Re: Integrating Birt into RCP [message #157845 is a reply to message #157785] |
Tue, 02 May 2006 17:57 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
------=_NextPart_000_0050_01C66DF0.68511240
Content-Type: multipart/alternative;
boundary="----=_NextPart_001_0051_01C66DF0.68511240"
------=_NextPart_001_0051_01C66DF0.68511240
Content-Type: text/plain;
charset="iso-8859-15"
If you have predefined the report and just want to run and display it =
this is very simple
Previous post
You can include the BIRT plugins and
call the following lines of code on an action
System.setProperty( "RUN_UNDER_ECLIPSE", "true" );
DtpManifestExplorer.getInstance( ).getExtensionManifests( );
WebViewer.display(reportName , WebViewer.HTML, browser);
Where browser is SWT browser or
WebViewer.display(reportname, WebViewer.HTML,false);
to display in standard browser window.
Attached is an example of using BIRT in a simple RCP applicaiton.
Jason"Gersh" <gershwinou@gmail.com> wrote in message =
news:444b0dc02f5c96b8c09c01131a6df601$1@www.eclipse.org...
> Hi everybody,
>=20
> I am prospecting BIRT for reporting.
> Here is my question: I built an app based on RCP, which basically run=20
> analysis and save them into XML files. I would like to know whether it =
is=20
> possible to intgrate BIRT in such way, that i press a button and it=20
> generate a PDF report from an input XML file, according to a =
predefinite=20
> design.
> I am not using database.
>=20
> I tried a bit the designer to connect some XML files and so on, but is =
it=20
> possible to do the connection inside RCP, and then build the report, =
and=20
> where do I have to check tutorials/snippets?=20
>=20
> Thanks a lot for any answer
>=20
> Gersh
Content-Type: text/html;
<HTML><HEAD>
charset=3Diso-8859-15">
<META content=3D"MSHTML 6.00.2900.2802" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY>
<DIV>
<P><FONT face=3DArial size=3D2>If you have predefined the report and =
just want to=20
run and display it this is very simple</FONT></P>
<P><FONT face=3DArial size=3D2>Previous post</FONT></P>
<P><FONT face=3DArial size=3D2>+++++++++++++</FONT></P><PRE =
wrap=3D""><FONT face=3DArial size=3D2>You can include the BIRT plugins =
and
Jason</FONT></PRE></DIV>
<DIV><FONT face=3DArial size=3D2>"Gersh" <</FONT><A=20
href=3D"mailto:gershwinou@gmail.com"><FONT face=3DArial=20
size=3D2>gershwinou@gmail.com</FONT></A><FONT face=3DArial size=3D2>> =
wrote in=20
message </FONT><A=20
href=3D"news:444b0dc02f5c96b8c09c01131a6df601$1@www.eclipse.org"><FONT =
face=3DArial=20
size=3D2>news:444b0dc02f5c96b8c09c01131a6df601$1@www.eclipse.org</FONT></=
A><FONT=20
face=3DArial size=3D2>...</FONT></DIV><FONT face=3DArial size=3D2>> =
Hi=20
everybody,<BR>> <BR>> I am prospecting BIRT for reporting.<BR>> =
Here is=20
my question: I built an app based on RCP, which basically run <BR>> =
analysis=20
and save them into XML files. I would like to know whether it is =
<BR>>=20
possible to intgrate BIRT in such way, that i press a button and it =
<BR>>=20
generate a PDF report from an input XML file, according to a predefinite =
<BR>> design.<BR>> I am not using database.<BR>> <BR>> I =
tried a bit=20
the designer to connect some XML files and so on, but is it <BR>> =
possible to=20
do the connection inside RCP, and then build the report, and <BR>> =
where do I=20
have to check tutorials/snippets? <BR>> <BR>> Thanks a lot for any =
answer<BR>> <BR>> Gersh<BR>></FONT></BODY></HTML>
------=_NextPart_001_0051_01C66DF0.68511240--
Content-Type: application/octet-stream;
name="org.eclipse.birt.rcp.viewer.zip"
Content-Disposition: attachment;
filename="org.eclipse.birt.rcp.viewer.zip"
UEsDBAoAAAAAAKp7cDQAAAAAAAAAAAAAAAAcAAAAb3JnLmVjbGlwc2UuYmly dC5yY3Audmlld2Vy
L1BLAwQUAAAACACpe3A0DI1YXLMAAABTAQAAJgAAAG9yZy5lY2xpcHNlLmJp cnQucmNwLnZpZXdl
ci8uY2xhc3NwYXRorZDNCsIwEITPCr5Dyd2oNw+tIqKgB5VSz1KTpY3GTdwk om9v/SkV9OhtZ/lm
2Nl4fD3p6ALklMGEDXifRYDCSIVFwrbZvDtk41GnHQudO2dzX1ai1ShAT7fo qFAmzJFg0WP5Gnu/
SLhaQx4q2lMA9nYKg7XTUMFBaGUd8IP0XOcBRVldw5fpbDddr7LJYjVL/5Bu JXBhCDjBOSgCudGh
UOia6O+KJngbfJ22V/iE497nd+5QSwMEFAAAAAgAqXtwNHZjWZTrAAAAsAIA ACQAAABvcmcuZWNs
aXBzZS5iaXJ0LnJjcC52aWV3ZXIvLnByb2plY3S9ks1OAyEUhdea+A7N7IW6 c0GniZruNCbVB6Bw
HW8z/OTCTPv4AqE6TZvGhXE19xzO4SMwYrk3/WwECujsorlj82YGVjmNtls0 72+r2/tm2d5cC09u
Cyo+QVCEPqZ0cq+ElQZaRx0D1aMPwDZIkZHybETYAQmeEyWqnDFgYyt4nbJ7 2DcUwY/UZsBerz2o
rKp8TFVpdXHO0Lc6MuUoDXKUpXA4Qm1I6obMDlXzqZH1lPJ7rtfAnqXFDwjx 4X+xa/UJRv4JNDs/
V555cSAo6SpO8a/90KF9KYuJXr6TwoXnsSedNH8TBT/7x30BUEsDBAoAAAAA AKl7cDQAAAAAAAAA
AAAAAAAgAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9QSwME CgAAAAAAqXtwNAAA
AAAAAAAAAAAAACQAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvYmlu L29yZy9QSwMECgAA
AAAAqXtwNAAAAAAAAAAAAAAAACwAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52 aWV3ZXIvYmluL29y
Zy9lY2xpcHNlL1BLAwQKAAAAAACpe3A0AAAAAAAAAAAAAAAAMQAAAG9yZy5l Y2xpcHNlLmJpcnQu
cmNwLnZpZXdlci9iaW4vb3JnL2VjbGlwc2UvYmlydC9QSwMECgAAAAAAqXtw NAAAAAAAAAAAAAAA
ADUAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvYmluL29yZy9lY2xp cHNlL2JpcnQvcmNw
L1BLAwQKAAAAAACqe3A0AAAAAAAAAAAAAAAAPAAAAG9yZy5lY2xpcHNlLmJp cnQucmNwLnZpZXdl
ci9iaW4vb3JnL2VjbGlwc2UvYmlydC9yY3Avdmlld2VyL1BLAwQUAAAACACp e3A00WCIsHcCAAB+
BAAATQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9iaW4vb3JnL2Vj bGlwc2UvYmlydC9y
Y3Avdmlld2VyL0FwcGxpY2F0aW9uLmNsYXNzjVJNUxNBEH1DNllZw4dBlAgI iEISkPELLYlFVUqx
KmUUDRH1ZG02YxhcdlOzu6D/xiPelINQWqV3f5RlzwYkwgEu3T09r7tfz7zf f77/BDCHuwzTvmpy
4biyFQhelyrkymnxTSm2hOKlVsuVjh1K3zPBGPrX7U2bu7bX5Mv1deGEJhIM hc4Wjq8EV5EXyg3B
y89dO3znq41q5Hl23RUmkgypB9KT4SJDIpdfZTAe+g2RhokzFgxYDH0V6Yln 0UZdqJouYshUfMd2
V20l9Xk/aYRrMmDIV065QZEGEjGGqVzl6B7F/LEUwa2lD45o6VqaM3AI+Jc2 McCQ7ZwfSX6w88uy
iUGGHkcJOxSPZNBy7Y8Mk7n/GQdbId+SjaYIA74PKqZxEUMWLiDLcO+U673y 1fu68Jy1UmNTBr4y
MWxhRL/nYJtByWtUo0MYw4vciUQqR3azD+fxowOL+XIalzGmeY8zpJdel2tv q0srtVK1Rs/X8cBl
LxRNoWjNK5jsRgpXGcwYvvwkjal2bpph7AR6JvJU2KCDH5CCZrSCCpgladiq SV+WOf6pGn/wExMn
rk8SUCKMlKclysDKlFjxI+WIx1JLsL/j/ef0LEygi0TMiD8oYlrVZLvpxMkz 8snCLs5+ja/TZFNx
0kIP2XQbgF70kaf2OEeoDMW65fm4zS4SMMkX93Dp6ewPjLzZxegeJhZHjU/o 3cG1hdQ2stnUlx3k
dNhL4UJyG6ls8teCMfsN1z8bMcdRzFCbceTIH5ApwCLbT7cZsgMYpKHj9J0z pMcbyOI2+XkM4T7F
PTHe0FTahONoTu9J2XuEv4ku6jKMW1SXoOydeM78X1BLAwQUAAAACACpe3A0 1B/ct4oDAABBCAAA
XQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9iaW4vb3JnL2VjbGlw c2UvYmlydC9yY3Av
dmlld2VyL0FwcGxpY2F0aW9uQWN0aW9uQmFyQWR2aXNvci5jbGFzc51UbVca RxR+Bl+AlTYJbdL0
LTGGCIKysdUaY2oCJkYS0FjfavppWEacuO5yhkXbn9WeVk/qOf0B/VE9vTNL kNYjoT0cZu/cufc+
z32Z+fOv3/8AkMcPDHO+qtvCcWWjKeyqVIGtnIZ9JMWxUHah0XClwwPpewVH r0WuCrUj2fRVFIwh
1+3ckjY/t7cvOgwwWOJHGYQnBF3+t7s5aLZdl2nrq59SpR1fHVSF5+yH+gWG EV71W504w4+kJ4NF
hplMuQehUofRku/tyXpLCbUwsc0wuOTXRAIxxC0MYoThSll6YrV1WBVqk1dd wZAs+w53t7mSet9W
Dgb7sskwX/6fJaRELKdDhWH6P7OnShzyAxEeEZXUhQKcF29HejX/2CSc6qfu UVynFNe3SpsM4311
aiGBT3Azjhv4lJriKMEDqtLrPjj1Ff7CIBDe5/jCIrwvExjCcBwR3GaIKVGX zUBX9N4/sd/scUeY
4OcFpYIkcAdjFjnfZRgqFNe2NhO4FyYynkA0DJyhlI4NXYY7782IGrMnXbci vFaRE5FsLyLaqsI9
Xm/PY+pS0y7LKPLEdnxZuiKG+9SpPSN9xZDOlN/wI2673KvbG4GSXn3hgsak HcOMBRuzOtCKcBsx
zFGgfSPNU/X6ohwFZTvAazUGu1eWNLaEXG3pXSkQh4bBt1gcwSM87pX0c+W3 GhWuDjRWgSFOWNLM
RwxLDNczlyX3zEIRywxjl4beEA2ueKAfpxVKIhP6vbBQwktdmcea4ZiWVhmi h++6me6zmTSLuita
pe9QP23VProBWtUeoiXfdw3sVK/ytq265yjqvPPM9u9Ib9KG31KO0JPFMNrj /crrutPdidCrCVoj
+hIaKaq/pGX6UaXVot2itqDvcDZ3isTPxu4DWi2jvUu+KXxI0o3QCldwlb5a uoYkGEX7CB+3Yx1g
wFils7/gs9wJbv2G0Wz2V4yeIEWqdKia0KoJUrXBTPAhWqcwgjyFu49bmMY4 ZrqA0yGwkbLIGeBJ
8giB39JOJ7t+Bns3OZ38+hTfVIz8IPmQ5NXc5Fs8iSB3huJu8ukpnofbKfOZ PENp9xTlE1QmQ7Zr
UyHFtQ5FohOndQ4JPMBNPMRtuh95GsNZPKFfASt4ild4ZihnQzIdyut0sk5U E3T+HTYQoQjz2CRp
gCy3sN1OY1aj0Z+dww6D0VruqgQLwxppB9+D0W/X2L/+G1BLAwQUAAAACACp e3A0DTIBidcBAAAU
BAAAXQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9iaW4vb3JnL2Vj bGlwc2UvYmlydC9y
Y3Avdmlld2VyL0FwcGxpY2F0aW9uV29ya2JlbmNoQWR2aXNvci5jbGFzc51T 227TQBA9G6dpY3oN
bbi1UJ6aUOF9RFCKVIUgWbJQRCpXfUIbZ3EXjG2t7fS34KkSSHwAH4UYX5RU AVWQl5nduZw5OzP7
89e3HwAs7DM8i7TPpReoOJF8pHTKtRfziZKXUvOTOA6UJ1IVhWeR/jSSoXdx Mp6oJNLLYAyH15Mz
xcUsnv+ZYDCsD/rvhoN+79R2++/t1wwt56OYCB6I0OfDVKvQP2JY60Vhkoow dUWQSYYDKmNVZayc
o0UcrZKjFUudxNJL1USuYIWh8VKFKn3FYHS6LkO9F43lKkzcMlHHGsOGo0L5 Nvs8kvpUjAKZc4g8
EbhCq/xeGevphUoYnjsL9oeesetpKVI59ZypcBxdVn6GoOPc0D57Lo1a8kH5 mZb6qOv8S9vLtBmb
4/99SAkwnd4Ow4uFGbv5BO6YaOMug+lNPbR/C0Iy7PkytWnUSgSldzDbBHvM sN3p/m25zGGUaU++
UfmU92+YoJUn4zFqqNNnYbiPJTRIL9OthiYMOtNakVwlCyfNSC89ucL61yJk g2QjN1LAZi7LAGyh
VQDexnaVfExgNdLN72ifH17h3pc5gK0CoF0GlQD5iTg9KOruYq+CelrxMFrN eZCdayyMKYuHRdSj
31BLAwQUAAAACACpe3A0lXDV1ksCAACABQAAYwAAAG9yZy5lY2xpcHNlLmJp cnQucmNwLnZpZXdl
ci9iaW4vb3JnL2VjbGlwc2UvYmlydC9yY3Avdmlld2VyL0FwcGxpY2F0aW9u V29ya2JlbmNoV2lu
ZG93QWR2aXNvci5jbGFzc6WT624SQRTH/8NVtqUtvWC9FdsqbEFZazSN1tbU JiYkRE0w1PrJZRlh
LO5uZpeS+BQ+in6xqU18AB/KeIalCzERFXeTMzuz5/zOnNv3H1+/ASjjLsOO I1sGtzrC9bjRENI3
pOUax4L3uDT2XLcjLNMXjn3gyKMGt632gbCbTm+veSw8RybBGDZHEV1hmEMr 43dmUYbEI2ELf5fh
oV4dQ6j8gth37Lei1ZVcbm/UGWL7TpNPI46EhhguMMxWhc2fdd83uHxpNjqc Yb7qWGanbkqh9oPD
mN8WHsPj6n/Fv82gWeGFGLYmjIQha0lu+nzPUqpPTBk4IOSb8dkJDUbzMs4i NBiGsPWXOQhNwzLO
M9yb4H51VbBFDQtYovb5Z3uGtCt5kMTnLrcZorrqhYUW989TO6zJA31jwqpM 4zKuaIjgKsPKKMLr
+UZLmm5bWJ7xwhG2n8QKQ1yvVILYrmvIYZXh/kSOk1hnmPG4X6EBEWanJj5Q x67r1fF36Of1JvJT
uIFCAKi1FdfpUP6o5fXXSmMDRaVRYsgMNGq+6Xc9NTfTuB38LVNj15yutPhT ocYl/8dRKL8zj02s
UrZiUE8UTE0lySTtduk8QmuiWDpB6jNAO42k1j9VKUtjir6ygRadpGlVXzOY BaN3DpkBa4fYSit1
hoVDwmU/neOUO5JzI6hUiEoR6mIftYxLA9QROVZaheIXXKuWzpA7zEReZdjH E6ydQo+gFD3FrWAx
Ihjcuw+Pk1wkuYRl2uUInSfs0HEhcEwaa2EMd/r2mz8BUEsDBBQAAAAIAKl7 cDTteNyreQEAAM8C
AABSAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcvZWNs aXBzZS9iaXJ0L3Jj
cC92aWV3ZXIvTmF2aWdhdGlvblZpZXckMS5jbGFzc5VRTU8CMRB9RRTBVRAV v28YAQ3Vg4mJxgvR
xGTFA4R7WSuULLtkt4D+LA/GxIM/wB9lnFYS9WKkSTszrzNvvt4/Xt8AVLHL cBhGHS49Xw1iydsq
0jzyBnyk5FhGvC5GqiO0CoMWAcXjFBhDridGgvsi6PDbdk96OoUZhr2fPPFY czmSgY75TXin7h9d
FWsZyCiFWYY53VVx8Yhyu/9PfsaQbjwGuiu18ojjXAVKXzDw0jQk5RZDshbe SYaZUrnlIIPFDJJY
cpDCfBoJ5Biyrgpkfdhvy6gp2j755t3QE35LRMrYEzBp2mCoTpG/eExtZPp2 JE35oBn2S+6fg7s0
hi2bUcrif5wpQyMcRp68UqbMld8lVM32GJzrgNZR80UcyxhH1HgSNFW6OTMJ kmmYk6CbwQLZDmmn
ZFuk8oJs5eAZy0/WJ28w+1O3PCukOSQNuoo1kgwFrE9YTia87Dt4zjo3bGDh 6/Mr0Gob2KQ3gS3r
v40dQ2wRc/KfUEsDBBQAAAAIAKl7cDSPWAtA8wIAADMGAABSAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92aWV3ZXIvTmF2 aWdhdGlvblZpZXck
Mi5jbGFzc5VU61LTQBT+FoKlJdzKTRQvYIW0lAYRFQFR5KJoAGcKnUH/mKZr GwxpJ1kuvozv4IwW
R0d/8sM38GUcz6YVEEEgM+3uOfvlO985e05+/PryHUAKywzJopfXueXYJZ/r WdsTumeV9C2bb3NP
XzK37Lwp7KKbIUdsJATGMHD4DX9b6HyLu8LX09zhlsRO58yS4F4ItQwXRMH2 Y8MUxzh7oAmGcPqd
Kwpc2BZxTNquLaYYdO08JPEMgzJTzHGGWi2eUVGPhggUqCrqcCGMGjQxNBu2 y5c2N7LcWzGzDmGj
RtEynYzp2dKuOhWZBkPqHPFjI5RG07ady3NRKQ3PMSQ047TyzUk7UN93FBqw EXbedvisbTrFfAid
RHp2VSFcZKg3LYv7wbUY5yupcZKiFb4jJlRcwuUIutHD0PM/ZAhXSYUsTIE7 DkOvdjJzACHq6+iN
4Br6qCzaKeDKZcci6MJNhpZ1c8vUHdPN62nh2S7VbIChIZHySiLHfTvv1iPO 0OZzQXWlxp3bEdz1
KWe68U7tlXH0/YB/EEnJP8QQosgyKYZ2Lf4PmJTrGJbKb1EbkWtDxW3p0DBK re1wNy8KQYcuqLiL
e/JgjKFxX80LU553aMfLGMeElDFJ3MUSd1VMETc5HpIuv6JLxTSBSMBjBsZp fs/YgaQuF/QYQ8w4
vRPl0PI/laNyHlM3ugu/OglyyEQAjB6Hi6SLm57FJTtR/d2FKYlnUBdcl3sz jun73McwjbNC3zQK
Iaeb1hDkU0O/eoTJjtBujGzpiSR20ZgY/ITmDwGmRfqCkzUohG2lnUqr9EbR FvC2o6PK8pMwdbTm
v6JrLfERzZ9xpYwbu+hfVL5BW6uNJtJLyaEyUvuHI3uIHRhl3Cnj/nu0Jg/7 HiTLeDSudCt7aK76
u5UyZg4k9iNM/69JkokeZNELi+72DZaxjlW8xUtskFUM5I9WJFbkB7tZzFEC UULO4wlqiOE5nmIB
tVgl7zOyFPIaQbRFLAXJM9rLJ/obUEsDBBQAAAAIAKp7cDTvKSWOxwEAAIcD AABSAAAAb3JnLmVj
bGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3Jj cC92aWV3ZXIvTmF2
aWdhdGlvblZpZXckMy5jbGFzc5WSXWsTQRSG35PEbrJd2zS19fuzAdNVMpUi CIoIVUFY6kUk95PN
mE7Z7padyQZB8M7/IyiKF/4Af5R4ZrfU6I3pLMP52LPPe+bM/vz1/QeAPrYI 97N8IlSc6GOjxEjn
VuTxsSi0mqlc7MtCT6TVWTrkRHfXAxHah7KQIpHpRLweHarYeqgTevMcM7NC FSq1RgxUwiVMiLSx
KlW5h3OEJXugTXeH5aPF9R8TWoN3qT1QVsfMeKJTbZ8SRO8skO0hobGXjRWh 3tseBvBx3kcDKwE8
NFuooU1YjXSq9qdHI5W/kaOEaztRFstkKHPt4pNkwx2D0D+DfneXj7Ey0+OJ stVs1JgQ9qL/ze+F
i8vuw8XVPFwiNGUcK2O6DwJcwbKPy7hKIG7/7oKihI2q4efqrZwmc337g2ya x+qldtNY/1u77/4T
QvAq5VvfS6QxymAHNZ41Xx7vths42xbcqvP2scxxwN4jrqu5TPgVq+G9L1j7 xFENHZcr3xQlZ529
gK3LXsAGW8ImLp5QnrF1tc3wM9a+4dq/jPfcwYeSsVnVVYzSu44bIH5untIe uq+dwh/MUin9cQ5B
pwiqEJy9Vdbfxh0nXGbc6vwGUEsDBBQAAAAIAKp7cDQH00n63AEAAAoEAABS AAAAb3JnLmVjbGlw
c2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92 aWV3ZXIvTmF2aWdh
dGlvblZpZXckNC5jbGFzc5WS227TQBCG/0lMnbiGQArlfKwhrkFxhXqBVIQE BSSkqKoUlAvuNs7K
WRTsaHebiJfgAi7gNZA4iQsegIdCjJ1ccCZZy9qZ3zPf7Mz667fPXwC0ERJu 5DqNZTJSYyPjvtI2
1sk4nig5lTreExOVCqvyrMdCsO2CCK0fM8zUxn2dTw1Hd/KkjL07EGMrtYsq YcUOlQm2uE5n8UI7
hHr3eWaH0qqEGbdVpuwdQhwuA9nsEZzdfCAJ1XCz56OGVQ8OfB+HsFJHBUcI jY7K5N7Bs77Uj0V/
xLHNoo1RT2hV+HPRKdogtJeoH2xzG24yFFkqB4Qo7Pxvbg8mMrPlsaPFy7hY J9REkkhjgpuE7nIz
+u1QUzVIpTXxvs5Tzcx7Qu/4OIXTHk7iDGFjgQQX5wiekbanjJrNL3xS3MAF XPRwHpcIxGJrwYlw
f+UYVZYytpsf6EQ+VAV27ed22k/FRBD8R1km9e5IGCMNtviiHf7bCUeLe+fd RbGq/NZQZ99j6xZH
VXj3oo84HF1/j8Zb9iqcw1r55QUcjj3Gls97oTaxVnKP48Sccn9O8aN3aHzC 2eoHXP6V8xKreFVy
1mexM05pXcEGiJ/gr0TnD8TXTHzzLyKrV8uca2gVWaVSrOZ3UEsDBBQAAAAI AKp7cDQP49+m2g0A
ABkfAABQAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2Jpbi9vcmcv ZWNsaXBzZS9iaXJ0
L3JjcC92aWV3ZXIvTmF2aWdhdGlvblZpZXcuY2xhc3OtWQl4HFd9//11zWp2 JcuS42ST2JYTJ1lL
Wm18JI7XjmNLlmwla9lYRolMEjOSxqtx1rub3ZEUp+VKKClXCFcg4QhHqcNl EhOtLAQhJJS2tNAA
pRBIKS20pVBaQkuBQBN+/5nVZUn2+oNP3868ee9/n+89ffmFzzwOoFVuEzRl csmYPZBysnk71u/k
3FhuIBsbcexROxfrtkacpOU6mXQvJwyI4OLZ8MNOLGsRRVf3cWCgXFDWtVNQ nzhijVixlJVOxnrc
nJNObhHUtGfSeddKu71Watj2ebcWabUq71bybvV5t6bn8A4gIKjN2dlMzk1k Brx5wcrEbGnyo25s
1BlM2m4+dsC+wyXH+v5cZjRvd2ZSg3aubdh1FatxUSwfgnhGiurYaVdw6aLA 7Zmj2UzecW3CB5I5
Z3Cn5VqC1fMQUtaxzLAb21UEIXh1W9f+A4d2793TQQbtcc/u0dxw2nWO2tH1 h648tC6231O1sSOd
dNJ2AA2C4P6OfXuJ1tmVINpKorl23vUePdbRbMre2daay7qDdt5JpgNYTi18 7XMLCVVcirX57y2k
n81lkjk7n2+ziHHZonrvmwZTrKqtTtpxtwnKI2t7BRXtmUE7hIuxwkQFVoVg IliNMqwOIYQaHV0q
WJKgTt3DR/vt3AGrP2XTT+rTVK+Vc/S7OFnhDjl5QUui9BClQEsHcrbl2hqO DDc3l0kJLo+U4MW1
vSHUYonK2EyLncGLCW9oIGqiFasIe1biBq6k1/O266PS64tL5IN44qzHBhPr sFGw6ixBZeBqGizS
pVgX4xoTm7A5hDosVXVolRWLcCOBzHDWwLWCK0oxUpHBdSa2YTszssdO2QNu o5+Y8QDaGHVUk+lH
Jc+LzK8Cir8THYrfKaiMdB30Ke5WW3ZxWrWtmbaU6nYaob39R8jSI5TAHsXo VnVXUZqhTM65k063
Uj1Zi5kuXSG8BPurudxzBhskrH47ZeClJnpVKbNzOJVq3Ge5Q1ToJp3s1Ec3 i9+Zyo2Bm03cgu18
KGxL6VG7Zp2BlwtikXOJdN9s/SYsDDDqrcHBPZlB5/CxhJN37bQmfdN8h9oj dprizoX0SNk4rIIn
WVnOXB0NOOWMKSb2ETVWeWtrawBH9avz3JRebyBr4naVfhml9yJJF2cUiC6q wDTwHB3ycFWOYbpw
/3C60S+hAYyem1wbDBwzcafKteosVdPAH5t4BbaHcAHCmmmv4ue5On+jgbtM 3K38GmgHrYRnNcOU
HAo8zwx/gtepGPcwFSNdXQeLCfZ6TZI30DRDtpMccnc7aTeEN/nJ8WYWJ3rZ HfJn3+LP3scyVUIT
MPA2E29XI1yIi9QI79TPbnJiFvc6eccv5hFPjnfjAV19ULB+vok8f01Zadh1 Uo7r2PnYjXa/GkrN
/V4tLy5L+3BWsCZy1q6mLN+Ph0y8Dx9gr8oWm3pZcpD9zufnFUC6OnHGCqmd LjVVuxNn7Q0Er0xp
VVHCZyw7W9ROQ5lRP1i5k6DROjMDw3lWwWzOpjGml4zkVGFdFlk7v7KG8Emc 0Bz+lKDu9FUDj6oG
djrpDnm9mpXx03jMxEmMMcLOFK77fCnaOL3DyzkD4yZOYZVfp33puq2jbPuf QYeuTPq+LzohhM/h
IZ1+nIy5yQnhCazQ7y9QpUEnz85C1Kf8uS9SytyUvkX9WRkT5yTgFj+TfMm4 EaBsrp2jRXeV0uLO
un/TfU4DkebT71ug4f1hOIbwN/hbk8n1lTNkju1tFmNW1on5+8aOOwbsrO+y v6NPpj8paqxkItxF
HXYYQF838Y0pp/sruzPq9G+iQ1f+oTSantGK+Aa+LdgYSZSANluUYuv7joln 8F3GeiZrp32yO729
r2D3QhuPUth0+XTYPdK6B2VO/SO+p3z+iccGf2O5y55x+U77MHe/atEDVp6H qZGSdDmNSYmSLc6X
Uv4z/kWl/IFg2+9Hy8C/cjORnLuu8RKOHPRrjleYGbypYgcm93/Hj4L4N/wH C9NCEAZ+wrrmkJbl
ZtjPlkdmU+oqzpPOT/FfQfwn/pvngfnrBp5jF0lP1b95G0Li/w/+N4if4xeC q0qxwhwV26w84/GX
gqvPCdVrDsSnkr+eW3aPsSMfNfAbFj2va5znS+xkWK/YZXtcRtNRCv3/eKEa v8WLtMvpMds2fPgw
u54IXTLNsdFjGW8MSLlmQYcpZVLpNQe/CIuBE0E8LwFWUivL1GCra1kwHxZm tyUkpgSVaoheczP+
WkhqcUInl7D2LaCIIUu1YOtEKh2SBpWrXpaxyyZt7xym2zbB+XNcvyOXs7xd KHkul/NV6guU/HwA
Qy405SKNjE2luKeHh0krN8e/hqzgeaA6IKuCslKNYwxZ+W5Gk9cND4bkErmU wSNrgviVLtcm7anz
44FjWZr1CjymmBF6mUtzNqC61Z5v4MXSRZqkmekiLYKtpSgzrcY0z/ahjDNg G9KqFw+2d5tCAa9k
9EtM1vmT3uYiJBtwQic3Ut8RBdt7WE/D85Nnof2EXC2buEGQa7hhikYDEmde Fq8lstNNLx6Qrbwt
OMCjevEU2DiYsfON6YzbOGSN2LNAWwOyjfuigZQ2fNmOFWqFHboJsPO087GQ tOsm4BnZqYlOJEbw
gFfxBetKqZFzmgSR/aUSkWc3JkUeLPaSjaUgn17S9fLC6wjbS8JevB6rJJ4F mTzLFwwo5aW1lVVx
oapKg3v4zJySRJlXFJVC0t8jX3NuFKZrI0mUOeupSV7zkpJuLonQAlm8Rbcf s1NPiaZ89WcWqDz1
3VYSk0Wyy1N7xL+mND0DFs8JAWtggOeeNbzPSZzbef1sd5XVPcfS7pDtOgMz XNaF8AnNiTIZnJmk
JXv+QKzn3uWZPZnh3IDd6eiBrWEukVaNLUGoK81jZnvKyuftPFZzQ1rBm+Rq hFGJKjCX+VXG77v0
4o/ju/TaT+f0ak3feifFdxj1s+CX8fu8Wd/n88cTtY71UOlxEL1U5HMlvzo4 L3wvaRpHY5OM4RJ9
rHnUQ7iMz3pPrDV8Roi6FrUcX86ZkI+GKxDhW7jS5JMsu4nsDU7d2tQ8hpbm SbT2jSNWwFWT2NS3
tBzjiO9pahnD1kls62s2xrGjO1rfXsAuhawsH8f18YpouKKAG2YhRFsK2Mtv ktq3p6VyDAcm0dsX
JfSN8cpwZX1fAQfDlQR6WdMkbumLLg0Q7VaqM5vpY7iEEIf45rTVR5UHCxgi wpG+aP1t40hRcy6u
qU8XkNHBJG5XqFwBIx5QXYBA8apwVf0dhAhXTeJOXf8jrpPKK/qaKc8rx/Bq j6lRR6a+rKT1anJ+
Dd9cu1txXlvAnypYVWU5kd64p6XOHMO9LXWDY3grab29r7lyHO8Yw/3EuZ+4 79J3eQHvURqn8MEZ
Dz3o+WMTw+YahsRmOjmORmyhP7biSlzL0TbswHW84tvOK7w29KEdt9LxDjqR xW6M4HpedNyA+wjx
bnTjOG7EGG7C44T8CvLcDLv4PqF+ijfgebxRKvEmMXnRUY97ZTXeI1G8j83x /bIZD0knLwe68UHp
xUfkFlJSyXb70eBHijf6EJYwVi5ik/owllKLJtmIP8NHUM771Uvx58SroHS/ wMP4KLV6htJ9DDVe
UH98OnCblZT+ZgxR5U2cmBWeoky99U9MI97Dr3K+oxoGBTySaC6g8AAaJ3GK wTWxp4Xfn21RKxfw
eRr+Sf7+YobJJQjweZLPx6jFGBOswHQaZ1acIqsJtGDSE6DRZ1IUIEDcL3kC ns/0/Ev8Fcr499f4
clGoLKEr+V5WFKo72txyCl89jsp4xaMQ4i/l39NzcvIJzj7J2afQQIrKs8mb X+bz1JFvaW9Up5Ym
RkjlIDdTj8Gc+RpXKwjztMpRfhvHdbTbU5P4Bq3x98zMZQV8axLP9EXH8Wy8 IlzRVMD3mXIV4coC
fqi5UDGBH5chboSNCfxMEA8cl2A4MIH/E4r4q3h1uPoLeP4BpMLVT+D5uHlS eKtR1tcgFeNSFTYn
pFpQkJqC1BXkPP0O6/fF8eBxtISDPhlZGQ9N4zUqXmhCVs/CI6BcJnjwxaeP 414yIoIyCldPyOUE
8wmvZX//gKZtcXpCopQ7GA5+ibUj6AsfOo6dJO5zjcVrwjUTsl4VORmv1fFV hFlSFCW85JRspjAN
soWChGtnpAkVpTkVDvijF56bql3TRU8N0yDXzql7Zrg6bM4tfOHqBStfuFpL nwrfINcVVH6tfeGq
CeH/DVg8pWMmZE+ihc+v0vlfY/n+OvvBNxme32LJ/jY24DssE8+yPHwPNzDN e/ADHMQPMcqj6N34
EV6HH+Nt+Ak+xfFn8RyD7ed4mqn5XfySs7/Gz/AbHrlekABe1DOKrOAR61oe 1XbhWXmJGNJH9w7y
GJSSoIzyHPRKqZHXS628RerkXTzpvFca5GFiPsJjS4Fnls/R/U/KhRrOlGi5 hiKLShW/OPLDWUdT
4SyTskt2M5wvkI9Ll1zP8G2UD8sNkmA6rZUHZY90E3uD3Cd7ZR8L0Va5h3Lt R4Da/lZ65ACqqW+/
vJQlS6+ON8uNXA1S5xVyk/RBr9Ne641M6nuzHCSVIPXulpcRLkS9r5KbWepq ZBn53UpetbKC1n2Y
oyUyiENyiIWtWkaR8AqbKQ/jIq+wBSn9y8XihqRftdP0o7fES9dKLQOPnFbY IrjcmwERB9C/COK4
2KdXxEdmIR6W5KIc7z+dY2wKkShD3tORI14NrIDFt1ai24vvO4vvu/337wBQ SwMEFAAAAAgAqntw
NGdzhk7kAwAA2wcAAE8AAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIv YmluL29yZy9lY2xp
cHNlL2JpcnQvcmNwL3ZpZXdlci9QYXJhbWV0ZXJWaWV3LmNsYXNzjVRrUxs3 FD3iZcc2JHFJStrw
CgnYBu8m9B0S2mJMcesAxdRpPzFrW5il9q5HK4d+6B/Jz+hMkwztTKf52h/V 6dHaARMKYXZW0pWu
zr3nPvTPv3/8BcDCjwJpX9VtWW24rUDaFVdpW1Vb9jNXHkplbznKaUotVZly BELgdq9627VbDm+Y
0y0uIugXmH5Lo1CSDVnVru8V3UBLT6oIBgX6CqsCyeKB88yxG45Xt0tauV59 SWA453uBdjxddhpt
2fHQ6gJaxkOLHlodD61Wr4dRxASurBS2d3bXN5/kBWZyD0NOWdX2tNuU2cXd +7sP7G3Z8pWeynt1
15NRDAvEt/Nbm7y2Vijy2gSvaRnocCg5zVZDrq5YqqVrMnDrXhTXBGIqBNmg dYHBhlORDYHJYi/5
4FDbh26tLnVgF40CyQ09cj1XLwv0p9JlgYGcX5MJ3MDNGAYwJoAoPkggiegV 9OG2wNUiXdxoNytS
7TiVhjQx86tOo+wo18jdzQG97wYC88VLZ5O+XK8q6WhpMseQa+WTwWzqXAo5 v9nyA1fLJeP5+IVM
I7grMHcZrEK6bPjPxnAPcwm8h1HDPM0y2PGnKnKq5nvSsqwo5gUigdQ78hct cCN1tnIMUBaWAbKZ
UdoxPEs0wrJNpYtv1+Wb06UEHmAxRqsfCYydpxXBJ3SAoFtOnYDT/wP41Fc/ V6RX3aeKQf0Mn8fx
Kb5gsC5SJTSTMerUamc6JczHO/spZP4Yy3E8wpcsMfaE9BikmUuEn3FmULd7 ankoLGxej/Jgza+2
WVfXgjc2c/uMuKwJrKcu4q/00qnjgz2nKrt1GPRQCEvJukhTq3ZVt5U8CU4E 6+yLOp1zVaDzDdkM
2Y6m0j01sVk5oDaT8C2+i6OAIrv6vGistLU2sBvsI/OesY/fwY2vzHFEmKPL UeUzsWc8ZgufdZQP
Sslvq6pcc8MmP9WrllHHNCt0AEwQBnELEb4UdAPgbpxyokceoXy1R77On0+K WZsG4zzIMz46HN+n
9Jj7gnM88wq3MskPX2D8t1B5guMI+jkmMECYGOdJI3XUMUWnwPUdzHSh9gjd x3k28yfu/TTf/wqp
F8hkfkcmufAS9zMv8fERHgpkjvBVH06sJIkPIgxjjG6Ns4cnQks3O2gdS+Hq a6xA8MvB6tpcpo7R
GsrMn/I8Fu5O06M7PVhDHaxwtWqCxC9/HIp5w8f8JzBD4cZcD3FxTHwN33Qv /mqyw/nuwmsUnmNy
4W8UjvBEYCP7GpvPMWJiwH+cUTjGptnB0GgECwxvluRthnIxtJXp4HVshast fE9rZrWNUpjXJHbw
A/q5Ww4xn/4HUEsDBBQAAAAIAKp7cDRQQsemrAIAAIMFAABNAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92aWV3ZXIvUGVy c3BlY3RpdmUuY2xh
c3ONU9tO20AQPZuEOAVzC1AoUCj0gpOATe+UUCilBCGlFIkqD7xtnG1YZOzI cVLxTX3qU5U+9AP6
UVVnbQORAoiXvczOnDNndubvv99/AJjYY1jy/LolbEc2msKqSj+wfLthtaX4 LnzrUPjNhrAD2RYa
GMPIKW9zy+Fu3fpSPaUHDUmGxW6IlrT2u8JK3A48/1xDH0N6Q7oy2GRIGrkK Q2rHqwkdGjL9SKGf
YbgsXXHQOqsK/yuvOoIhW/Zs7lS4L9U9NqaCE9lkyJXvmHmRYcz2BQ/EPtFL 7pT5udcKGOaNck/m
vC6i56JKcfrGd1KeZRisi2C3JknhNhEwjBu58lWJjgJfuvWijnFMDGAM98mh 2R1QkU0ZSTKOcxUd
U3ig/KYZ8kRsxsSm0maSNjPSZrq8Les8kJ5bIUMGs6kt+k2GUV6rHQXcrXHH c4V6IyCjN6Hj/VKv
UfHP45HiX2Dob3Cfn4mAqpjBYwY9KmDJc2rCZyhdg3otaE+BI4S4xDqe4pli XGIo3Kb4Mhslaj2f
QY5h9jZoDQWGIarHocNtcRKnPWFcr3sF5gCWYVFT3TmLDJ4zaMSgLjpeRhCv op5QtosuWzXuUhcV
cVmVN3irqrIWNmCv34XEdfoX6qcdx2sKNRo6NlQDFfGeZs2J6Wdv63H6aNHV vtneTAnpW1y9uRs+
8wrryGv5tihJ1dIjXRNoKlgsIEFzToAAnZgafFrv0c2indHel/+FgZ/hs05r WhnJaZBWPXLAEIZp
J3iMxsE/yC9F+16hg0mGz4VkBzMJFLIPk6ns3HIHi2m6PEmHZ6MPByvZfAer CaxkX3TwOvTs4F0C
FLeZwBX9IlGDCDWiHCK6GfoSg2Z5FRNYwyRKmApTy0f0UWrhaQsflD5at/GR 0AyarB18QpKsuyF+
6T9QSwMEFAAAAAgAqntwNFXXyXrUAwAAzggAAFMAAABvcmcuZWNsaXBzZS5i aXJ0LnJjcC52aWV3
ZXIvYmluL29yZy9lY2xpcHNlL2JpcnQvcmNwL3ZpZXdlci9QcmV2aWV3Qmly dEFjdGlvbi5jbGFz
c6VUbXNSRxQ+myAQxBqx2toXNTaxkGi21b7YxoZKgooSkoKBTvvBuVxWssnl XmbvEppP/Tn97Exr
M/3QH9Af1emz995ABGrS6dxhd9k9+5znPOfs+evvP/4komWqMrrtqTYXtiO7 vuBNqTRXdpfvS9EX
im8pYVYFbD+wtfTcBDFGs7vWvsUdy23zzeausHWCpkeAepKXGp7aawrX3mlI t+X1Q4B14Yi2pUWC
zjCK94MTRnPlEy6vMEop0fWUrlgdwShTHnKoaSXdNiwSTeX1faFG8fy+5tER L4QzrOP3pSv1KqPp
bK7OKLbmtUSaztFbKYrRLKPzZemKSq/TFOqZ1XQCp55tOXVLSfM/2ozpHekz 4uX/pCP8n/OFrh4L
6VJ2PKZcPU0zlJqhKXoXjEMFIAWuFo5inc+eGKyBOUtpA/Mh4m2qPkbVcxkt vH5594VlC24FFHkp
omrUuVDdrjzfrqwXq8+La+XSVq2YpBsmeNUTSZp/rSZqB74WnQTdZHQWRLeU 1xVKHzC6NyHCCTGP
b6UpS7kUfUyLjFbGdG5Z2uJey+I9LR3esVz5Qviar+vuRrQu/tR1PCVUgm6B U1vokutry7Whej6b
K/8PRFBbJp6i2/QJMtgWONDC9SHbkSVq42k29+NxJwG+9jzH57bnugIy70t9 MMHjGBr83aG7xt9n
UH9Hd5wkfcHozlgIYalE9RegSi2FzxuiWQ/2EnQPL6Yl/a5jITePT5WbU1Xa 17SSoq/oPqOLAwBE
Yotu2EFW8ba6gNM1bdl7z5Rl4919a95dnh6gysPyY3Tj5NJkxMzLKY/4ic5m fTSbwHBtB2eihVSc
ot7HLSIZfV6qAXH4KmaMg4jtzdNdizT3fNM6TAMyD/jE7mdkTVDSPOAKnn/N 6ylbPJSm/1we6y3L
Rg2ag22MICdNY4XLaPhTppmY2XQDzEmco+FhPI9/dzEzzGcWf6cLLwOzDMYU ZkI+Y0jsRazSoRG9
TZcwgwC9EwGswtLYxheXfqMrowiruJMPEC6HViFCsHoPNsb5+/TBJKyro1gF YK39C9Y1wxDfdZqL
sH6GBNOYFzIfZRYOaalxSJ++os8bi7/SlcyXGK8e0je/UHLj1isqvAzCu4Yv H7oEuTjGh1DrEeBK
OHkC8DLN02ZA4XoIPqCwAGrrAYEYFXFvyqwHKvdMPk5Bprz0BjJVkKkBbhsn dYB/DzI/HOkxJHNE
wegB8o8jCnn8DGU2lDUeOLKPxcMG8bAwHrNC9E+CeJ4O4lky+5PA9gbVMgRj kG1jUoY3RzPsI8N6
coZNMQcRbQV3vvsHUEsDBBQAAAAIAKp7cDSdp4XHPwIAAIsEAABOAAAAb3Jn LmVjbGlwc2UuYmly
dC5yY3Audmlld2VyL2Jpbi9vcmcvZWNsaXBzZS9iaXJ0L3JjcC92aWV3ZXIv Vmlld2VyUGx1Z2lu
LmNsYXNzpVPbbtNAEJ1NnKQxLqVJKTThlvSC4yJbSLwFVUBLpUoRqijkfeNu 3C2Oba3XbT+Ly0MR
D3wAH4WYXadNWiIBIlI8s7PnnDk7Xv/4+e07ALiwScCOReAxP+RJyrwBF9IT fuKdcHbKhNfXYT/M
Ah5VgBDYmEZn3Ev0lvdykEpBffl+7wJbJFDONwk4vb/t0UXWcx5xuUWgaHf6 BIzt+JBZUIE5Ewww
LShBuQoFsAgs9HjE3mSjARPv6CBkBGq92Kdhnwqu1uOiIY94SqCUSiokgXVb u4nTgHtDQUfsNBYf
vFdZdBiy7TiS7Ex2VWPz9ZnPEsnjCMn1Y3pCvZBGgXdRxjMuWbAINeVrmUDF 12Ts0P5zA3SVyjix
oJHzm9gvYHKHDWkWosQTu/MvM6shd29EA7bDUl/wRMaCwAu7N3F9IAWPgu5V 1eMh9ZknWBpnApNr
CqjbRLQ7RrvKg4se3NzDHLQIrPCrnF0Rj/bHb/3tjP7/6ciCVVhT81rHASZU HuHRf5fEWR5o/i5X
739xeliuQkMLL5CBHwAi1X3CrIQ53jF8VnHVxUgwVp1zuOF8gflPuCjATQD8 F/FZQ3od4UuwgCsr
B8MtLUXUpUB0HXMDV7e15BZWChjLzuY53JnombraQANNrbWco3Itnd2FFW2n MUN1d6xqKtV7ZIbT
Fiq3Ebs6pW5eqpu5Ou7fhwfjw69hVD/jM8x/vFQr62pHqxT0aR/CozHjKVbU bqXWdr7CxnXSs8mQ
cMaPwdZD6miU8wtQSwMEFAAAAAgAqntwNAGQDBSRAAAAOQEAACwAAABvcmcu ZWNsaXBzZS5iaXJ0
LnJjcC52aWV3ZXIvYnVpbGQucHJvcGVydGllc22OsQ4CIRBEexL+gQ9Q7gss LDSx0MpYmZg7bkUM
B5tdUD9fErVQd4st5k1mhnMlB5YAM5VDgDuQvfZkFobJdVrlWrAWiQ8hNd6+ DcnFOgI3EWP1TXlM
cXbUynzfb4hgCS4n7v7BJxgpI1AJwIKnwbG6core+nAWDIyx54sdJhTgdrVf zje7tdRODm+v2e8O
rZ5QSwMECgAAAAAAqntwNAAAAAAAAAAAAAAAACIAAABvcmcuZWNsaXBzZS5i aXJ0LnJjcC52aWV3
ZXIvaWNvbnMvUEsDBAoAAAAAAKp7cDS83AluzgAAAM4AAAAsAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL2ljb25zL2Jvb2suMi5naWZHSUY4N2EgACAAoQAAAAAA/v7+ AP7+AAAALAAAAAAg
ACAAAAKnhI+pi+EPo5y02oszbpVbA4GR6JAjQKGPKpmGwLZlB6MADK9B7O4r /rrZRiVVzCesAXU8
nq8ETA5DxRlVKmWGnCzs8mg0Er1C7Yr7E2bB1Sczupw1r2llmb0TX+Fl+ZYO pfZFlGf1JtiH9Ge2
w5eDJ8JGltNxNOJouZiCeXbQllAX9HgjUDraaFrTiKhUilATdGAqGpvKYxti q7bQ4nmioBEsPEws
XAAAO1BLAwQKAAAAAACqe3A0HiSsnN4AAADeAAAALAAAAG9yZy5lY2xpcHNl LmJpcnQucmNwLnZp
ZXdlci9pY29ucy9tc3RvY2suZ2lmR0lGODdhIAAgAMIAAAAAAP7+/gD+/gAA /v4AAAAAAAAAAAAA
ACwAAAAAIAAgAAADqwi63P4syEmrvRXqvSTAYBh8o2hm3qkOJKmGA5u+WDyU OE3ZAUG0usqtRxAA
g5KYpGj0CATIoQ8KhIaeWOxtOiNZL08LlkA5BsKVsO2m9JVnkmw2oKS3ye/c xeeu9PMuFn1/RBdm
O313fBiHST5sQyeNhTwvjYQ6LTaLSCNmeEgfCimYliWjI6UhLqMRepItrR05 gXCnsQ4eoqyeuLIP
uhHAHK7Exg3Bx8YBCQA7UEsDBBQAAAAIAKp7cDRpsdAY+wAAADoBAAAwAAAA b3JnLmVjbGlwc2Uu
YmlydC5yY3Audmlld2VyL2ljb25zL3JlZC1idWxsZXQuZ2lmrY8xS8NAAEa/ QJAQqtxSuAaEXKrW
QAZvaxCk3lDxphoEJZMSty5KFyGL0AwdQqaMHSrS0dGxBJc4mTE4uTpWcHI6 yX/wG95763dyOuz7
1yZMLIGiKMo4rcS4IrKK4hpCIVCQa4gSfhnnFXxFQsVjZQRfEHO4Kq3Vcq1I sIKfw00IVyyqDZHA
DUE/IV7AI9AV+DN4CCZBJ4RPmiBzGVVRMgZLucR/jP3qWmOvQfMJGxcD2DZt 6Rp7GB3QrZmuLS4p
3XzramdGK5vdBItzbzp9unsd2Z33q58Pr/+dDQeP90e3NnPMNml3uts7bBd7 vZ7F8n1pOpblZDjG
4R9QSwMEFAAAAAgAqntwNKsp9yn/AQAAUwIAADgAAABvcmcuZWNsaXBzZS5i aXJ0LnJjcC52aWV3
ZXIvaWNvbnMvcmVwb3J0X3BlcnNwZWN0aXZlLmdpZsXR7U8ScQDA8R9yLEIi U8yHKWVbD2490IML
M5WoQMxVQ+B6mxsdvm8t4XcX3EHFQeYGC1avmr2KN4z1ytnWW1qbphcsTJI4 iJNos3kajzX7J/q8
+77+6vRaVf/tJtAEcijwhJy5jbL97o1U8TcdooBnIc2xbIFbynz8yVeKndrI 9NDn3Apfri1mt9h1
ji3k55bm6KAz+RbGvvGr+TW+VIvnt+Pcdt+LW/Fsgg4536f5zXIt9aMU9qo9 AUeqWKrWqziB2QnL
p+hk7lf5+0bFF6SSuRUbgUFowSHmd4wwmeWAQ+eDo+6pMTuBvfaqY2meYZch blnIbtEBgmEZ+jmV
YBNMdNJ9f8z91EaHXEzUGktv+qAeEtbZx5fXOLZSrUemh1fzX73PyEqtDnHM ht/JruftOEbg1jib
gBADpuCDe9fpIPlmZvDPP+A/6SkhAgBQcHwndp6AXREHSlIu90PU5KFNj0iT ecZ80dT4RDdq0Bpa
DjdeIY2us/v3vOpuUR8gwUvy1G6DIRI9QQ6LEVIjmJ8/clQZFoub0UFhj0Ik /HA63Nd/Ehlvk7SJ
2jvax0mk88LATeM+yXmRrEP2BW3u1auk0sy5S3J5VwG0Hjw01DpiRMRypaVb IjyjVfZOvFOHNUDR
pVpEGlzCvQpZUq1x+49dM0unJqirs36qQQAG/gJQSwMEFAAAAAgAqntwNJDb 86COAgAA1wMAACwA
AABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvaWNvbnMvc2FtcGxlLmdp Zu3TW09SAQDA8cPK
RrOYueqhWaKtZpsPWm3m/S4HJDqIKSAqF+clr4iKHFFPgcbFDNtURCTCy9Rp smVOmg+JztuoXGbN
YTOJW4lTl9lsGs1P0Uu/t/8H+OPwSbdCWV6AF/ALABKjYk36jwe77hXNwbtX q3sOt0FkXhiwO60u
MIb8fsFcmNAlyNA8rTX1Ns0NaAyy4vGxNgecqxrueAMXKaghLYk3ORV0DRRd TIrjDCqWs3FN/apJ
X08COboqBZcPF6rIIMcwtOSwbtJwIjrhPpUgmNUfTo+vZRJlSPHoUPdUn06f eF2YHMEHw8opCQiL
3EK9Db98Pk/FyxlERQapAeGOxIXTzJ++ESKFaaCMTmy2WXbAsEZyvKKALeOV yOmk1ixKFwNqz6ao
aZCEkSquKpdr1WNvTSsOu4tDe7a8ZLFZNyBQzqLqMtOUd0ntOZkjHMYwO6Of SdflMftysl6kpag4
zN6CvMGe3j2LZcticabTRkq5EziirrTazBN+pmf3cCsHqhu24Ic7/Aeuynpn Zb29ou4rr3adL7Kp
dK4nykV8ilIg2eU3btdIf8KSH3zxJl/8nStclrTu10nXSqqNko5DZd9hcKQw na222Tfcbjfw37/j
t38cBQAIEHgUR08A6FEAddIH1GsnRegaIqLXGj0wlzF2LBNrfOQbRQchSJ8M xHjMvZ73t0kxXmg0
fBaaeXw+IF7sKttBtBIU83eRwdiDPnMpKODUtCjvjk8oz6kOpsySOiMEJ+59 8bZ7tl1LHaRK2dY5
KES4KMF3557uDObvTghulM2gzl3M/wCy4pPQQCD6TyzXv9HD+wpRCCI5+Mmr AReCthG/Y81YAgam
rTOnPLF4NXbVJODFAED4X1BLAwQUAAAACACqe3A0wAXQIY8iAADliQAALQAA AG9yZy5lY2xpcHNl
LmJpcnQucmNwLnZpZXdlci9pY29ucy9zYW1wbGUuaWNuc+18aVAbV9put3Qy /lz3pjLfv/mRW56q
z1VfZapS9sQ2sY1jvBtjGwxGC1pACCQkgZAwi1gMnO6WrA0ZhFgksS8GI/bF mM0GG2y8xMbxQrxk
Yiee1Hz31+Tn/Ejd3Lcb8BZvGdtJZkpH9PK8z3POe/r0OWqd7rfRJqVnEoT9 O21S5n8RBBFOQOJP
LXzCflj4LGGWexWvzVzzCUGQW1sIKsFO8BMePGA3srt35bAR370rthB8Qawg lrpGxVIEcYA5h86f
P3cuCvYjcDe/q7u7C3cTEQB34J38xqbGRmonZNlSVbUFCtjkcoXCZr3Ltd5O UOtaCHDTB4a+775j
N13ffNsFm/Zvvm23EEQzbqLuUU0Uscw/P3/rFvzhecJPEe95ZmfPz56nZwkP RfCdzpISaopfAhvw
YxkdtUAJRUNDRbDJHxrKAz85nJ8CMBSo1ewmT6XKg022SpUNeTKMGRlUEpVB Eb9LUygS4Y9SEGkU
wdNIpVhCsisiBTwpk5RKSsxXKpOSIFe8QBgPZUhiD0pgI4o9KAJPsS1E5np9 KjTgfxCvlX6E9M/i
H59I/wwmfqa/R/i10p7tkf/13Hb44PuXLh/8+OP3L1telf+V6Rf2r01jB9R7 /+d/CFIQzcSQ0QIP
QURb4oloD7E8Jl6pNxr1yvgYDujPzM2d0S8Cw9z9+3OGBSBNu3zv3mW9bBFc unv30iIQaligEcY4
ofxwJmK5UJ1z6c6dSzlqIRNBhgsY4j/DY2MPHoRFOTg998UXc9ODSvNBIpwh lkfEihTQmZWGM8xV
8oyBUvIVgugIhuBHRMo6qZPk6Dlq9n9dmD0/dnLk5MlOWSRLbY2MH7Sdpabx Wf5gfORW1rJH3EL1
Le/t61v8o/r4LaJwjtodW0k18poCnVQXrzPQRDXyK2N3s8yGHbsPUDFIVt3U DMOcrJZRMfwD4Ts3
MAQvZPt2esfyKHtlfUN9XaU9yryDCGHg4EKYDcu37BUe9XqPCvduYTaQIQIn sfzPmyMclZWOiM1/
9gDYtNt89Kh5VygHQncxLhezcyMHQraxYFsICz4K2ZpL07lbQz5iwbr1m7ds 2bx+HQBy5TpmLblu
ZQVBfMx8RHz8fwk4a4FupovsDsBZa7H0EC0egtfV00cN8/p6uiB7V8+Ju/fv 3z3Bgdae4a+/++7r
4Z5WFnQO3f3m23tDnRzoGGDBQAcH2npZ0NvW6oTi/Uzt8tauE3cefHP3RFcr U0v6A9AK7qZGumF5
++e37n311b1bn7czDWSjG+y1DU10O9lzg7lL3uih23mN9bUM8b8rfM0Xr12b u3bt1vyXX1Lz9DX+
xWZfBbRzRXXjFXyTukHehBV9k3+lsZo1O8trzuKL7124cPHihQtHLvLP1pQ7 oRhnmXdsampyagq+
Xs9Ts/QUf8xbBgRiHC53OfaQvjFmavmYz1Ne7ik/WsIwBFFM2bGDV94/Qk2+ N9Jf7rADJJ3FDBxY
McMst5R4hsbGhjwlFoYhiwNwwgpoZ//ISL+TLoCWyCw60nPiRM+RokwWFFq6 h4a6LYUcyKVYgE0c
MBW3dXW1FeWwQJeTW1hUVJibo4NTordkE3o4cQI9oyP1gv9hT5ggh8kkcwRg 1eczeWQ+8LzMvAIq
l1eQx5WWl5eq1abmLYJcrVqtzV0AphyNSqXJWXCak82C7AWn2VkpKlVKVrbO ueBsOVw0WEtGhpHz
DI2UbDCkp2MDL12lopJ4KlW62UAkg12XbjCAnUxPZpLI5HTKwDca0nVwFpRp aUlYSSYlUQp+Ilx3
aCU/KS1NyRAfKFN1iQkJikd/TAI/UatVsnnU6ngsY6SUjJby5Wo1a5Oo1XIs gwsVJTki5cvUagl4
lSTC5Qonkoo4RkzGKXAiggtXIstEJyoS4RK3TCQSc38UkKQymh1jUrNkmVwu EorEcrkZLn3sCIuR
y4UCoUgu575vxHGC2IOxcWIOiMQsEIsWvolELBAJWRAhFLFfOiJhBJyFiINM LHkQ9ohwC3zxeBa+
qMhwOFtp3MUSvebF8q0k/ocruPQh//n8hzMPuDTz4fP5FQ9+5NKDFf9a/NJx hz5c4B+GLrXD08f9
8IcF/oeHS+3wqNxn0pKffw3+xcf3eu1DvGH7/1b4x/37nxsf7yRpkzTwY5EX TrxWCvvhTdfF/w8O
lG2lqTdfs6W92uPrrN9Weh1f/57to9WwP7b/4+iPxA9wlZFY40iJoIEgJXJr PCmXwF5cvDWBjI9r
IFBcfILGRGFk0iQsYVM7NYnaTY8wnqQeoEn8CBefpr5Gp4sXsUR2eIL6Ck0U yqWLuGCcuovGDy9g
gURaMMbiApmEw6K4PBaP5cWJBCwWinM5nCsWwm8VuwCpDuWUTlK30WRpziGV XWAlsOD9GMHix1g3
MHaJuo4ujQ3UGa0xpCDCSlACHIsF/NjYzH7rNbI/0xpLxkC23wliYqVaoxFn 8I1G67D1CjlsNRuR
RhITvc9KoH1R0SkecwfZP2W58N7Fi2cGAgG6A3lSoqM4NvKA/vjRc8x5+hxq 10dFhoMtfH+krsU1
SU5NUlPk5BQ0Uosucj/HROxT+S2DeICBxTKIfKq9ETvAvmNPRFKFpRt3MbBY ulFFUsQezr57j5Qy
e/i+lo4OJsDv6GjxmT2Iku7ZzbJbtu/cG2dOWGYsb2llP1QLWW40J6C4fbt2 brHCTYRtO3ZYdvJl
9sZG3EQ3knaZdSe5HRi0cfu27dvM298X59lcvvr6ujqvy5Yntm0nwqwEuSPM ugVFCsQaO+VDdo1Y
EGndQobt8BBo0+YtAoqqQpRgy+ZNcE7Wbw4TFFEVqCh282frWRz6WXQBVYoK oj8L5fDGTQfyKBfK
PRC6cS3gtRtDD+Q+iT/dEMnh/etDOByyfv+TeHXIp7tTKBNK2f1pyGoWrwsJ 3UXtRbtCQ9YBJlev
sa4j18Aescq+hlgFljWrrKvJVWvY/sz16fGAtYcMjIMiYO8mAqDo6bb2kd09 UFpPd9/gGHUKjQ32
LeGxq9Cfro49wqduU9+h26cWcKC799Q89Vc0f6q3G0p6P9DZPXbr228fPpwf 6+7kDIGu0ZvffPPt
t7dGuwJgwIFlIzdYfHMEc3x7x8kFfLKjnTU0tbUPX2cNN4bb25o87OTGWvd+ oH/o9K37D+4/uDU5
1B+w1sEEB06mH24NWRpQ9/TV63eov6A7169Od9saCD9QdY3NzZYmsveK9R55 pdfaRDbUwTmuq29s
6TT3kKNz1rvk3Ki5BwVaGup9wPj8te2naXY6c/nG/Dz+kp4nb3xuvohOt9f6 Wb7S6++YpeeZWxgW
yzya7fB7K1l7lbdthr7OfIFhsVxHM23eKtbu9lQ2n6Yv40sYFudldLq50uMG u6vc0zhGz+LzGBbn
LBpr9JS7YLy5St01PSMjePS9kZHx6fPn8Tn6PH96YnQUj/xudLS3trzMBbnt TldZtdlPtp60niFP
tpr9qLrM5bRDB7U4KCdZ4qRKSN+gdWrZoK/ECR8WO4AmzDYHqmrvHxqnTqPx of72KpuDMEM2m5m2
0HZU5q6oG6DGfzdQV+Eug+kX2EiHDXo3xVjKu6hR1FVuYSg434U04w5QIyjg ZuhCFhdh13HqBDru
wkUszjtcVNJGDaG2kqLDeSwuKHRy2FlYwOLs/ALHMcDH7Pm52SzOzbdz2JZn 4rApz+yjWpGPyc1h
cUaOqYCmjiC6wJSTAT01I8uaQ2bBHmGwZxEGsJgM1gzSYHrUu01Z1mwyywSK LHs+kQWK7HxrAZmf
veA930TlIBNsF7HJQKUig+kRzkml1Cg156d4sXZZOkqFdFlcbX+Kc3IzOZy5 WPusnENawNpDOVkZ
LM7MzuBwRnZmhgfqqrPqUXq6UZ9CJaMUvTE93aondSY4XzpswOm0Aek1mhQV kKoUjUZvMxA66Np6
Q0YGNtIZpD7FmkSm6Nnj10MX0qcbDfq0NBqKUAOh1pmhcIMxHTikTdWnqulk vkqVnEjDXI0PdyiT
zMlIDXYty+vStEkswcBiU6AkbZqOtat0qZpEOh4nMLDY4lFiik6jYu0pWrWC lh+RMXKLDCWotSmc
Va1JTqClRySM1CJB8uQUdSJYE5PVYJXzZTKplJbQUlImNctQPFiB/V2iMjlJ mQiVIuMlVjEpiacV
v0tMVCYlK4HlyxUwAU2ilaSCI2F6SyeRSjkwEpjsYiWtQPFxcWIxJUJicVwc ZAZtkgR6tlpilb8v
lcmlYqFQJIqTymVSq5yUqD3E+3GyeJlIIBAKxbDDXleBlYooARJJH113JQIq dmEL30kCsYSbsh6E
HTFnEMWJOQPsiDiDUCziDLAjXDCI2OkrfIQi1sBnDUwsX8QhUhBDxS47yPEx CxguvNxehIC7MjcQ
TgHbnzXc7Hb5Lzm7/W2mD1aHPUqrPyBemVaXTT1KZauJV6awqR8fpakw4pUp qP/t65/sM4a5x/o5
w7N96ad9Zu77x/rv557pS4/r8Mo0FRbU/6vqf25/+Ln97ef256D+X1f/c69H P/d692+etFnsXZmP
NrD7P77wUwa/3VYKBNHeGBQtiFopuE2glYIYidQbh6QSkWAlYEFMnEzulSH4 PRgDPF8gkcn98Xy5
TAKIFy2V18bz5NJoUIIwPt6bgOLj5XExr4txAlIma1L1NiPSp6YkK/FP+WSN 0VRgwwjmHprk5/Aa
Iy6ttjWi6tJio+Y5fKqptH3QNokG20tNqc/h9QXVg2dsc+jMYHWB/jm8ETdO ztkeoLnJBmx8B7yh
uAH4+yxfbHg+f/qq7Wt09XT9s7xMjuNRelHdqSu2v6Arp+qL0gHDmVrkJRIp lqG0w7UTn9u+Qp9P
1BbqsRzJpM/wBTUTl2330OWJ2sMv4Mcv2e6iS+M1vyzPTiOwFKUW1Iwt8gVp oJdK4lgefv5jMZYg
Xb5/gR7zF6SCPA7mHlx2dgaB45A2b4n35WlxHBaRgsXcQixGmlzfEpurASwU Ct4xPbIw5sK9EUgo
V6rUOAXlmBsnLtnuoEsTjeYcwGpVklwIfLggbKXAy47JCBijAiRXpR/KxDmI KW2fvGy7jS5Ptpcy
gDMP6VVy4GEMC1aCHuTcmFboC+1HcQWqbR06d8V2C105d6K1FvBRe6FesTDm I6B8iwDDFApWWEDG
wGoRIaXRXteGB9Dw2NlLV23X0dVLZ8eGAbfVWY1KL6uOCPMS/PD90QJzrOWg JZY+iJQZJW2D+Aya
PnfxypztCzR35eK5acCDba4Mpe8gXxC9PxxqGAH3V2MZgSXWIqBjUXJmef+U 9xqa6i/PTPbGooMx
0YKId6HCMGcVy+DZrtICk2RkKPQOnvFehZHvLTSUKZEiHr708EEUDXdtF/PE HMSxSCxVatMYoyWD
NqICa/3wWe8VdHa4wVpQZkRpmkSJEBrrQHTUQp59B2KioQyJ0lhoYUosLroE VdR0jp/1XKIvo+mJ
rtpKxuUoQZbCdIUYR+MocjFbZFQUjkaylEJPfVkH6u4fnZrxXKAvonNnxgZ6 6ICzA9V7ClNkj7KQ
EftwJD6AZFqmvrPsJBodn5w+VzaLL5CzsELnZ6YmxvAIPkmOjNhOos56s1YG 6sjI/U9mjtc7jp8M
nHOdd55Dw+0OfTyOYiXhW9+WBG0N3xcZCTg+zX5ssPOsa9pxFg0es6U9o9m/ H0cime5IS//xSQx3
vCdtUxjufk/B93Z/i1UnA3b//r2L6oi9+/B+JNXAgV8YhUNjNFLA+/Y+4iP2 4n0oTlXsb/MMWgZc
sJQPojZfsUqM96I9cF+c0+0Ij9gDWKwqqmop68O9ZB+scB/Z22t7CpX1oZaq wmQRhhG5Z/dS3j3h
gIVJBRVNnm5LlwuW8m7UVHE4SfhOdbt278Z7UGxCtqOyrBE1NR/rCFCdvK6u TgeE+3R2UZ0o0NHW
3ARcpSMrIRbvwbvJp7LGSNMpR5kHVfnqW9roDleA6UBtLfW+KrA5qHRpzOMs G7bs2LUL70aRsYq0
Q2V5qMhcVtPEtLna6TbUVFNqLgLboTRFbCRodsHzgg1cnm3bIQwRhe+F61MZ e3Wmyv1UC6+1tYVu
5bW0tNpbkL+cMmqAk8Ud3LcH70I7d25/Ku/u8H1RB8ogVEmd56qmmyzNziZU 7cpXy8B2IGrfnvCn
82zbzuwo34miZZn2CqbR0uRoRBX2Q7Jo7060Y/tbV/FDwrbBc4/yHShKko7t 8HVaWeWrq2ca6HpU
V+urqgSLHeslUTU7yLAQ0K/bGLad3sbbvn2bezuKEuvyirENOVweXy1dz9Sh Gq/H5QBLcZ5WHOXd
Dm62ha2Dyqz6FPwwW8u3o0hhYkoqNqLsgiPuaqqWV1NTS9WgKveR/GywpqYk CCPZfDu3f7qKvVjs
2BAW5t2C9kQKBOxFSKHJtbttPuS252kU7EVIEB25x7sFh5E7uGvFyh3rQrwb 0JZde7hRI0w4ZDlq
86KjlkMJQsB7I/bs2gJ8yLpVKwUjBLlhE96Mt8BXYypVYqtCJVSqIALw5s2f bdpw+w1p9Of1mzZv
xmHA64odtkrkKNYBH8by6//8NF9kt0E7F2lj9+DN6LPPQpf4zz4DvOdgyuEj Njc6cjglJhx/hjaF
LvEbQzcB3h2tLrDYSpGlQB29+/l8vtl2FJnzVQd24U0odOOGJX5jKOBdB5Lz GJsLMbnJB3biULRx
44a1vwi/FgSAdx5Izn0Bv2E93oh2RCUt8VE7AK/f8OkiH/Lpp3gD2h65xCft 34bXo5CQdSxP/nkt
DgG4bb/yF6fRR6vXhoTgT9HWCLkh10ajXIMsYitg4Fd/9AQftluUYrCZkCFF tDvsaX7dOhyCNm3d
K5TaEpFUuG/rJsDr1q15it8QumVXuG0vCt+1NXTDT3loq9DPNtugT34WumH9 U/wna9Z616G1a14P
r/z4k3XrvGsh/9qPV8JU6U+rPqldw/tk1Z+AW/Hfq9at9a5Ba9et+e8Vdwj+ mo9WfeJdzf9k1ao1
9wjemj997P2I9/GfVvxIvPjjfvm0LuAeD3R7uxA8ZXQHwKN7vAtwD+D2cTfg 8a6eLg53dXaNA4bn
jt093m54YAmPHaG2Lce7a3t43cdbgOvq6QGuD7junq7XxVQfr3/whGOYd2Kw n3qGw32of3B4bMJ2
Ck2MnRzsxz/lB4dPzczaLqHZmVPDg8/hT4zNXL0BP4FvXJ0ZO/E8fnz25l2Y VN29eWH8efzwqUu3
79u+Q/dvXz41/Bb5VrYdcS/Lf/k18F9/eQn4XpYPtD7Nz//F9lf0l/mLz/Jd 3bgH6n9h/ivqIe+v
f31IcaqJE5g7W4uqQGcn7kZDYxdu3WO+pR+ir+YvjA3hbtxJPiOAZqC/Yb5F 927NPiEgWqkA7kKD
o+cf06ODYAkEOt4GDxU4HujAnWhg9PyNRcXN86MDYOl4QnEcB1D/yLnHipF+ sBwPtC8q2trbcQfq
O/lYce5kH+7A7eRrCcjWAG7Dx1Hv8MxjfrgXLG1tx7gSapta29pwO6u4fodT 3L0xA4p2VtFU+zYU
I+xgDFT4vbVQ386uLu7kzt64wzygv1nonmDpYk8sKPwVpe6AF4ZroNbv99ZB jp7+ATyERk9fvHUX
38cPyPuwQndvXZocA/NAf0+gFWR+f3XADdkCtXUNDUxjeT061jk0fgrmXTMX rn15D24e3Pty7sIM
4FPjJzqPedlfKjW14Ihf4W9oYho9Daite2z6Ar6Krl2/dece3E24d2f++jXA F6ZHuttqGkh/BVst
f0NjE83K23vGz3+Ob6Jb87fv3oObC/fu3p6/Bfjz8+M97d4G1NjQ4IcakbV1 uJFu9jSh472nr9z0
3kM3r5zuPe5twg1kXe2b86i2rr6hgWriNbe2udtRz9CZKze8d9GNK1NDPe52 XlsrxL8jCE5ZKqse
w2/mlvbO7rIeNDQ6M3cTxDfnZkaHAHcF2lqgXFbuYw+2wlfL5kDNbd1DI/YJ 3vj4BDWOJqcvXbvJ
3LbccdxGN7+4ND1VNoFGhrrbmjHXqGxOssKH/bgWNbcPnJ52XqQvoIuX527c YuYtXzrm0a0bc59f
KruIpk8PtjeDyu/3LbiDkAkfrkHNHcNnL9qu4TnyGqzQtS9u3OSyOud5t258 4b6GLp490dEMQp/f
V8l5q8Re7EdNHSOzc4551y0LLJ55NDc70tEEdq+3+u3LoLZV1dXYhxqPnzx3 xX6Td+PGTccN3s2b
N+gn9t034ZbD8PFG7MPV5FLpVdiLGtpOzFx2XHd9YYHFcx1dnjnR1gD2qqpK rnSnu4JVorrWganZ
C1fR7NRAax3gygqP28nx5R4PrkS1zX2nZ5yXLZcssDRfRjOn+5prcSVEzbMy 0unG5fBrvKapZ+Ks
86LlggWW5ovo7ERvUw3Yy8vdC6W5ysrd2IN8jd1jZ5yzlvMWWJpn0Zmx7kYf 2N3lbtc70JFOFy7D
5chb3zE0tjDdhRWaOjN97jwDOZyzvPMzZ9xTaGyoo94LwrKy0sXyj5aWYjeq qjnWM8iMWEbpkYXZ
P33ecs55Hp2bnpwYY0YtI/QoGuptq61+Ii9jLzl6FJciT1Vt8zG6w8LO/rr6 Tp46Q83wpqdn6Gne
zMy0fQadOXWyv5sOWCBkDLW31lV5cBk6etS1WIbDWYJdqLSsotpb5kcNrd0n J7xn0MTJntYGwN5q
T1kp8CVOp52B42Tg/QRcglwQs+Nmyh3QMA2BoTEvd2ANPsZjKac9cDLKjh5d ysQ6sdjgxQYnr6TE
aS9BHl/b4CjkGB1s83moEh68gUYvcQ6H/ZfKwS+GwKASu8OByr0tnf3UCG90 /LRjknd6YhSCfPo7
m7zljMPC8k6nw1zsJXjFZqvfgcqqGts7cT8aGBoZP2U7Dd/CJ4cGAHe2N1SV 1ThIVgr3ea0OhxeC
izwwncTN6FhH74lR2wQaPdHbcQxwfZ3XUwa8w2EtNoBeb2PMZqfFYUclZW43 29F9de0Dw7ZxNDxw
vM7HdnB3WVkJY7ewGpvDatOzlwi9rbjYyyCL3cmdRI+3tXfINgYdpcXrWWx/ i5fBxaQ+AJeuAopm
zNiCSsobugZso2igq6G8BLCZYaiC22/MkwUUprEZBnR9Z7+NbcJ6txMwTVML 2QsxTWEGOdz1AY4P
1LkdgCmaKmSzA48xjWyltUCfZOlSG2CMi5foIozREZf/eK/tBOo9XuM6Ahhe ZWFplAnhV0W4mOXb
e4DvafcDX8zyeZkL/GEoAVlKfG3dtiHU3eYrsQAuPFzwC/H5BYdxITI7l3iv 0wz4cAHHk5l5OB8f
hjeFvAv0sWoHjQtQXn5eNpcdosXyANMO77FF3k7hfJSba8rmsmfjXICUvXqR rrJhnIdN5LtloV45
JhPOQ8VHPA1tti7U1lBuKcK5KCcn+ym+yFzqa7C1ogbfUaZwgV8qPQdgQfGR o+Vwk6D8qLW44Ins
Oggjy8EmiKUrps22I8hMFxWAb5bP0D3B5+YVHC60sa2dn5f7NJ+V7c1B2VmZ r4P5esD+bH5WVoYe
Jk46w6G6LNLAChNSDFlZ3kyUlZWZkgDCcJPO4M/gGwymcPbBGkC9V4f0uoRw wctmeqUvm+lx5WTl
gJecLEM4+wAv3JQJOBsw54dvysw2+XP5JlOmia1elqkun8xiq6fPyc3L9+Yh OPoc/VJ38S52n9fF
dAGRX5JLwPYn3S4/P89kskH0oCk3Px8/h8/LyTxky0CHMnPynsfnmTINelsq 0hsyTXnP5Q/pU21a
lKo/9Fw+NycjVWtTQyyfMSf3t8MvDQ5TtkGnsamQRmfMNj0alY97f07WEm/I yuEGz69NLw287Mz0
JRYs3MB7DXpp3LG8NgX4FG068M+MO3ialXVIv8QfysLcOHtN/lBmFs5GmRlL vD4jE3BW5lvgRx4P
WKPBeCgDZ6IMY5qG02nSjBw+dMhgXBrQXm6463x6wkClw13adL0uRW2DANIU nR4wlU4YfHq+LsXE
Pg2DctP03nSUpk9LTcVpKFWnUatADPGhOg6nAgM80DoT6BN0aQYjY7CkOw18 fapGjTUoJUWt4rKo
1CkpWMNXa7R6nwHqatAlQF2SNXqjGTI44FVJvZZR4WRHEk5mVDytPt3Hvhyp SYZyoWoGA5NhMToy
kAEqrPImIRVU2ODNgHcp9bq3JSF1egyNQBsYqBBKT9Oqk0GTrNampZcZsJE0 wArifPVPaJHBAJhJ
c+hRmk6zqNfo0sr0JPsC6GM9UkIp8MInD4o1axxapElRJyd5lSgpGYKC3Vqe Lg1YVq1VcmpdahqG
QlO1apWTbZHkpMQShQUCe3kQVevmTsKiIvXpHBDZm+RUmpMIpQv0ZgWRWA5e 4EifUXOnEIpPSnSC
jtX6FSgxSa1dONXad6pjK5loS8AKMgFWOIFUKJ5GEJCRqFRptDgVgpq1KjYv QB2HNapEhTPekuCC
xR+PFInJKRqsQxBjzepIpQpzMCVJkeCQW+JdsNTIUYIiSZ2CtTiFXCiN65Fa lKIGmVNeKXPJyyGc
OUG5KFoqiu3FapUyId4u40mlsnIpDwKgHdy+W4rkCcpkTqFWPZUhOTFB7pRW SlzScgmSyhUgSmFF
iZK3KUISCMoGzFYwXr5QQbPUJWmWIll84rPKZCgRqaC8eKeckWFpicTJHYwb omhAvcAmLajZyG2s
QmxMt8KZwLCxNBJnXImEB6HY7nhoy8RF/pFemUQl8+A9Y3OiQ4ES4uFNJ6+Y fRMqPsGpYBJ5yiTg
ERS3oIeA8EQmyax0JiJFgnxJm6BwJB6B0HA49YlythEkcsw9FHcoUaJiUQZ5 E51KxzsQoWhpQiKM
MAv0YH68VCzCYgjLEIttsEOKYMUXiaXxJQoH+wJ1ojSafUwlWcih5HLEiXEc DXIatnxxnAy0TniR
WymB711elEhqToCiIVIGQmEkEBIikcRBMLmQ5oLeJZxFKpXHOxJKEvnKBFEU lB+ulkDYk5wlZDIu
CEUiXsgCOaScRQanBhQQGKUOZ2sUrhZI/RKeTC7ngm4e6+HUYTiRcpkfOpIg KlwwshCss6CLEwlp
ASOEQAQJWJbCdX45xeLRSEFhEyChCKr7nKAc9vCFDARUsC/NLVringrLkUBo v8AGvEAkkSzF3TwO
y4mDQH94J4AH/waDOohiBSJxHFjFYtGvIFqKBQL8lAqsYi4i6LVFS5E98FrC 0xqhaCG+5+2K4EFn
rBA6FSFkOAV9kAcKSsTxEb8kXxJLCOin7AIBLSQEnF0IneAg2BcjZuyPyoo9 SHEROI857z+NuTgj
/0IEEbBhEVECwWIQEpBhu6ME/mi+IGo3oIWAqaWAqNuLAVeLAVWvmGtlcS+Q bAm+QBJMwRRMwRRM
v/3EX/bBHz5c8eL04R9+v+xd/m+RZR+sWL0+7MVp/eo/frCMeHfpgxVhCmPx i5NRsWXFu3wn5A+r
FWXHp16cjpcpVv+BeHfpw/XG4zMPXpxmjhvXf0i8u7QirHjqwY8vTg+mcNgK 4t2loP+g/6D/oP+g
/6D/oP+g/6D/oP+g/6D/fxf/r5rfh4pKZx++xP/D2VJR6BvcH3jV/F5kaJj7 20v8/22uwSB6g/sD
r5rflzZM3v/7S/z//f5kQ+kb3B941fx+du7+9/94if9/fP9gbvYN7g+8an7/ 8G9//8cPL/H/wz++
/9vDN7g/sNC/313ixkfQf9B/0H/Qf9B/0H/Qf9B/0H/Qf9B/0H/Q/68+//u1 57+//+MWhRG/OMH8
/8H3L/H//YOphtKX5If5/x9//xu+//Fr3/8hfuX7X0TQf9B/0H/Qf9B/0H/Q f9B/0H/Qf9B/0H/Q
/2vdH5h5x/Hff/iV49+5+wNvML9/07TsV37/gf8rv/8RTMEUTMEUTMH0b5L+ P1BLAwQUAAAACACq
e3A0NBICFCkBAAA+AQAALQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdl ci9pY29ucy9zYW1w
bGUyLmdpZqWPTUvCYACAX8uP2sH0kqUdCoIiPQXBwoosV3OXhLZc7/rYNKuD Bw0KLPBUJ5UImQch
2EbRZYMOXqTLLm6dIoh5WJc+L/2CPC39DT2HB57jsxpbQWc5D/AAA4CZExI9 TaD5RLgA5wpw8WIn
WkxipRTWcTGFlZJE5YCoHK7VMvFahhRzlJgjxSx9d0xJuS05v3t/ti3ny/X1 cp2sNqhqY0NQaVGl
ZR3KOqPoUNGgojPNFqu12KbBakbH3PNryvxIm+/pt+99y7LAPxhr220ABEGo G90n4GRUPouH/Jc4
l96MuYNT1EtDuokP/hBH/OiE9/EzujD/NCAtj09fmbfeh8je+ZLgnvxq//qi zn4ECYwEAkify4U7
hv0OaB/y9UIb3wPBNYCCEAHhP1BLAwQKAAAAAACqe3A0DYf/8K0AAACtAAAA LQAAAG9yZy5lY2xp
cHNlLmJpcnQucmNwLnZpZXdlci9pY29ucy9zYW1wbGUzLmdpZkdJRjg5YRAA EADjAAD///9/WFBQ
WFDQuKAAAAD/+P//+O//+KC/2L//2FD///////////////////////8h+QQB CgAPACwAAAAAEAAQ
AAAEWvDJSau9NYixO/8C8QhFaRbGkaaiQJ6FKhNiULzlEbNIW76yGOEwqJmA wkOiNzoJdIdhguj7
3VxRJTOgExhSSuWw2PSGp2gCUxBAuN0DRDweetDu+LwIw+9TIgA7UEsDBAoA AAAAAKp7cDQ40W3C
nQAAAJ0AAAAtAAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL2ljb25z L3Njcm9sbDIuZ2lm
R0lGODdhIAAgAIAAAAAAAP///ywAAAAAIAAgAAACfIyPqcvtH4CctEIkb9TA dEttHTSO5FGZXsZt
KFNmIcuujQqbpYMntX6aRD6v4qPnSip5CyTyNiQqaxec1INtYXzG6nDK1a6E 4SqQqY3JhM/mEnpL
heA5+Trqao/nR57d27QGwkb2JGjRFxiFiKZwyAcTZzdJVvengZlpUAAAO1BL AwQKAAAAAACpe3A0
AAAAAAAAAAAAAAAAJQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZpZXdlci9N RVRBLUlORi9QSwME
FAAAAAgAqXtwNOBWAut2AQAAzwUAADAAAABvcmcuZWNsaXBzZS5iaXJ0LnJj cC52aWV3ZXIvTUVU
QS1JTkYvTUFOSUZFU1QuTUaVlMFOwzAMhu+TeIc+AI2A4xCHgXYDNDFpdzfx Oo+kCYnbDZ6erqWr
BiXrLlXl/8tvO7byAgWtMXC6Qh/IFtPkVtxMHstCaUw78ajddcorGJwmK8Id +mShyzylotOWnyaz
mmTLWJ8LlJpcQJGRZ+GlE1Vz8D4JVOQaubZ+YF/ij8NJLX01TxpCWABvpolH Zz236cUWfIfMJFMF
bH00r2gPHsruq362EjR9ATeJXavN94c86QLkO+TxZiZv+FGSx7Tx+8WWdH01 OYlI61H4smAy+Fvb
oHZDMQGu/vUV+kE1gzBo1Wb/G95hVhv2Ut/WUEzIDdRfhRVJFLhnLA4zOo+G Ko9AWNT3jGeBUQnb
rSBGE4FKiorxRM3YBgUFDP8Kwqq4KECB43ozFQ8M5Nhaz6818Jo0XgTX7Y3i tyqTo8GxpgGM06iy
i+Cx5nujx3Ixy+O6nScEGuLDxDZs9AW4U+sYbazCmF332MxbKZ2VbJdcr+40 aR7Qb1BLAwQUAAAA
CACqe3A0esrm6PoAAACRAQAALQAAAG9yZy5lY2xpcHNlLmJpcnQucmNwLnZp ZXdlci9wbHVnaW4u
cHJvcGVydGllc1WQMU7FMBBEe04xHVU4ABLFF9BH6Je/2dibxODsWraTAKdn nRRAY8me2TezpkHX
euXP+nSdQ8Hbc49LSjE4qkEFOxVMLJypsseYdbnJ7a7OjP7lFX1cpy4I+qzv 7Cr28E3ZP5jFTAev
0JIio8y6F9iBqo9N7EDeg+yausgbRywsK0i8PWkcKBusziDXapTfkQ/+GoL4 IFMx53/dZbaa2ALv
Js5U4UjuKwaGi1rYN36zAssaa2jNgpRK4rhAR5vh1vhEnMzEuSS2lM0sR6UU yfGs0ZuCUTOE9zPz
nFgLHyDPI1kKjh+GDxR1+tvTtk9Z/epqswYJbZOb/ABQSwMEFAAAAAgAqntw NPzZypPzAQAAiwcA
ACYAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvcGx1Z2luLnhtbMVV y4rbMBTdD8w/GG9L
5T42XdgTpoFCoC0hpKW7osg3nsvIkqqHk/59JceJ5diEurOoFsa6ukdH51w9 8sWx5kkD2qAURfqW
vEkTEEyWKKoi/bb99PpDuni4v8sXwDgqA33ue5/bDinuKhT+7/4uCS2HowUR knzg3LAsUqoUR0at
H0mjISVR2CKVuiIdCWFSA9FOWKyBRDCTPpyBeRQ+Bbu4h3XdvjFOjRlS7FBb opkiDcIBNHmMFjeY
L/MT9qzZkLYNnfT2gUv/tkiHRHkzFTCLDcTSovBQiqA1FOn3dsXJus/yds6U Owb3lbqNVBEy8iUK
v9yXQBUbEvpTTmxASW2vBFDO5eGL4xYV9zlWu5FEFjZw+JrM0NqnvSMV7ue7 +JU2WLV7IdRkppFi
AI69DAl/Kz5ZU+271tv//3y4rOEfbFA9duzCnK0UiJSWpWN2zvXSQeLt1oWG OqKDf1vQ8Job1+3j
arNNNst10hXwdJw7+n4F/kDZ321sPAXdSWdXNa0uFe1bQ7mDc1V1S/EzOpxt gbM5ZAcUpTy0bOal
dHnWeTunsNN3xA5FeKXiuj3DlQYm65qKclWO0HvkQOCI15eHYU9QwwSghD31 Z+mRMeCgqZV6KcUe
K6enKm3gl/PvqDdmud18fvUjzaYE+8czu7yefwBQSwMECgAAAAAAqntwNP04 HY9XJQAAVyUAACoA
AABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvcHJvZHVjdF9sZy5naWZH SUY4OWFzAKQA5/8A
AAEAAwYBBwoGEBIOFRYUGRoYHB0bHyAeIiQhJykmNRJ9NxN/NhZ4MBh+OBSA MRl/KywqORWBMhqB
MRx6OhaCOxeDNBuBORt2PBiENRyDNCB3PBt/PBqGNx2EPhqGOB6GOyB0OR+H MjMxOiCIMzQyOCZ3
PCGJOyZxNDYzPyKEPSKKRB+LPihuPiOLRSCMNjg1PySMRiGNODk3QCWNOy1w Qyd8QStxQSaOSCOP
Ozk9OTs4QiePQyiQQC55RCiRQjBvPD07RimSPz1BQzVnSyuIPj5GRyuUPkA9 RTRtSSyVQEI/SDhg
Si2WRD9ISDGLRDthRjpmQ0BPTC6YSD9PRz5ZSTptST1eRT9fR0BVTjCaRUZE TzKcUTOdSUpIUzWf
VTahUjuQVjeiVTmcTU5MUElfWTmlUkODWTygWjumVT6nUFJPWzynXj6pWEGq U1VSYD+sW0StYEWj
V1lWYUakXkawZEasYUiyZEuiY0u1XV9caEyqakuxZk23Z065bU20Y2VibFOq b1C2cVK5Z2lmc1S7
dlW9c1myc1ytd1e+a21qdlm5elnBd122b3FufFvDfl3GfGDEfWK8fGS3dHZz gWDIf2i0g2LLf2bM
hmTNenx5iGbQg2nQhG+7i2jSimvNhmzTf4F+jWvVjW3QiW/XjXO7i3LGjXHN i3DYhIaDjXLajnPc
jXjFjXvBkHXdiYuIknfglnrkjY+MmH3ml4PMmoPEm3/pnYPZmInInYHslpiV n4PuoobxoY/QpYjz
o47ZnJ6bqIv3oKKfrozyqZLhq475ppjSrZD7qprOspD2paeksJP/rpvgtZP5 qauot5X8uZf+ra+s
tpz/uKTTt6PftanWvp7+srSxu6T/waH/xqL9vK/ct7m2wqb/xKj/wbDly6v+ vsC9za3/yLD/zbH9
xLvjw8XCzcHiycvIz8Ls0NLP2Mvs09bS2NDq1tHw1tjV39jk293a4Njy3+He 5d/02erj5Ofj6Orn
7uf07e/s8fPw9vj0+fb7+fv4+/36/v/8////If4VQ3JlYXRlZCB3aXRoIFRo ZSBHSU1QACH5BAEK
AP8ALAAAAABzAKQAAAj+AP0JHEiwoMGDCBMqXMiwocOHECNKnEixosWLGDNq 3Mixo8ePIEOKPBgg
wMiTF0uqVLmw5ECXKF+uLODmnEF+ubQQCDBAByh4MksSUGPT4cqVLU0KhBnT 30oAUAFsIygPQtSr
AIJeBWdU6UOmTQm63LdvnRwAIgbus2rgVz1++M65giBT4LuzOboi5IcKAs8u zZZ6ZVpS3h8CAnQU
1TcJyIAABdQEFthMy+MDifApZEo2AIB9AnMBMGCPrGnTgv3187cPgNekB/cJ waqU8GCsAATA2zcJ
t9I/uBPkS8i037sABljLBvALNHGl/erx7HrUpKsABKzl2wcNSOrvTgH+5EnH z50MAH/8Qd2Wj9+7
Xyj2/QJwANr2dFoAZHouUF85HQBMMhABANgDW3mzjUHdUf5YBQ1oZNX1XWuf mZYOffsQmAuEEOYA
gDyrkWUPAAk855lrAXTBj0AUrrjZiZ4RkI5eBVEYYUG2DeQaQft4tk8ung2g RSZFCeDZU56ZeCQo
qGUYgIEvxqjGO84xBBaLrulD0mBKtfZaawKQ5Q4qXRAYQCzqoagSVK/haNI+ sQBQgDxqAcEcbGSt
9lWbrDm4pYROedUPNAHkpRxZzQBAAD8eAsVjlQbBtM8gAECgmUCujFbPiwTp 2dCVrGUipzX65GPN
EeDZtg1Z4BQQgCv+/pDwizz87GMNVP6IhkAwb+mzTi4o8McaP10AAISW++Rz wGhu8ZPPObHQBR6k
Vlb3plVYpcolilDpQNZVR47RDz/A4ZYVQpztIwIAcgz0zrLmAhqRtQH0k2wm fhGghTXaytSIAchN
4pw1Y7haqcCmbTMGwAEkMAhX6Aq6jz0GANCIasm6ksNOBOSACp3gZcThadRu SbJaJFeZMmoPRagy
hKwpFxaNCLHDiyR6sBGGF16EEQYabMCxhyKlFBPPzEiD189q87BShxRMZLFF FmJwIcYXaZyh9Rlw
wEGHHXvsAYkv8yQdE2eriBEEEWtLIUUWWXBhtRhopMEGG3XkvQf+HWEHIggh Y5ds9kfk6IFDCjgE
gUMSbku9xdVfhJH1GXXgvccbe/Thh9+ECKIIJKaoMzhI2pwBww48BBGEEUYk wYQYRHDxeM9n3E15
5Xv4obvfihBCCCKLLAKJJ+iMvhE7ps8Awwyoq946EVLIXnXWa+D9Rh2Y74FH IH308TfwwV9CyfCm
HG28RYy00AIMLswQQwpsr974FlvwHMbWetuBhx97fI9IH5dYhCMccQlHQMIS l/CEL843EWkEoQMm
UMEKYHADHvggcURgHNweJwYxpKF6eGMD38JGiD4oog/BC5/4LoGJS2hCE5sg HgMfcogImiAFKmiB
C1KQugsyoXH+YshCz8SgtTq0oQ57qAMfuPc74A2wgARE4Cam2IlPbEIUtpjh Qu4hBhN4wAQrWMH6
boCDHfggCElwHRGC6AUiAu1ueVOiH7yniEUAcBGXeMQlLmGJTXTij5/4RChC MYpRiOIeWjTIPrTh
gS96AIJhpGAMdqA6IuBgC2+zGu0oRzk7+GGJguiDEyFBwEe0EIaBHOQnTjHI U5yiE8VL5EB40YFa
diAFJsjl+mYQhBT4wAhue1sHaRe0M/jhDbsTJSJI+cQ9biIUqRTFKFJBzVaI IhTU/MQ0ZOkPVizA
BLXkADhxuD7UsQ0HjRNmGtCgtTdgrg5gE8T3BLhHSrxwE4L+nOYpRGHNVrTi FfwMxStSsYxEcmIB
HchAB1bQAQ+EcZc32AEOjMAEDcrNC1+oHd7qQAc+zLGOd6znJVKJTVWEohWw EEVKX8HSV7RCFSYd
BgP3wYlweiADucxlGNt3gyCcEXpSCGIH71cHyiVxc30gRAoLeIlO4HMUp0iF KqwJi6paFRYtVSk/
lyG4sLAioRiwpS11OYMUNA+YUiAC1bggOTac4Xp0mKM8L4HCPbown6eA6Suu yter/rMVodjm4I6B
gQpsQKENTQFDI9iC9/nAB0QApuPaSES88e0NTFRqAR/RxyqGAqb/3KtVayGL qtbiqi2FqTfMZo4P
ZOC1HGj+qGxVEMEZ8OBwiqMo3Kz2BaAVdQ+eDIRSUUjAS/gRqgAVLSxqYYta 1EIYphAGLITh3NNi
laWEbEfSXGCBCmBgA2HdACQjOEHU/dII0JMaFyL3QTYgM7hKLSUmNBFIqaLU tNWtLnVh0dznTlel
LgUs0s7wgQW89rViXagYl9dL1UGtam3En96Sakc8GvcTozipSmuhUulS98PP 9XBfq8pPUYSFEw3I
gIExwAHxNrKW5HVBBVeHztcJMQxraAPewMY94BWQEpbQxGfvu9wPTzfEz01y iKVrXVj4MxUyRQk5
HrAAw2IAto+EYC5zCINJru6HbvMgOykHhzmakLh7xPD+KazJYee+4sPCgHOc 5+zcI1d1r9cUhehO
EoQMWODP3kWsF2u5ghzeoII/fZvU6OZW7O2Be+FzBCb8yErTwnnJwthFL3bB aTmTVhh7bWkrTvGJ
k0jCAgvoroE30OJabiCMHVDB6Xgov91erZ1IzNxw7dqJUwDUtEeecy+EAQxk GDvOwwYxdIVR2pSq
YhSdWGBI2KEAFVsgAwyoQAa+K85a0laHOOAB/FxHNarhuHId7fEiHkEJ405z r85V9i6EQYxoCEMZ
xsA3MuYc51rMW7mv+KxTzfcRMajYzxi4srazfEtywsAHKTDCRNMqRC+soYh9 O6Ej9FjFvN5ZzsAQ
RjT+kBENZZB85CUPOZ2TTGJrhqITpvjIPo7BABVL4M81v7J4vejQBVuQdVGL mxfWuVE78AHNBCSk
KODtYWIjQxlQV0Y0osGMqUtdGMYgRrKpS1pT1MKlpxiFJjCxWo/g4OCp9i63 M8CB2ILTBGM0I3qF
GWGNfhTNncgwSt8c4pBP/e9/d0bVqz7yfhveuqFgpRUv4ZFbVNvAqf7ztVsN TtpGEtHozEJQveDb
vM3RxxzfZ1U9PO+o//0ZzwB8yaVODGIY3qq/HsUnNGEJSgh2IyuwgAQysHtV V0DbChVnTlvgvjMy
4Yf0620Rj/43em5iFCgVRdNLTvJqPKMa1bjGNbD+gQ3sR6Ma1I+GypVcVUI6 dY+P6KpE9uF4BTBg
AZH387Y74GIPbEAFErxBCir5tvqJoXpwgETdAzyUgAmdcFL4lWkiJ3XYh33c x33eB35TR2z9dlrC
sHTY9AmdgECQcHsYgQOA9loLkG0bYGWCtgKMhWhJgE5BJQaSczt4IAiIgAjO NAq/1ncLCH7XkH3Z
0IPcwA3bhw1WB3UK2G9WJU2dgH4GpBHUsAAK8AAKcG0V8H5/xnaIpWA3FAMz xgRqJURncHHIhAd4
AD5BhoDxFmfGMHXgxw3ZwA3d8IZumA0QKIFSN2+ndVoYyEqYQAmPEDzkkBFi 8GdRCH+71wFVpm3+
4gVB3hYDvBRxQWc17LRRfnBCFvYJqZBSzrULwJCGatiGbviGb5gN3cCG3kdy KleBTpYKi7dHi0CD
GDEPEhCFD2ABG0CI8sdilEdbOWRbbKNB9cNO2KMHSQU8fRQKG8ZsIicMzJB9 1yCK3xAO0BgO4gCH
2bCD0eAM9jZsVeV1otCNs0cJBIQIvoNIFlEJUagA6PgAr7V7BnZgLwZGOTRJ E+U6VcNoZ7AHR/c7
e6QJ0FdVshBn9fZ92CCKoBgO3/ANoQiEdKgMp8h1WPVy6Bc8/yNtFcEDUfhn DyAB8IdQC/BdtvSO
KpACM/BYbRM3HsQGRzSANDhS3ZhkWKcMqYf+DdfQDc8YjdE4jd3Afd9XeMNW ZwHXCtCGQJcwgyck
CBZhDueIjgpwWK9lAR2QbQk3VoXmPnL3YBhVRGBDiZx1Unv1j72ADNjIg28I jeJgk6Aoh+AndeNn
XapwClNUQBLpPX2wZxLRD4fAAJIXixqpkdfGlGEFTgu1i2aEA8cXNzi2BvCE B6K0R5ZgjK8gC88F
DAxYDWNZk+NwmWUZDqIoh1aHDMAwb/+oVS8nlMCDCIIQCHuwChTRDzswgkoJ hQfXXRJgWIiFggtF
fJSURsJ0P1qDVEr1CM90X3NWctHAfWM5DjYZjQgJgVVnDKiYUoS0CXkUPJ3T B/jYBxTBDqj+VnMW
cI4qtgAa+Vob4AGthkuCmTqvkwQuWD1vYAd+gwiOQAnPpFKwIAvAQAzOcH1s GI2X2Z/QiJA5mZae
+ZxA+QktFEB2dEJhQwcEBxGscJHo2J3Yto6G+HuI9WIStAO0RgRRw1a3oz1J tUfGKAqy8I/CUH3V
gA0FGQ6XCY3ICYpC+HeZpmTXFArS6QgSWUKBYAd5wwsRsQ/9IAboWHPnOIKp 1nvblojj1QK4RZhv
g1H3IzTDKDwHWJ/+Rm9Shw37aZMtWpZyyH3PAHWut18ABm2asEczmFRhw6N1 oAgT8QEZKQF4GYUZ
oG3wd3DbplCAaQLLgwO/lF63tmMxKAj+LPQJqqBSXokMqZeib2iZyGmQNBmg 4Ldv/1hn1rR4ltAH
kCCO3MMHeYOSEoGU6OiE3fmE1aZihnhYLYYBiyVGZaU4wXQ1WSOAorQI8mmM n7YLT1ecbNgNySkO
z9gNbQh+zAB10fBceBZwZ8qK/9MHgeAHeUM5aaBdDvoA1npzEIptBrZ7s8lq CQWYKjAD4UZRXfgF
YnA3+iODeKQJqfBPJUpv0RCTK/qfoLh912hvyGip0LQJloCj4kgIqGkHb3A3 7OSjLTMHStkAFsAA
RboBfGlg16ZQDrVlM8A8KeA2swOM1wk8kIAJxlhkxCZ116eiBUmQnJmWDBln JJZSoyD+nZQQPEkV
CPsTR7UjBpEQEUFgrVBIZd35Z+HJkXUaWwkFSY11RhT1pOfKNfloq5uwT48p C/NGnNEQhKD4hjKp
k1dXgXg4mlCUpnxwOdHqVmFQBxCxD05oqhIwi+moe7ynYqoqXisQW7LGPKmj VlzgBV84YYIgQJjw
CS35j7qKjc/wgMY5kGAKk1nHaZCpVa3wCSvUiiYUNpfzVmeABjvjBRDBDhKQ tqb6hIJopCPIe7Q5
tBK0PhAXBD8kRBnVSTG4TE1lTU8bsiJLuCmqesowZ5X6kKGACQhUq31wdHRA B9jzhVojBl7QoOOi
JQdRDOn4hLHIsH+2AIdlpwjXYnv+qgIuEAOWhANiwATrhQZoQKs+hgmGtFxL BnWod32ohw2opwzM
gAzGMGwlulL7mkcBxKm5E0di+wVyIwbUoBq1MjHvgBCkYK2dy5cRupdAi2AZ gIIpiEFpNVS1Awfd
s7dJd6hdqYnEIHVTl3rxWnLMcIqQeWfSdKZ9mKa/iwdvUDtaY7le8DhSMAv6 MDHykA7gAA0H0Q+A
YKoGnLaCOIvcWouG1QFX1lArkAK4mTixypsCGAiI8AiQwI+q0JXCtsFRh2/i JwybJgvNlVIBxa/t
9j8KGjbXwwZrkAYdFESaJwny8A43/AuoICAHIQY727zud45UppHq2F1FnGWF RkH+ziMF9PMzkkhh
7XZFS/e0mgYM9+mcxMDIxGYLu1Bn5dcJvPuyrRhKn/QGAbg1V8MFcKN5d2AN v+AKk/AHctAFsZEE
O9vKRtqz1faz2xZWKQBjgml8LUg3bcA3AwgJ9uS3S1efcjZvmcZpuzC/XkxI nsCsomSdYVNUKHm5
9ahWUgAGmTAIctAETSAEMoAQMNC5UBiF2Cqh7zehTFmnhAZ3FJQ6jCPIqwtP m/M7BJR3VEWfJfqP
kElapdVsAWWgj4CjrYgI+8MHXcPCPmOucPM2aUUEYyAE3IwCOWAoNeIBT9jK 6KiwRapiGJBqCHVl
j9TAKNhl8IO6JjlmX6OS7Ob+sSWGVfV5z5QMUAEVCss6lP9zml/7qXVwcWnw wlbjNseXBETAzTlA
AiggAmlxEBkQzkq9sz3Ltkj6tgy3Ai6wA5SERkYgBr9oOY8mXJCgR5cwSNaU yLBgCrKwdGYNWPV7
wuIYSp5Ks5JjrlgdTECtOj6AAkWdA0Yt0QVR0Xzdue+nlHv5fu04VhCEvWXV i4I8VGgAB0Y3gMKz
j1DVjStt1oPUsrUHxZBbQs5cOdVzBi4IylTzQysoBT41A3gtAqd91AYRi+C8 szcneRJaZQe2bVm2
ZaeDA4nDOmx0Bm3woaGkVLbKRwdYSKo0SPtqCbXX1cok0NZJBzq2NWlQBsb+ G1THd3xGcEYpAANG
vd1GjRAGbMCdqwANEM6oxnsLW1gZwGpCq1MWawTy43/AOEJMNIOXAAm+HGSb AEN21W72LZHiqJjA
pb8600GPo3lcyAR0HXE40AI5AAHcrdcEYcffDd6CqHvwVwFVGLGN9EV8KlH7 p1tbwFbgWzn6wz3+
g0f2bd98mEeQ4N++0wcAzqYXpzU7Qz8KfXxrszY8cAMwkAIQkNrdfRAWHd4Z 6bkRynsjWAELwAEI
1gFuF67v496AajVExVGZ0z2/00QpFNAzaJqh1D1+gAc8ysJmHAbGKztTk1aE mTi4zYha+OAOjhCt
XdFKHaHdSWV16pQMEFb+UilGHq44rhM9XHAGaXBuwvto3YPlf5PlL57oeLCm +vuFHvQFXlBuUPND
7h0EVD0DPN7jPy4CDo7aCAGedZ6OULi5UNizeAmer/V74oVgKOg+KQDUrdN/ VoM/XWN0V57ovN49
3KM90UrmZ7Az9YgDmkcElmQE+7cDN1BWMdACRwzqQI4QHdAAfK2zdjynFg55 1gZeHMBwcHcDWuin
cyc19rMGwJg3YIOPkouPXxvgeQMHd+NW7MS/aqx5brM47l1Gzd5lLYB/Pg7k qs0jK1Dq105lGH2R
NQex7ZgBWTaxhrZ/i2NRc2O5vAlHXvM1cdTJcFBELRwGlA7aYgDUaZX+BO4d cf0OA/+Ogi1QAw2O
2p+OEEkw3q1c6rGosBZAZamWAUv5lMDHcF8ka2WUBPsHVFNzt0TU2fjDSVzz hW7FBpbrwljdQfj+
0376WMw+Ay4A7SGZSx3QA5/+6QNPEGLQAOP9mhYdznaOjjzfjoEmtOkckuKa 7ByqaEjvgmiwBmuA
Y29EvJVr5h3Ev1Jz6RzKNmzjAzyQ9S4AA4UmQUa8AkiQ16EO4QMBCAxL86Xe ytgKode28zXnrQsF
Y1svrmeEAxyaurtlrpEz7C4YBtLtM8PEBS1Y9Ti+7z6wA4wIAyqPf2AUa+AU Akjg4GE/9gPBCXLK
AAw74eHdAJvfnez+aGBTuG1Mrohbtku3tTZ1r2iJTTUcZLzGSz9YrXmMo1ZA PVGIr+mHpvXqQ1tv
52q19AQRLe1BbhA095oSTufoKKewvHt+ZgFXdmAA0aHCig4rVqhoAWMGjx04 cAQhwiSiFIpZpFis
eDHLFhwUpTABGSTJQ4Y7bsyYAaNFixUpTKRYYcIDQZkmpogQASFHzhz+fP70 14+dBQkSGjB4oOBB
0qQKlCZdIMGCgqkKGCxYYKHCgg4YMGTIwCFDwQ4pEMLYwYMHDh84khBJkoSJ R7oU51IkYoQIRB9B
gqTwcRKGyhYqTMT00KGDiQwrxnLoUEQECZw5IIgAmnlBgwYKjDb+ZbrU6QMJ VqdayLAArAUGGVCP
Hau4sUEVKxLGUBukbRAcRHoz6S2lt16IRh6yxbHDB48bMVyoNGhCeofEMmVD BssTZ+XMQHkwYGAV
PFOnT0cvoOq06oKtDLZm+Aq5A9iCLhEmnHGDRwrjvP3ikAjAh3Tzy4e0TkoJ OhUMa2mx6RSDkAMO
NgBhp8u2w6w7n+LwrKnSQgMtKQkeYMCC00yUAL7WKtAqLAghlM6E2lrID4cb /jICMB/aUitHhm5A
cIbnWDKrNhMUmykx6qjz4KsMNqgAicos2ylDDVk5qqijlCpPNC4V2KzE8kxL zb3WMqhAQiQ5qE66
g1aaIQb9TIr+YQeUahQMBhdWKszII2U8cgMkXwxrA9QquAInnS7sSUN/zFGK sw6R8lK0pUpb4AET
UUNPNdfQ9HQDsSBcITGaZFyQJdtSSIgwPg9akMEYpdugug5qnc+DDTDYAM0K MGCgCQwpu8xRn4AF
T1KrzPtSqdKOeiArE7GSIKvUWIQPrF5ls+4wB6WDIdbaYnUpRpqYJEtXCEXt FcoKemWggwkqW7RK
Y/0Rw6nSGJAgvBCfAg3MEpsiqldrtVLNq/lwVazUxTyYLqaX/pzJXEGXhDA2 yDwAC00MXkuxgwVs
UHQnCxt1lJUHtmxAy0q7ZKrazkzscoOookotAwa8ElTCbV/+3ICgxGw90gOj yTpyBUGV7DU+Xju2
QDX2XHtCBMu2u9rYfdjprCgGOEvW0pc961BTC5JqIGepegWrxI7nGysx7AYd +kXZuppPsV1H3RWs
Cq7lSjWpFhACJxRywtrYfvyZQdnwrOKsKfMsHTOpqTRVYAOlsLIAg/fg80os juWzu3TFJuyVAwwW
9vw117hCLXacL6jMagytdPQQq/r1bF+rlgqYS+AtTy+9nFMrSuS/z3QSLDUh mxADnyV0sgOx0Pw0
NSgPruCqqFNbAApFb8fp3n0gbdmolrnsbHLyupw0g6emSjGqFN3z3FAGVHfy 3XefbNoGmuY5v+3K
U/Lj1JP+HvA3wYElAlGw2oUwhDJj3UABYPtavz4UPBC9bwFiUo9TwMceqYTn V5vq3qc6Z6LVuM4C
NovaC7fytw20plPfq1ZRNMAondzuXkGpxJi+tjISQWtylXNWtahCMxOZbQM5 BIvXzMSBGUqtiu+J
YWpE5poaVkABf/uU1FqjryVc7WqLKt8P7xE5342nZQ0I2PCaNaLRVKU8cIza zRbQOha1xgJbjF32
VNO9J2agWg8wJFGopRobSmUqMphgvXRivsXlC47CWxa03jcagI0GbaxxTVXM ljlD5lBwRXldDAfn
GglUwJTgq5ZqbPbEqNjRAiSjUg+plEbzUaN9JPqQUpD+MkSAbXJsIwIPzdRz yczVb5FSG6EhF6k2
sKjmbA2wwMzUQzMI1qtk2/mhT/rBg/bBkV+Pu+BRtiS8SsXMKVhJih/LY6LO mO2FrZFADTuGlV6l
KJ+lUcrZxpQeZVIFBCI43PgsxJ0f7mMftEjnBYk4It4BlHKe5ORTikKVTNlz ngMlyubQs8RLom2J
89zUabZ5tkTV7mq242U4V3DBMakTcvwyIvAw6qXRrI+Tm1oiitRjTzsStHhA HdOJwhMeDWDoMi9F
HO4Ux49bdIYzYANmaYwSHmYyK0Q81alFL4fSgQZVpSdC6aYwZ8oHUKFKME1o BCmotX30w4JlBduW
+kX+qX/xtJOc9JJWx2iVUBbUqFUBJYmAl0GyleagEuzhBGMazmNc1artA6hR hDnEx31Vcjrta2Oj
BjAG6DM8rIlaiaTyzvKMlDwNwAJMexhZCYbTJ3XtR75oGlGc8uspnEEmszz5 Wa+SDW10fGfLSDOV
zRzSkyO6FOWSwgKsffOpibOtT/jBtcs6BY4sa8rXsgSeYsLsfdJtFvAA2qXM Cresry3CGXcZ2fFl
V5z8OEQ52zea8cQzUsHsLFiLSx6d3lGORyzm8AisgCHI1XazdbBUG+oTHyjr ql0Cj+8u2K/QmPdL
6P1sgWEGWMm9l0snsK52Hnwy+/6kH+SIqHf3u+H+4H5XfYqF38sI7FcF73S4 Cn6tAoRlxsls57oR
lLBt+xHEdOpXUmDbK+SgDC1/+diYIsYoO8uaYwWI78j0rZIE55rdfuT2jjPe 7/riSd4NK5dSgGVn
iXuMYCCD9oI0kC2SjQxTcLY4Myaw8IUv7Bnf6otENxUPiZCCyR8PVMcldrRS aCdmelXprRjyM1D6
gT40n9m7RdnqHJdS6Cpjec4XrTPlgnVpHkYVqlbL9E/2wY9jyPjJgZYxUjSI 0ztSVLHiPfCItbxl
4VFBgrXjyWzpO9kWl5kfWLqjp2Ps3ZVt9VIXBHb7vha2A6M61ZG6wltfqkue LPSlsZZ1mSshaFz+
N1nbW0rWeJbFL//m+ihIgRaVy8NmfFsh2Spe6O3MOEl0u3jJu42xsmRcHuiS mn2+LcqhGc4yXg8T
o50RX6WjumysPbVYBU83J5q8cHefOc0U3XW1wbY7XnvGqvwyCqjH29Jv8nm+ Yd4JZcZc8H5ANOFo
VnjksB25d49HS5rtLUDzitXOUEGyx6YXkmdbJRKAXEO+JLllTR5tIdIRnXnN MMV55xQ2X6CbAc+l
fD1uaauhYOeZLnNQ9vEOIpDc1lu3bDlFFNyJh0eDnTmnoU9gsiPL1Zu7JF8O jjAGq9/2J/yQhzXM
4OQ0B32gymoK4P+ur5cfvYQZ97hTd4lzZOf+AAU60IIcJtF4oPADH+n4xSCw oIGaBv3Wg771b1e2
uyzZ+ygluAlMX8pqxL26MkIYwx9QkQzW/0Qf9wAHKuSgBBEMYdAj9+7ly5n9 mpa4ZejcgPiIH3Db
Ed7wOUB/6ieRi228o/kOfX0yGtEF04ugCSy4Prtx3928L9yqEt2AH4ivqJIt 4os6k0EoJVCDQUCF
ZniHdciH5vMHyHuHWMgDITicy4CAKGAB7EO4rOM+afs/ErEBCJKsZLu0B6sd nXC7LsiDTGC/dLCH
WXu/uWuGSRgDIcgBEngrCGiCHxCvy9q/iOo/IrwgCxDAw2E1S9NAqLo0FHA7 LRiDRHAFaHj+h3fY
B33YBwn0h3xIh2BIhC54AT6bDA18AhD4wIQLwaxrgBOwAiikDOsKs/MTOKvJ AeRTvmAAh3ewB33g
hy2UQH6wh3KIBTlogoSytPmyGiuggQnAtduzsAugASvIuUs7GUZxKVfDCRJA gcV7wVwwh3OYwXwA
RC7kh3vYBlBwAyDAuSa8HQiAxRyggiGgARBwxKW7ABBgASiggsIhn1dEwAsR xgK8wy6Qg0aIhWQo
B3hwqD/kQn9wqLmzBhyEJISKoDicIFbTQMSBuhOMJBUUPmSzQxKQASUYg0Zw hWR4BxnMB35YnGcU
J314BzCkv2BEP2/qRhKgjDjcwV80slz+0g5dEkYn1AkZkMJBAIVf2AYZdCjH g8cJfL3YE4IxXEGA
ND6q88eoO7/IejW2s7RyHAOE/AVzSId72IcIhMaHfDx7eIdf+AMtSEES8CaN +6abQyMIGz2F+jeB
u8Pkg0FoOAd46EN+UMnMiMZyyIU/0MHbiatv1Am120i227PCIzwEzAEdUAI3 +IOfZId3wIdZK8Wi
fLx6eIekhMlMjDAVU8uSmUmoQ8A90w7Ty4GDhEFrOAc+1AeHFEugcCjYSwSY ND6dLL4TFDdMfEUC
NBkEFIIumEJQyAVruEJ88MOw3MvMwId3uMExgKSqlKSOY8vxccoUtMp6QQEZ WDw5SAT+VPgFa0gH
vCRKyqxMcepCedgGV5ADDMwlnaND4Su86lI7qNIlt8PDSUhGcOhKUmzI2HSU LdyHeyjLQegCSNJH
FZQk4ExBuEw7O7TD0zvNRIBBdeTDdnxH5fwh10uHZgCF25QBHszEtMNHwxNH 86sMEniBxUy+SXCF
YIDMdJCHLOwH2CTP5bzCX2gEN1jKw5TJ7FwxcORJqwECKcyDRHBMaNhDPpy1 /wzQFsuHd9iGWEiE
MTiCe3zLptyzM7I5NEIoHRACORiETEjG9nuHeiBFDM1QP+MHskTPC1TCX3zL BT0ZxITCuTzGWAiG
K8RCUqzRWItGaEzOxYnGJeWHKF090oZ80iotMyqtUqIczyTlOaPcUr4E0wnr ji8FUC7NLtj80jBV
Uz+rKzN10zeF0ziV0zml0zq10zvFU2MJCAA7UEsDBBQAAAAIAKp7cDQXYZ2E 7AIAAEQQAAAtAAAA
b3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL3JjcHZpZXdlci5wcm9kdWN0 pVdLbxMxEL4j8R9W
e8ehrYR6aFoBUqXcUFW4oll7duPil/xIwr/H3t02IaJlnFysXfv75mXPeHxz t9Oq2aAP0pple8E+
tg0aboU0w7L9/nj/4bq9u33/7ubOCdzjrtjFOJ0XnLci8dgY0Lhsv6weHpuH r9+aB3TWx+aHxC36
tpFi2Vo/MORKuoCskz4yzx3bjAA2S2kbcE5JDjGreZtxAGybFPAeISaPYdn2 oAK2o3VN09xAZ1Nc
md7ejv9lSmoYsHEQ18t28YaSheTWhIUfffnpsvcOeZQbZIPs28XtpGBxqGGa yrReDisji2XLVmAP
ScXMeAYoSIav0X/2Q3gWczQ3zW6lEXa7KgaHJmhQ6lyTj02Yd67ImXdrH6hg FXgZZk9ne4pPK26f
Az2tzcuddgfgRUYfe/fimVNpkGb2fj/xclTAQcYzMDlu/wOpxNHgK7h9tEZp jFtPgZaAEGGMryGP
AjeSI8NdRFPy5CR22Ax1PDSDJPl+zDnZ0ulwyYi6jpdkLf4EC+mbO2IrjBIQ oQbLrKjGMxDgYi5v
Ijoqd5/8ZMa4gXulvYLYS0UO3Cv8mmAei3gSHT+He4bqANopFN25/DNMyJfw GdQTFGOQg0FflS5H
3HqtdZXqLxJDLWPJi3WsDtWRBCf6SgHaCqxVSk7IvANl0BqMCFQ87lxudUpd JFMy3ibPsZ5QrHO5
0eqkkvF3PT03AVeXZFoyUWrKITmEn2biJvc20ClSSEq+RWtViYYxY0uVNRFL /L/JtaVXeNheCgIQ
NeWEZ9R47kh3awEjsVi8YHNtopSIASnmrlFRbsQCy11h/vQbUv6NhA4CxbOC pZW9EbnFDhzF6Kce
OEX/iGMRd5TG1IaBYmnYUoRl1JTH87i7/kRgRQRNvWKIXkWrOVCApG1KMrea +eEY1oiRUgYyobde
E6HlEiBCt9b/6jC/kCrhY9xQyGgphz25XIqQTc/T5OFt1lMyMu6fudPq9DTN f9OLPf/9AVBLAwQK
AAAAAACqe3A0AAAAAAAAAAAAAAAAIAAAAG9yZy5lY2xpcHNlLmJpcnQucmNw LnZpZXdlci9zcmMv
UEsDBAoAAAAAAKp7cDQAAAAAAAAAAAAAAAAkAAAAb3JnLmVjbGlwc2UuYmly dC5yY3Audmlld2Vy
L3NyYy9vcmcvUEsDBAoAAAAAAKp7cDQAAAAAAAAAAAAAAAAsAAAAb3JnLmVj bGlwc2UuYmlydC5y
Y3Audmlld2VyL3NyYy9vcmcvZWNsaXBzZS9QSwMECgAAAAAAqntwNAAAAAAA AAAAAAAAADEAAABv
cmcuZWNsaXBzZS5iaXJ0LnJjcC52aWV3ZXIvc3JjL29yZy9lY2xpcHNlL2Jp cnQvUEsDBAoAAAAA
AKp7cDQAAAAAAAAAAAAAAAA1AAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmll d2VyL3NyYy9vcmcv
ZWNsaXBzZS9iaXJ0L3JjcC9QSwMECgAAAAAAqntwNAAAAAAAAAAAAAAAADwA AABvcmcuZWNsaXBz
ZS5iaXJ0LnJjcC52aWV3ZXIvc3JjL29yZy9lY2xpcHNlL2JpcnQvcmNwL3Zp ZXdlci9QSwMEFAAA
AAgAqntwNAZkg6mDAQAACQMAAEwAAABvcmcuZWNsaXBzZS5iaXJ0LnJjcC52 aWV3ZXIvc3JjL29y
Zy9lY2xpcHNlL2JpcnQvcmNwL3ZpZXdlci9BcHBsaWNhdGlvbi5qYXZhlZLR auMwEEWfra8Y6EPt
sKt8QCg0dPOQLrSL16V9K7I8cdQqkpDkuGXJv++oUUhLA6VgLGEd3XvnYifk s+gRrO85Sq1cQN4q
H7mXjm8VjuhnjKmNsz5+gKT1yP1gotogX/7RIq6s39SDMaLVODt1JYyRj6rr MQb+SwWnxetJblD8
oHe3JPfpZMJgAs1aBZBaBHpbE73VAYTWIIJDGQPYFcQ1gnBOKymisuY8AL6g HNKeFKbMDS2dZZH5
EQRKoXGDhmQ+zQL/GCumEyiNNT+vxVZ0VlasoESXAfEbpZzRSflEAlwL0/Pb 9olyk1JKVuRo+4+Q
yLwVvg8VTebtGGDxItGlxBSqKHKJ0OX1Ao69celRRMxIWc2Ij/717V6hDFlg HLy5sh2eujc3HcW+
t/65RSPXZbb4AQbHd80diXm3VcH6siKn5LCC8r3DB4t60dzVN4/14m8zr5tq n6nY45/754uHZXOA
38R37Ev89ncid7BShv6RPHYegqfVBkylJDF6duw/UEsDBBQAAAAIAKp7cDQ+ dC+fwAMAAJwLAABc
AAAAb3JnLmVjbGlwc2UuYmlydC5yY3Audmlld2VyL3NyYy9vcmcvZWNsaXBz ZS9iaXJ0L3JjcC92
aWV3ZXIvQXBwbGljYXRpb25BY3Rpb2
Re: Integrating Birt into RCP [message #158756 is a reply to message #158593] |
Fri, 05 May 2006 15:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Take a look at this example.
Specifically the PreviewBirtAction code.
In the comments I have labeled four options.
The uncomment option runs the report in SWT Browser.
If you select the run button you can change parameters. If you want the
parameter box to appear automatically do set a default for a required
parameter. Create you report to change the datasource xml file based on the
parameter. Also one of the options allows you to pass the parameter in on
the URL.
Jason
"thoorens" <gershwinou@gmail.com> wrote in message
news:22006072.1146815342080.JavaMail.root@cp1.javalobby.org...
> Well, thanks a lot.
> What about if I have to change some parameters on the fly: The source data
> (xml file) of the report depends on the user choice. I want to allow the
> user to choose an XML file (same schema) and view the report into pdf. Is
> that possible?
> I guess i can change the report by changing the lines of the .rptdesign
> pointing on the source, but is there any proper way?
> Gersh
Attachment: rcp.zip
(Size: 56.82KB, Downloaded 89 times)
FUDForum. Page generated in 0.04323 seconds
