UI SWTException: Invalid thread access during a stack command [message #158186] |
Tue, 16 November 2004 18:46  |
Originally posted by: brett.bock.embarcadero.com
I'm wondering if this is a bug, and if it is not a bug, what would be the
prefered method to fix this issue. Below you can see a stack trace of the
SWT exception.
What we are doing here is using an org.eclipse.ui.newWizards wizard to
create a new model element. The actual creation may take a while so the
creation of the model element has been placed into its own thread. Creating
the new model element then creates a command stack change, which sends an
update to the editor, which calls into the framework to update the text for
the diagram name. Since the name change is not in a UI thread we get the
SWT exception.
!ENTRY org.eclipse.core.runtime 4 2 2004-11-16 16:15:11.932
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
org.eclipse.swt.SWTException: Invalid thread access
at org.eclipse.swt.SWT.error(SWT.java:2697)
at org.eclipse.swt.SWT.error(SWT.java:2622)
at org.eclipse.swt.SWT.error(SWT.java:2593)
at org.eclipse.swt.widgets.Widget.error(Widget.java:385)
at org.eclipse.swt.widgets.Widget.checkWidget(Widget.java:288)
at org.eclipse.swt.widgets.Widget.getData(Widget.java:415)
org.eclipse.ui.internal.presentations.defaultpresentation.De faultTabFolder.g
etTab(DefaultTabFolder.java:159)
etItems(DefaultTabFolder.java:211)
org.eclipse.ui.internal.presentations.newapi.AbstractTabFold er.findItem(Abst
ractTabFolder.java:169)
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.getTab(Pr
esentablePartFolder.java:378)
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.childProp
ertyChanged(PresentablePartFolder.java:311)
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder.access$2(
PresentablePartFolder.java:310)
org.eclipse.ui.internal.presentations.newapi.PresentablePart Folder$3.propert
yChanged(PresentablePartFolder.java:84)
org.eclipse.ui.internal.presentations.PresentablePart.firePr opertyChange(Pre
sentablePart.java:90)
org.eclipse.ui.internal.presentations.PresentablePart$1.prop ertyChanged(Pres
entablePart.java:62)
org.eclipse.ui.internal.WorkbenchPartReference.firePropertyC hange(WorkbenchP
artReference.java:342)
org.eclipse.ui.internal.WorkbenchPartReference.partPropertyC hanged(Workbench
PartReference.java:139)
org.eclipse.ui.internal.WorkbenchPartReference$1.propertyCha nged(WorkbenchPa
rtReference.java:63)
at org.eclipse.ui.part.WorkbenchPart$1.run(WorkbenchPart.java:1 29)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java
:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.ui.part.WorkbenchPart.firePropertyChange(Workben chPart.java:127)
org.eclipse.gef.ui.parts.GraphicalEditor.firePropertyChange( GraphicalEditor.
java:145)
com.embarcadero.ui.infrastructure.gef.ui.parts.DiagramEditor .setDirty(Diagra
mEditor.java:580)
com.embarcadero.ui.infrastructure.gef.ui.parts.DiagramEditor .commandStackCha
nged(DiagramEditor.java:562)
org.eclipse.gef.commands.CommandStack.notifyListeners(Comman dStack.java:186)
at org.eclipse.gef.commands.CommandStack.execute(CommandStack.j ava:89)
com.embarcadero.infrastructure.core.undoredo.ETCommandManage r$ETCommandStack
..superExecute(ETCommandManager.java:57)
com.embarcadero.infrastructure.core.undoredo.ETCommandManage r.execute(ETComm
andManager.java:92)
com.embarcadero.infrastructure.core.utils.XMLManip.setAttrib uteValue(XMLMani
p.java:359)
com.embarcadero.infrastructure.core.metamodel.core.foundatio n.VersionableEle
ment.setXMIID(VersionableElement.java:298)
ment.buildNodePresence(VersionableElement.java:1114)
com.embarcadero.infrastructure.core.metamodel.core.construct s.Class.establis
hNodePresence(Class.java:99)
ment.prepareNode(VersionableElement.java:87)
com.embarcadero.infrastructure.core.metamodel.core.foundatio n.CreationFactor
y.prepareNewElement(CreationFactory.java:144)
y.retrieveMetaType(CreationFactory.java:108)
com.embarcadero.infrastructure.core.metamodel.core.foundatio n.FactoryRetriev
er.createType(FactoryRetriever.java:109)
com.embarcadero.ui.infrastructure.wizard.NewElementWizard.do Finish(NewElemen
tWizard.java:122)
com.embarcadero.ui.infrastructure.wizard.NewElementWizard$1. run(NewElementWi
zard.java:81)
org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext
..java:105)
92824 [ModalContext] ERROR
ment - java.lang.NullPointerException
Re: UI SWTException: Invalid thread access during a stack command [message #158203 is a reply to message #158186] |
Tue, 16 November 2004 21:21  |
Put the code that needs UI thread access on the UI thread (look at
org.eclipse.swt.widgets.Display#syncExec() and asyncExec()).
"Brett Bock" <brett.bock@embarcadero.com> wrote in message
news:cne3g9$4r6$1@www.eclipse.org...
> SWT exception.
Creating
for
> SWT exception.
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> :616)
> at
> at
> java:145)
> at
> mEditor.java:580)
> at
> at
> at
> at
> andManager.java:92)
> at
> p.java:359)
> at
> at
> at
> at
> at
> at
> at
> at
> tWizard.java:122)
> at
> zard.java:81)
> at
> .java:105)
FUDForum. Page generated in 0.03725 seconds
