocumentProvider$DocumentProviderOperation,
IProgressMonitor) line: 530
UemlbaseDocumentProvider(AbstractDocumentProvider).synchroni ze(Object)
line: 991
UemlbaseDiagramEditor(DiagramDocumentEditor).handleEditorInp utChanged()
line: 568
UemlbaseDiagramEditor(DiagramDocumentEditor).sanityCheckStat e(IEditorInput)
line: 692
UemlbaseDiagramEditor(DiagramDocumentEditor).safelySanityChe ckState(IEditorInput)
line: 674
DiagramDocumentEditor$ActivationListener.handleActivation() line: 1135
DiagramDocumentEditor$ActivationListener.partActivated(IWork benchPart)
line: 1094
PartListenerList$1.run() line: 72
SafeRunner.run(ISafeRunnable) line: 37
Platform.run(ISafeRunnable) line: 857
PartListenerList.fireEvent(SafeRunnable, IPartListener, IWorkbenchPart,
String) line: 57
PartListenerList.firePartActivated(IWorkbenchPart) line: 70
PartService.firePartActivated(IWorkbenchPartReference) line: 73
PartService.setActivePart(IWorkbenchPartReference) line: 171
WWinPartService.updateActivePart() line: 124
WWinPartService.access$0(WWinPartService) line: 115
WWinPartService$1.partDeactivated(IWorkbenchPartReference) line: 48
PartListenerList2$4.run() line: 113
PartListenerList2.fireEvent(SafeRunnable, IPartListener2,
IWorkbenchPartReference, String) line: 53
PartListenerList2.firePartDeactivated(IWorkbenchPartReferenc e) line: 111
PartService.firePartDeactivated(IWorkbenchPartReference) line: 116
PartService.setActivePart(IWorkbenchPartReference) line: 165
WorkbenchPagePartList.fireActivePartChanged(IWorkbenchPartRe ference,
IWorkbenchPartReference) line: 56
WorkbenchPagePartList(PartList).setActivePart(IWorkbenchPart Reference)
line: 126
WorkbenchPage.setActivePart(IWorkbenchPart) line: 3402
WorkbenchPage.requestActivation(IWorkbenchPart) line: 2946
EditorPane(PartPane).requestActivation() line: 265
EditorPane.requestActivation() line: 98
EditorPane(PartPane).setFocus() line: 311
EditorPane.setFocus() line: 127
EditorStack(PartStack).presentationSelectionChanged(IPresent ablePart)
line: 846
PartStack.access$1(PartStack, IPresentablePart) line: 829
PartStack$1.selectPart(IPresentablePart) line: 139
TabbedStackPresentation$1.handleEvent(TabFolderEvent) line: 131
DefaultTabFolder(AbstractTabFolder).fireEvent(TabFolderEvent ) line: 267
DefaultTabFolder(AbstractTabFolder).fireEvent(int, AbstractTabItem)
line: 276
DefaultTabFolder.access$1(DefaultTabFolder, int, AbstractTabItem) line: 1
DefaultTabFolder$2.handleEvent(Event) line: 84
EventTable.sendEvent(Event) line: 66
CTabFolder(Widget).sendEvent(Event) line: 938
CTabFolder(Widget).sendEvent(int, Event, boolean) line: 962
CTabFolder(Widget).sendEvent(int, Event) line: 947
CTabFolder(Widget).notifyListeners(int, Event) line: 706
CTabFolder.setSelection(int, boolean) line: 3227
CTabFolder.onMouse(Event) line: 2005
CTabFolder$1.handleEvent(Event) line: 316
Display.runDeferredEvents() line: 3682
Display.readAndDispatch() line: 3293
Workbench.runEventLoop(Window$IExceptionHandler, Display) line: 2389
Workbench.runUI() line: 2353
Workbench.access$4(Workbench) line: 2219
Workbench$4.run() line: 466
Realm.runWithDefault(Realm, Runnable) line: 289
Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 461
PlatformUI.createAndRunWorkbench(Display, WorkbenchAdvisor) line: 149
IDEApplication.start(IApplicationContext) line: 106
EclipseAppHandle.run(Object) line: 169
EclipseAppLauncher.runApplication(Object) line: 106
EclipseAppLauncher.start(Object) line: 76
EclipseStarter.run(Object) line: 363
EclipseStarter.run(String[], Runnable) line: 176
NativeMethodAccessorImpl.invoke0(Method, Object, Object[]) line: not
available [native method]
NativeMethodAccessorImpl.invoke(Object, Object[]) line: not available
DelegatingMethodAccessorImpl.invoke(Object, Object[]) line: not available
Method.invoke(Object, Object...) line: not available
Main.invokeFramework(String[], URL[]) line: 508
Main.basicRun(String[]) line: 447
Main.run(String[]) line: 1173
Main.main(String[]) line: 1148
Ed Merks wrote:
> Tomas,
>>> oclIsTypeOf(A)
>>>> is a bug in GMF.
>>>> GMF. Scenario:
>>>> Regards,
>>>> Tomas Zijdemans
>>>>> Here is what I do:
>>>>> - File extensions
>>>>> - Model ID
>>>>> - Visual ID
>>>>> - Plugin ID
>>>>> - Editor ID
>>>>> Best Regards,
>>>>> Tomas Zijdemans
>>>>> Ed Merks wrote:
>>>>>> Tomas,
>>>>>>> originates from..
>>>>>>> Thanks,
>>>>>>> Tomas Zijdemans
>>>>>>>> Hello Tomas,
>>>>>>>>> 1.
>>>>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159739 is a reply to message #159680] Mon, 12 November 2007 11:47 Go to previous messageGo to next message
Tomas,
So what does the code at "UemlbaseDocumentProvider.doSynchronize(Object,
IProgressMonitor) line: 402" look like?
> line: 402
> line: 983
> line: 66
> line: 991
> line: 568
> line: 692
> line: 674
> 1135
> line: 1094
> IWorkbenchPart, String) line: 57
> 48
> line: 111
> line: 126
> line: 846
> line: 267
> AbstractTabItem) line: 276
> line: 1
> 2389
> 461
> 149
> not available [native method]
> available
> available
> Ed Merks wrote:
>> Tomas,
>> should be able to get it from the Error log view. Have you been able
>> to get the debugger to stop at the point when the exception is thrown
>> using an exception breakpoint?
>>>> define domain specialisations for them (new "constraint" inside the
>>>> oclIsTypeOf(A)
>>>>> there is a bug in GMF.
>>>>> GMF. Scenario:
>>>>> is created - the error occurs.
>>>>> Regards,
>>>>> Tomas Zijdemans
>>>>>> Load Resources shows nothing in "Browse workspace".
>>>>>> Here is what I do:
>>>>>> - File extensions
>>>>>> - Model ID
>>>>>> - Visual ID
>>>>>> - Plugin ID
>>>>>> - Editor ID
>>>>>> Best Regards,
>>>>>> Tomas Zijdemans
>>>>>> Ed Merks wrote:
>>>>>>> Tomas,
>>>>>>>> a bit of a hurry on this one)
>>>>>>>> DocumentProvider I should start, but then everything worked
>>>>>>>> again !! - This bug truly has me baffled! Now i can't reproduce
>>>>>>>> the DocumentProvider error without making completely new diagrams.
>>>>>>>> originates from..
>>>>>>>> Thanks,
>>>>>>>> Tomas Zijdemans
>>>>>>>>> Hello Tomas,
>>>>>>>>>> 1.
>>>>>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159753 is a reply to message #159739] Mon, 12 November 2007 16:41 Go to previous messageGo to next message
Well, it is a generated method, so it would be kind of strange if the
error was there. But it suggest that the synchronization of the object
(called when I select the diagram) fails.
* @generated
protected void doSynchronize(Object element, IProgressMonitor monitor)
throws CoreException {
ResourceSetInfo info = getResourceSetInfo(element);
if (info != null) {
for (Iterator it =
info.getResourceSet().getResources().iterator();
it.hasNext();) {
402 Resource nextResource = (Resource) it.next();
handleElementChanged(info, nextResource, monitor);
return;
super.doSynchronize(element, monitor);
Ed Merks wrote:
> Tomas,
>> 402
>> line: 983
>> line: 66
>> line: 991
>> line: 568
>> line: 692
>> line: 674
>> 1135
>> line: 1094 PartListenerList$1.run() line: 72
>> 111 PartService.firePartDeactivated(IWorkbenchPartReference)
>> line: 116 PartService.setActivePart(IWorkbenchPartReference)
>> line: 165
>> line: 126 WorkbenchPage.setActivePart(IWorkbenchPart) line:
>> 3402 WorkbenchPage.requestActivation(IWorkbenchPart) line:
>> 2946 EditorPane(PartPane).requestActivation() line: 265
>> EditorPane(PartPane).setFocus() line: 311 EditorPane.setFocus()
>> line: 127
>> line: 846 PartStack.access$1(PartStack, IPresentablePart) line:
>> 829 PartStack$1.selectPart(IPresentablePart) line: 139
>> 267 DefaultTabFolder(AbstractTabFolder).fireEvent(int,
>> line: 1 DefaultTabFolder$2.handleEvent(Event) line: 84
>> Display.runDeferredEvents() line: 3682 Display.readAndDispatch()
>> line: 3293 Workbench.runEventLoop(Window$IExceptionHandler,
>> Display) line: 2389 Workbench.runUI() line: 2353
>> Workbench.access$4(Workbench) line: 2219 Workbench$4.run() line:
>> 466 Realm.runWithDefault(Realm, Runnable) line: 289
>> 149 IDEApplication.start(IApplicationContext) line: 106
>> available DelegatingMethodAccessorImpl.invoke(Object, Object[])
>> line: not available Method.invoke(Object, Object...) line: not
>> available Main.invokeFramework(String[], URL[]) line: 508
>> Main.basicRun(String[]) line: 447 Main.run(String[]) line:
>> 1173 Main.main(String[]) line: 1148
>> Ed Merks wrote:
>>> Tomas,
>>>>> oclIsTypeOf(A)
>>>>>> GMF. Scenario:
>>>>>> Regards,
>>>>>> Tomas Zijdemans
>>>>>>> Here is what I do:
>>>>>>> - File extensions
>>>>>>> - Model ID
>>>>>>> - Visual ID
>>>>>>> - Plugin ID
>>>>>>> - Editor ID
>>>>>>> Best Regards,
>>>>>>> Tomas Zijdemans
>>>>>>> Ed Merks wrote:
>>>>>>>> Tomas,
>>>>>>>>> originates from..
>>>>>>>>> Thanks,
>>>>>>>>> Tomas Zijdemans
>>>>>>>>>> Hello Tomas,
>>>>>>>>>>> 1.
>>>>>>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159756 is a reply to message #159753] Mon, 12 November 2007 16:48 Go to previous messageGo to next message
Tomas,
Since resources are often demand loaded into a resource set as proxies
are resolved, that's probably what's happening here. Maybe try changing
it to
for (Iterator it = new
ArrayList(info.getResourceSet().getResources()).iterator();
> * @generated
> if (info != null) {
> for (Iterator it =
> it.hasNext();) {
> return;
> Ed Merks wrote:
>> Tomas,
>> "UemlbaseDocumentProvider.doSynchronize(Object, IProgressMonitor)
>>> line: 402
>>> line: 983
>>> line: 66
>>> line: 991
>>> line: 568
>>> line: 692
>>> line: 674
>>> 1135
>>> 73 PartService.setActivePart(IWorkbenchPartReference) line:
>>> 171 WWinPartService.updateActivePart() line: 124
>>> 48 PartListenerList2$4.run() line: 113
>>> line: 165
>>> line: 829 PartStack$1.selectPart(IPresentablePart) line:
>>> 139 TabbedStackPresentation$1.handleEvent(TabFolderEvent)
>>> line: 131
>>> line: 466 Realm.runWithDefault(Realm, Runnable) line:
>>> 289 Workbench.createAndRunWorkbench(Display, WorkbenchAdvisor)
>>> line: 461 PlatformUI.createAndRunWorkbench(Display,
>>> Object[]) line: not available Method.invoke(Object, Object...)
>>> line: not available Main.invokeFramework(String[], URL[])
>>> line: 508 Main.basicRun(String[]) line: 447
>>> Main.run(String[]) line: 1173 Main.main(String[]) line: 1148
>>> Ed Merks wrote:
>>>> Tomas,
>>>> able to get the debugger to stop at the point when the exception is
>>>> thrown using an exception breakpoint?
>>>>> a diagram for both. Run it, and still get the same error!!
>>>>>> the mapping). The body should be:
>>>>>> oclIsTypeOf(A)
>>>>>>> in GMF. Scenario:
>>>>>>> another for D is created - the error does not occur.
>>>>>>> Regards,
>>>>>>> Tomas Zijdemans
>>>>>>>> at this error, I've lost all faith in my ability to create
>>>>>>>> multiple editors and make them function together. I get this
>>>>>>>> error, and Load Resources shows nothing in "Browse workspace".
>>>>>>>> Here is what I do:
>>>>>>>> editor)
>>>>>>>> - File extensions
>>>>>>>> - Model ID
>>>>>>>> - Visual ID
>>>>>>>> - Plugin ID
>>>>>>>> - Editor ID
>>>>>>>> Best Regards,
>>>>>>>> Tomas Zijdemans
>>>>>>>> Ed Merks wrote:
>>>>>>>>> Tomas,
>>>>>>>>> can set a breakpoint that will stop when a particular
>>>>>>>>> exception is about to be thrown. Look for the "J!" button...
>>>>>>>>>> in a bit of a hurry on this one)
>>>>>>>>>> reproduce the DocumentProvider error without making
>>>>>>>>>> everything seemed normal. So it's a mystery where the
>>>>>>>>>> Thanks,
>>>>>>>>>> Tomas Zijdemans
>>>>>>>>>>> Hello Tomas,
>>>>>>>>>>>> 1.
>>>>>>>>>>> time..
>>>>>>>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159840 is a reply to message #159756] Mon, 12 November 2007 17:39 Go to previous messageGo to next message
Hello Ed,
> changing it to
Should we adopt GMF generator to always use this pattern?
Alex Shatalin
Re: ConcurrentModificationException [message #159845 is a reply to message #159840] Mon, 12 November 2007 18:18 Go to previous messageGo to next message
--------------080800020203040502070200
Content-Type: text/plain; charset=UTF-8; format=flowed
Alex,
Making a copy of the list is a bit expensive. Depending on if you want
to visit the demand loaded resources or not, I'd suggest either
List<Resource> resources = resourceSet.getResources();
for (int i = 0; i < resources.size(); ++i)
or
for (int i = 0, size = resources.size(); i < size; ++i)
The former would visit even ones added during the traversal, while the
latter would visit only those known to be in the list at the start of
the traversal.
EcoreUtil's resolveAll is written this way because we want to resolve
proxies even in the demand loaded resources.
public static void resolveAll(ResourceSet resourceSet)
resolveAll(resources.get(i));
> Hello Ed,
>> changing it to
> Alex Shatalin
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Alex,<br>
<br>
to visit the demand loaded resources or not,  I'd suggest either<br>
<br>
   List&lt;Resource&gt; resources = resourceSet.getResources();<br>
    for (int i = 0; i &lt; resources.size(); ++i)<br>
<br>
or <br>
<br>
    for (int i = 0, size = resources.size(); i &lt; size; ++i)<br>
<br>
the traversal.  <br>
<br>
proxies even in the demand loaded resources.<br>
<blockquote><small>  public static void resolveAll(ResourceSet
resourceSet)</small><br>
<small>  {</small><br>
<small>    List&lt;Resource&gt; resources =
resourceSet.getResources();</small><br>
<small>    for (int i = 0; i &lt; resources.size(); ++i)</small><br>
<small>      resolveAll(resources.get(i));</small><br>
<small>    }</small><br>
</blockquote>
<br>
<blockquote cite="mid:3c3172e61a05c8c9f39c57a4b488@news.eclipse.org"
type="cite">Hello Ed,
<br>
<br>
<blockquote type="cite">Since resources are often demand loaded into
<br>
<br>
changing it to
<br>
<br>
<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
Alex Shatalin
<br>
<br>
<br>
</blockquote>
<br>
</body>
</html>
--------------080800020203040502070200--
Re: ConcurrentModificationException [message #159874 is a reply to message #159756] Tue, 13 November 2007 03:17 Go to previous messageGo to next message
My birthday is coming up, and I've had a hard time making a wish list
for family and friends.. This is probably the gift I'm going to
appreciate the most!
This removes the error from all my editors!
Thanks Ed!
Tomas Zijdemans
Ed Merks wrote:
> Tomas,
> it to
>> * @generated
>> if (info != null) {
>> for (Iterator it =
>> it.hasNext();) {
>> return;
>> Ed Merks wrote:
>>> Tomas,
>>>> line: 402
>>>> line: 983
>>>> line: 66
>>>> line: 991
>>>> line: 568
>>>> line: 692
>>>> line: 674
>>>> 1135
>>>> line: 165
>>>> line: 131
>>>> Ed Merks wrote:
>>>>> Tomas,
>>>>>>> oclIsTypeOf(A)
>>>>>>>> in GMF. Scenario:
>>>>>>>> Regards,
>>>>>>>> Tomas Zijdemans
>>>>>>>>> Here is what I do:
>>>>>>>>> editor)
>>>>>>>>> - File extensions
>>>>>>>>> - Model ID
>>>>>>>>> - Visual ID
>>>>>>>>> - Plugin ID
>>>>>>>>> - Editor ID
>>>>>>>>> Best Regards,
>>>>>>>>> Tomas Zijdemans
>>>>>>>>> Ed Merks wrote:
>>>>>>>>>> Tomas,
>>>>>>>>>>> Thanks,
>>>>>>>>>>> Tomas Zijdemans
>>>>>>>>>>>> Hello Tomas,
>>>>>>>>>>>>> 1.
>>>>>>>>>>>> time..
>>>>>>>>>>>> Alex Shatalin
Re: ConcurrentModificationException [message #159898 is a reply to message #159874] Tue, 13 November 2007 04:21 Go to previous messageGo to next message
Hello Tomas,
Can you please submitt corresponding request for me - I'll be able to correct
GMF generator to get rid of this error in future.
Alex Shatalin
Re: ConcurrentModificationException [message #159931 is a reply to message #159756] Tue, 13 November 2007 07:43 Go to previous messageGo to next message
Hi, Ed et al.,
I seem to recall something about the resources list of the ResourceSet
implementing a custom iterator that was tolerant of additions (by proxy
resolution) during iteration. Was this not done in EMF 2.0 or some such
long ago release? Am I out to lunch? Sounds like a useful capability for
this particular list to have, in general.
Christian
Ed Merks wrote:
> Tomas,
> it to
>> * @generated
>> if (info != null) {
>> for (Iterator it =
>> it.hasNext();) {
>> return;
-----8<-----
Re: ConcurrentModificationException [message #159947 is a reply to message #159931] Tue, 13 November 2007 08:01 Go to previous messageGo to next message
--------------010506050308060306090700
Christian,
There's EcoreUtil.ContentTreeIterator.ResourcesIterator, but that's used
for the tree iterators. The iterator for ResourceSet.getResources
itself is just a plain old fail fast iterator. I'm not sure it's a good
idea to make it be not fail fast given that some clients might well
expect to see only resources that were there at the start of the
iteration, which is generally a safe assumption when using an iterator.
Christian W. Damus wrote:
> Hi, Ed et al.,
> Cheers,
> Christian
> Ed Merks wrote:
>> Tomas,
>> it to
>>> * @generated
>>> if (info != null) {
>>> for (Iterator it =
>>> it.hasNext();) {
>>> return;
> -----8<-----
<html>
<head>
</head>
Christian,<br>
<br>
used for the tree iterators.&nbsp;&nbsp; The iterator for
ResourceSet.getResources itself is just a plain old fail fast
iterator.&nbsp; I'm not sure it's a good idea to make it be not fail fast
given that some clients might well expect to see only resources that
were there at the start of the iteration, which is generally a safe
assumption when using an iterator.<br>
<br>
<br>
<blockquote cite="mid:fhc665$v4c$1@build.eclipse.org" type="cite">
<pre wrap="">Hi, Ed et al.,
Christian
Ed Merks wrote:
</pre>
<pre wrap="">Tomas,
it to
</pre>
<pre wrap="">Well, it is a generated method, so it would be kind of strange if the
* @generated
if (info != null) {
for (Iterator it =
it.hasNext();) {
return;
</pre>
</blockquote>
</blockquote>
<pre wrap=""><!---->
-----8&lt;-----
</pre>
</blockquote>
<br>
</body>
</html>
--------------010506050308060306090700--
Re: ConcurrentModificationException [message #159995 is a reply to message #159947] Tue, 13 November 2007 08:55 Go to previous message
Hi, Ed,
Thanks for clarifying! I'm glad I'm not out to lunch.
I see that the tree iterator naturally has different semantics from the
usual iterator. The very process of iterating contents may add to the
resources list (resolving containment proxies) so this is necessary in that
context. That isn't the case with simple iteration over
ResourceSet::getResources(), so I withdraw my remark.
cW
Ed Merks wrote:
> Christian,
>> Hi, Ed et al.,
>> for this particular list to have, in general.
>> Cheers,
>> Christian
-----8<-----
Previous Topic:Specifying Location of Element during Configuration
Next Topic:Diagram - Model element separation
Current Time: Sun Apr 27 02:06:39 EDT 2025
Powered by FUDForum. Page generated in 0.05936 seconds
