Home » Language IDEs » ServerTools (WTP) » WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0
WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #158652] Tue, 31 January 2006 17:59 Go to next message
Originally posted by: tpp+eclipsezone.iki.fi
I have no problems creating WTP projects or publishing them onto my Tomcat 5.0 server.
However, when I try and start the Tomcat 5.0 instance, this is what I get:
java.lang.IllegalArgumentException: Document base C:\develop\workspace\.metadata\.plugins\org.eclipse.wst.serv er.core\tmp0\.\wtp-test does not exist or is not a readable directory
The wtp-test web application has properly been published into:
C:\develop\workspace\.metadata\.plugins\org.eclipse.wst.serv er.core\tmp0\webapps\wtp-test
Why is Eclipse omitting the "webapps" directory from the document base? I couldn't find a similar bug described in this forum, on Eclipse Bugzilla or by googling it.
Any ideas for an (easy) workaround?
-TPP
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #158702 is a reply to message #158652] Wed, 01 February 2006 12:58 Go to previous messageGo to next message
With a fresh install of Eclipse 3.1.2, WTP 1.0 (using individual zips),
and a fresh workspace, I don't see this problem. In the server.xml file
under the Tomcat server's folder in the Servers project, what does the
docBase attribute contain for the Context element for this web project?
Larry
> -TPP
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #158711 is a reply to message #158702] Wed, 01 February 2006 13:39 Go to previous messageGo to next message
My WTP 1.0 installation is fresh, but Eclipse 3.1.2 was installed over 3.1.1 using the 3.1.x update site. Maybe that's the problem, who knows.
The context is as follows:
<Context docBase="wtp-test" path="/wtp" reloadable="true" source="org.eclipse.jst.j2ee.server:wtp-test"/>
Thanks for the tip. I didn't figure to look into that. I changed docBase to "webapps/wtp-test" and it works like wonders. I wonder why it's not doing that thing right the first time though.
Thanks for your help!
-TPP
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #158719 is a reply to message #158711] Wed, 01 February 2006 15:28 Go to previous messageGo to next message
The docBase attribute should be relative to the appBase attribute of the
<Host> element in server.xml. This implies that the docBase you give
below is correct for a default server.xml. At the moment, the Tomcat
support assumes appBase is set to "webapps", and has problems if it is
not. You might check what it is set to in your server.xml.
Also, since your project name isn't the same as its context-root, you
may want to keep an eye on:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=125364
I'm still working on the patch I promised in that bug.
Larry
> -TPP
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #158727 is a reply to message #158719] Wed, 01 February 2006 16:00 Go to previous messageGo to next message
appBase is unset in server.xml.
catalina.base passed onto the server from an Eclipse launch configuration created for the Tomcat server is:
I suspect this is where it's getting it wrong. I can't change this value. Everytime I do, it's automatically changed back whenever I start the server.
-TPP
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #158735 is a reply to message #158727] Wed, 01 February 2006 16:13 Go to previous messageGo to next message
Change it in the server.xml found in the server's subfolder of the
Servers project found in your workspace. In the J2EE perspective, it's
found in the Other Projects folder of the Project Explorer navigator.
That one is used as the source for the one written down under the
".metadata" directory.
Larry
> -TPP
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #158742 is a reply to message #158735] Wed, 01 February 2006 16:20 Go to previous messageGo to next message
Thanks. Worked well.
I'll see what happens when I publish another project or create another server (Tomcat 5.5).
-TPP
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #159201 is a reply to message #158742] Mon, 06 February 2006 13:57 Go to previous messageGo to next message
Originally posted by: info.catmedia.us
So does it only happen with Tomcat 5.0 not other 5.x versions?
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #159215 is a reply to message #159201] Mon, 06 February 2006 14:38 Go to previous messageGo to next message
Any Tomcat version which uses the appBase attribute on the <Host>
element to establish what relative docBase settings are relative to.
This means Tomcat all 4.x and 5.x. Tomcat support currently assumes it
is always set to "webapps".
Larry
Re: WTP 1.0 + Eclipse 3.1.2 - problems running webapps with Tomcat 5.0 [message #159223 is a reply to message #159201] Mon, 06 February 2006 14:38 Go to previous message
I didn't try 5.5 yet, other priorities at work right now.
If I had to guess what caused the problem, I'd guess it's our server.xml file. It's a little, um, messy. I should try with a clean server.xml file and see what happens.
Previous Topic:Can't Export WAR File
Next Topic:Problems doing Tutorial "Running Web service scenarios using Ant"
Current Time: Thu Oct 16 20:33:13 EDT 2025
Powered by FUDForum. Page generated in 0.04429 seconds
