Re: how can I make the cvs version become 3 digi? [message #158422 is a reply to message #158340] |
Mon, 26 June 2006 13:48 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: cburgess.progressrail.com
CVS only uses additional digits on a file revision number to indicate a
"branch" revision as opposed to a two-digit mainline "HEAD" revision.
If your intention is to try branding your files with a "software release
version" number, you should investigate using "tags" in CVS. It was
NEVER an intention in CVS to use file revision numbers to represent a
software-wide version number.
calendarw @ Jr.P wrote:
> I seen that I use eclipse to commit project and it will become a 2 digi cvs
> version, how can make it become 3 digi? (1.1.1)
> Thanks.
FUDForum. Page generated in 0.08124 seconds
