Home » Language IDEs » C / C++ IDE (CDT) » conflicting names in standard make project
conflicting names in standard make project [message #158371] Fri, 18 November 2005 03:27 Go to next message
Originally posted by: josef.baumgartne.de.telex.com
I have a problem with the gnu error parser. I have a standard make C
project.
The project has several subdirectories with a makefile for each
subdirectory.
A make in the root directory recursively calls the makefiles in the
subdirectory.
The different subdirectories can contain files with the same name (e.g.
main.c).
If I do a build and the compiler detects a problem in auch a file I cannot
jump to the error, because the error parser reports "conflicting names".
I tried to solve this by creating a "Make Target" in a subdirectory and
making only this subdirectory. I thought the error parser would then only
check the files in this directory, but the problem still occurs and I get
conflicting names.
Does anybody know how to solve this?
Josef
Re: conflicting names in standard make project [message #158380 is a reply to message #158371] Fri, 18 November 2005 03:51 Go to previous messageGo to next message
Hi Josef,
this bug should be fixed in CDT 3.0.1 - see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=108920 for details.
Norbert
"Josef Baumgartner" <josef.baumgartne@de.telex.com> schrieb im Newsbeitrag
news:7307d56a33d991da0e28c9d037aee192$1@www.eclipse.org...
> Hello,
> project.
> subdirectory.
> subdirectory.
> main.c).
> conflicting names.
> Josef
Re: conflicting names in standard make project [message #158404 is a reply to message #158380] Fri, 18 November 2005 05:36 Go to previous messageGo to next message
Originally posted by: josef.baumgartner.de.telex.com
Hi Norbert,
thank you. I looked at the bug and found a link to bug 108489. I think this
is the right one and unfortunately it isn't fixed yet.
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=108489)
I use Eclipse 3.1 and CDT 3.0.1
Josef
Norbert Ploett wrote:
> Hi Josef,
> Norbert
>> Hello,
>> project.
>> subdirectory.
>> subdirectory.
>> main.c).
>> conflicting names.
>> Thanks,
>> Josef
Re: conflicting names in standard make project [message #158411 is a reply to message #158404] Fri, 18 November 2005 06:10 Go to previous messageGo to next message
Josef,
so it is a bug and somebody will have to fix it. :-)
Will you?
In that case you can see at which class to start from "my" bug.
Norberr
"Josef Baumgartner" <josef.baumgartner@de.telex.com> schrieb im Newsbeitrag
news:5e99453753e5dad77c9e63d8696f4267$1@www.eclipse.org...
> Hi Norbert,
> this
> Josef
>> Hi Josef,
>> Norbert
>> Newsbeitrag news:7307d56a33d991da0e28c9d037aee192$1@www.eclipse.org...
>>> Hello,
>>> project.
>>> subdirectory.
>>> subdirectory.
>>> main.c).
>>> cannot jump to the error, because the error parser reports "conflicting
>>> names".
>>> only check the files in this directory, but the problem still occurs and
>>> I get conflicting names.
>>> Thanks,
>>> Josef
Re: conflicting names in standard make project [message #158555 is a reply to message #158411] Mon, 21 November 2005 02:24 Go to previous message
Norbert,
sorry, but I think I'm not able to fix that bug :-(
So I hope somebody else does.
Josef
> Josef,
> Will you?
> Cheers,
> Norberr
>> Hi Norbert,
>> this
>> Josef
>>> Hi Josef,
>>> Norbert
>>>> Hello,
>>>> project.
>>>> subdirectory.
>>>> subdirectory.
>>>> main.c).
>>>> names".
>>>> Thanks,
>>>> Josef
Previous Topic:What a reasonable computer configuration is needed for quick Code Assist?
Next Topic:how to change linker output name
Current Time: Sat Oct 25 08:43:23 EDT 2025
Powered by FUDForum. Page generated in 0.32537 seconds
