how to export a plug-in with icon included? [message #158511] |
Tue, 18 November 2003 22:15 |
Originally posted by: progers.classwide.com
I have an icon associated with a plug-in I've created. The
corresponding gif is located in a subdirectory (imaginatively) named
"icons" underneath that of the plug-in directory. The manifest
references this directory and gif and everything works as expected --
the icon shows up where it should when I test the plug-in via the
run-time workbench.
My problem is that when I use the "export" wizard the resulting zip
file does not include the icon subdirectory and gif.
I'm using "Export...", "Deployable plug-ins and fragments", and
selecting "a single deployable ZIP file" as well as "include source
code".
I can manipulate the resulting ZIP file manually, inserting the gif,
but it will not have the right directory path.
Is there a way to get the icon into the zip file using the wizard?
Pat Rogers
rogers@gnat.com
FUDForum. Page generated in 0.04233 seconds
