Re: BIRT perspective does not appear in Eclipse 3.1.2 after reinstalling BIRT 2.0.1 [message #157565 is a reply to message #157525] |
Mon, 01 May 2006 19:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
RC1 requires Eclipse 3.2.
Try downloading the AllInOne and see if it works on your system.
Jason
"Holger Buchner" <Holger.Buchner@Web.de> wrote in message
news:e35e9j$7nu$1@utils.eclipse.org...
> Hello,
> after having tried to install BIRT 2.1RC1a under Eclipse 3.1.2 (what
> didn't work as well), i deleted all directories containing "*BIRT* from
> the plugin and feature directory of eclipse.
> After that, i installed BIRT 2.0.1 in the eclipse environment. The
> settings for BIRT are available under preferences in eclipse, the views
> are availabel as well. The configuration of eclipse does not report any
> problems with BIRT.
> But the BIRT perspective is not available to select. Even if i started
> eclipse with c:\program files\eclipse.exe -clean
> How can i really wipe out my old BIRT fragments to get a clean
> re-installation.
> Any suggestions ?
> Holger
Re: BIRT perspective does not appear in Eclipse 3.1.2 after reinstalling BIRT 2.0.1 [message #157581 is a reply to message #157573] |
Mon, 01 May 2006 20:24 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Have you tried running eclipse with the -consolelog command?
You can also extract the Birt plugins to another directory and verify that
all the plugins from the original where removed.
Jason
news:e35mg0$c0d$1@utils.eclipse.org...
> Hi Jason,
> BIRT 2.1RC1a wor.
> I would just like to learn, how to get my old configuration back working
> on Eclipse 3.1.2 wihtout having to install everything from the scratch.
> Somewere in the eclipse environment, some fragments of my failed BIRT 2.1
> installation are still avoiding BIRT 2.0.1 from starting up properly.
> Is it possible to turn a log-level on during startup from Eclipse ?
> Yours,
> Holger
>> Jason
>>>Hello,
>>>problems with BIRT.
>>>re-installation.
>>>Any suggestions ?
>>>Holger
FUDForum. Page generated in 0.03613 seconds
