Home » Newcomers » Newcomers » Installing???
Installing??? [message #157860] Wed, 21 June 2006 15:07 Go to next message
Originally posted by: icockcroft.fnb.co.za
Hi, I am trying to run the eclipse exe and it gives me a message to check
a log. The log says
!SESSION Wed Jun 21 19:44:22 GMT+02:00 2006
!ENTRY org.eclipse.core.launcher 4 0 2006-06-21 19:44:22.218
!MESSAGE Exception launching the Eclipse Platform:
!STACK
java.lang.RuntimeException: Could not find framework
at org.eclipse.core.launcher.Main.getBootPath(Main.java:635)
at org.eclipse.core.launcher.Main.basicRun(Main.java:272)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
WHATS GOING ON?
The java JDK is working fine because I have run and tested it from CMD?
Help.........please.............
txs
Ian
Re: Installing??? [message #157868 is a reply to message #157860] Wed, 21 June 2006 15:14 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
This usually means your zip client did not expand the directory
structure properly when it unzipped the eclipse archive. If you're using
WinZip, make sure you have the option "maintain directory structure"
checked.
Hope this helps,
- Jeff
Re: Installing??? [message #158024 is a reply to message #157860] Wed, 21 June 2006 16:23 Go to previous message
Originally posted by: eclipse4.rizzoweb.com
> check a log. The log says
> !STACK
> WHATS GOING ON?
This is a frequent question on this newsgroup - please search the
message archives before posting questions.
Previous Topic:How to reference an external class?
Next Topic:missing org.eclipse.swt
Current Time: Fri Apr 25 18:38:51 EDT 2025
Powered by FUDForum. Page generated in 0.07736 seconds
