Home » Archived » BIRT » How to build (and run) BIRT from CVS ?
How to build (and run) BIRT from CVS ? [message #158484] Fri, 05 May 2006 00:46 Go to next message
Originally posted by: julio.nospam.no
I have tried several things without any success. I followed the
instructions here:
http://www.eclpse.org/birt/phoenix/build/buildInstructions.p hp
but things don't work as expected.
The "Prepare the viewer" part, where I run the ant scripts fails with
this error:
[javac] error: IO exception sun.io.MalformedInputException
Though compiling the source code from Eclipse itself works just fine.
Since the code seems to compile fine in Eclipse (not Ant), I still
followed the instructions for running BIRT in a runtime workspace.
It all seems okay, until I create a .rptdesign file and the editor opens
(or tries to open). In which case I get a ClassCastException
java.lang.ClassCastException: org.eclipse.ui.part.FileEditorInput
org.eclipse.birt.report.designer.internal.ui.editors.parts.A bstractMultiPageLayoutEditor.superSetInput(AbstractMultiPage LayoutEditor.java:558)
org.eclipse.birt.report.designer.internal.ui.editors.parts.A bstractMultiPageLayoutEditor.init(AbstractMultiPageLayoutEdi tor.java:723)
So I'm really out of luck.
Are there any instructions that actually work for
- BIRT 2.0.1
- Latest BIRT (nightly build)
Thanks!
--J
Re: How to build (and run) BIRT from CVS ? [message #158494 is a reply to message #158484] Fri, 05 May 2006 00:49 Go to previous message
Julio wrote:
> I have tried several things without any success. I followed the instructions here:
Sorry for the broken link, here it is again:
http://www.eclipse.org/birt/phoenix/build/buildInstructions. php
Previous Topic:using xsd and xml file in ODA XML data source and data sets possible problem
Next Topic:How to set URL in openReportDesign
Current Time: Wed Jan 15 09:30:31 GMT 2025
Powered by FUDForum. Page generated in 0.03391 seconds
