install viewer [message #157703] |
Tue, 02 May 2006 08:13 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: lazzeroni.voila.fr
according to indications to install the viewer below it is necessary to
take the file webviewerexample but I do not find it. or he is you?
I thus use org.eclipse.birt.report.viewer_2.1.0 but Ca does not go once
all is carried out.
have you to it solution with this problem
indications :
Install the Viewer
Deploy the BIRT Viewer application. Follow these steps:
Download the zip file with the BIRT report engine runtime. The file is
named birt-runtime-version#.zip.
Unzip the file in a staging area.
Look under the birt-runtime- directory and locate the "Web Viewer Example"
directory.
Copy the Web Viewer Example directory to the webapps directory of your
Tomcat installation. For ease of reference, rename the directory to
"birt-viewer".
Copy additional files to the directory structure described in the BIRT
Runtime Note below (iText and prototype.js).
Stop, then restart Tomcat.
Display the Tomcat manager application to check that the viewer is
deployed: http://localhost:8080/manager/html.
Verify that birt-viewer is listed as an application, then click on the
birt-viewer link.
A page confirming that the BIRT viewer has been installed should be
displayed. Click on the link labeled "View Example" to confirm that your
installation is working properly.
FUDForum. Page generated in 0.03600 seconds
