Home » Language IDEs » Java Development Tools (JDT) » What is the proper use of IContentAssistProcessor interface?
What is the proper use of IContentAssistProcessor interface? [message #157539] Thu, 06 May 2004 11:55 Go to next message
Hi All
I want to extend content assist feature of Java Source Editor, by adding
my own items for the content assist. From looking at the code, I understand
that in order to do that I have to implement my own instance of
IContentAssistProcessor and register it with IContentAssistant of the
editor.
However I cannot find an extension point that would allow me to specify my
instance of IContentAssistProcessor. It is quite surprising because I can
see that extension points for IQuickAssistProcessor, IQuickFixProcessor and
IJavadocCompletionProcessor which in my understanding have a similar
functionality to IContentAssistProcessor.
I would greatly appreciate if someone could explain me what is the right
way to implement the extension for the content assist functionality and give
me a hint which extension points to use.
Thank you very much !
Re: What is the proper use of IContentAssistProcessor interface? [message #172001 is a reply to message #157539] Thu, 05 August 2004 05:58 Go to previous message
Originally posted by: daniel.megert.gmx.net
Leho Nigul wrote:
> Hi All
You can't. The Java Editor and its JavaCompletionProcessor are internal.
Dani
>editor.
Previous Topic:Error in brace matching
Next Topic:Java editor recognizing protected areas
Current Time: Thu Mar 13 15:12:22 EDT 2025
Powered by FUDForum. Page generated in 0.04047 seconds
