status of "Extended Java Family" theme [message #157952] |
Mon, 10 May 2004 05:37 |
yuqui Messages: 4 Registered: July 2009 |
Junior Member |
I would like to confirm how much "Extended Java Family" theme's works are
completed and what are remained to be done.
As I tested with M8 and read "New and Noteworthy" documents, I assume:
-"Improve support for Java-like source file"(such as JSP, SQLj) is NOT
completed yet.
-"Support Java references outside Java code" completed in some
aspects(like launch configuration, javadoc comments) but there are many
things which aren't implemented yet(plugin manifest files, extension point
schema files and so on).
Am I right? Please tell me if I'm worng.
And, is there something like check sheets which you can figure out what is
planned to be implemented in 3.0, and what is already implemented until
M8??
Checking all the "what's new" documents are really heavy :-(
Yuki
FUDForum. Page generated in 0.03991 seconds
