Indexer works, doesn't work, works ... [message #157534] |
Wed, 09 November 2005 08:45  |
Originally posted by: bluesboys.-remove-this-hotmail.com
I have a workspace including several.projects. In most of them the indexer
works as intended, but in one project, it only works on some files. I have
some files in the the same directory which includes the same header file,
and in one of them the preprocessor is able to locate the header, and in the
other one it isn't.
The other day it suddently worked in the whole project, but now I'm back at
the state, where some of the files are ok and other aren't.
Have others experinced this, and most importantly does anyone have a cure?
(I've used the include external path trick)
I'm using Eclipse 3.1 and CDT 3.0
/S
Re: Indexer works, doesn't work, works ... [message #157894 is a reply to message #157534] |
Mon, 14 November 2005 05:08  |
"Hansen" <bluesboys@-remove-this-hotmail.com> wrote in message
news:dksugu$b6k$1@news.eclipse.org...
> Hi
> the other one it isn't.
> at the state, where some of the files are ok and other aren't.
> /S
FUDForum. Page generated in 0.03313 seconds
