Home » Language IDEs » C / C++ IDE (CDT) » Linker can not find libraries
Linker can not find libraries [message #157784] Fri, 11 November 2005 11:03 Go to next message
Originally posted by: kwallis.gmail.com
Hello. I am using cygwin on WinXP. I have 4 c++ projects, 3 of which
create static libraries (libxxxx.a files), and the 4th creates an
executable that I need to link with these other 3 libraries. Under
Properties in the linker section I have specified library include paths,
and included the lib files to include, but the linker can not find my
libraries. I have tried a number of different options, relative paths,
full paths etc, but none work. I get the following in the console:
Building target: RHP_InternalPool.exe
Invoking: GCC C++ Linker
g++ -L../../../POOL/Debug -L../../../UT/Debug -L../../NHL/Debug
-oRHP_InternalPool.exe ./IP_Coach.o ./IP_Defenceman.o ./IP_Enforcer.o
/IP_Goalie.o ./IP_Group.o ./IP_Player.o ./IP_Pool.o ./IP_Scorer.o
/main.o -llibpool.a -llibut.a -llibnhl.a
/usr/lib/gcc/i686-pc-cygwin/3.4.4/../../../../i686-pc-cygwin /bin/ld:
cannot find -llibpool.a
collect2: ld returned 1 exit status
make: *** [RHP_InternalPool.exe] Error 1
make: Target `all' not remade because of errors.
Build complete for project RHP_InternalPool
Any help would be appreciated.
Thanks.
Re: Linker can not find libraries [message #158755 is a reply to message #157784] Tue, 22 November 2005 10:48 Go to previous message
Found the solution to my problem in a newer thread:
http://www.eclipse.org/newsportal/article.php?id=9006&gr oup=eclipse.tools.cdt#9006
Previous Topic:Can I debug a C program with multi-process?
Next Topic:Defines while indexing
Current Time: Sat Sep 13 22:35:10 EDT 2025
Powered by FUDForum. Page generated in 0.02834 seconds
