Eclipse doesn't recognize a JAR file on the build path at runtime [message #157425] |
Sun, 16 November 2003 00:11  |
Originally posted by: andrewip.shaw.ca
Hi there,
I seem to be encountering a weird problem. When executing my plugin as a
runtime workbench using Eclipse 2.1.1, I encounter the following error when
I attempt to open up the editor component of my plugin:
"Unable to instantiate editor: ID_TapEditor
java.lang.NoClassDefFoundError:org/jdom/JDOMException"
I recognize the class it isn't finding - it's from the JDOM library that I'm
using in my plugin. However, I've already included the JDOM jar file as
part of the Java Build Path for my plugin. This presumably adds the jar
file to my classpath at build time and at run time. I've even tried
manually adding the jar file to my classpath as a program argument at
runtime, but this error still keeps appearing. Can anybody help shed some
light on this matter?
Thanks in advance,
Andrew Ip
FUDForum. Page generated in 0.04795 seconds
