CDT installation problem (Windows XP , Eclipse 3.1, CDT 3.0) [message #157414] |
Mon, 07 November 2005 10:24 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: Irina.Transky.expand.com
I installed CDT plug-in ( just unzip ) , restart Eclipse ,
when I enter to Preferences--> C/C++ menu , I got an error "error occured.
See log file"
In the log file error message. See below.
I use
OS: Windows XP Professional
Eclipse: 3.1.0 Build id: 200411050810
CDT: 3.0
Shoud I install anything else to make it work?
Irina
!SESSION 2005-11-07
10:17:13.440 -----------------------------------------------
eclipse.buildId=I200411050810
java.version=1.4.2_03
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=iw_IL
!ENTRY org.eclipse.core.runtime 4 2 2005-11-07 10:17:13.440
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.core.runtime".
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Link
org.eclipse.cdt.ui.CUIPreferenceInitializer.initializeDefaul tPreferences(CUIPreferenceInitializer.java:42)
org.eclipse.core.internal.preferences.DefaultPreferences.run Initializer(DefaultPreferences.java:157)
org.eclipse.core.internal.preferences.DefaultPreferences.app lyRuntimeDefaults(DefaultPreferences.java:189)
org.eclipse.core.internal.preferences.DefaultPreferences.loa dDefaults(DefaultPreferences.java:321)
org.eclipse.core.internal.preferences.DefaultPreferences.loa d(DefaultPreferences.java:317)
org.eclipse.core.internal.preferences.EclipsePreferences.cre ate(EclipsePreferences.java:295)
org.eclipse.core.internal.preferences.EclipsePreferences.get Child(EclipsePreferences.java:388)
org.eclipse.core.internal.preferences.EclipsePreferences.int ernalNode(EclipsePreferences.java:528)
org.eclipse.core.internal.preferences.EclipsePreferences.nod e(EclipsePreferences.java:660)
org.eclipse.core.internal.preferences.AbstractScope.getNode( AbstractScope.java:39)
org.eclipse.ui.preferences.ScopedPreferenceStore.getDefaultP references(ScopedPreferenceStore.java:226)
org.eclipse.ui.preferences.ScopedPreferenceStore.getPreferen ceNodes(ScopedPreferenceStore.java:257)
org.eclipse.ui.preferences.ScopedPreferenceStore.internalGet (ScopedPreferenceStore.java:439)
org.eclipse.ui.preferences.ScopedPreferenceStore.getBoolean( ScopedPreferenceStore.java:352)
org.eclipse.ui.preferences.ScopedPreferenceStore.setValue(Sc opedPreferenceStore.java:731)
org.eclipse.cdt.internal.ui.preferences.CPluginPreferencePag e.init(CPluginPreferencePage.java:79)
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceNode.crea tePage(WorkbenchPreferenceNode.java:79)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1080)
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:307)
org.eclipse.jface.preference.PreferenceDialog$9.selectionCha nged(PreferenceDialog.java:594)
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:636)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:616)
at org.eclipse.core.runtime.Platform.run(Platform.java:747)
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:634)
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:905)
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:925)
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:231)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:226)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 392)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:118)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:2771)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2451)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:718 )
at org.eclipse.jface.window.Window.open(Window.java:696)
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:64)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:988 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:946)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:896)
org.eclipse.jface.action.ActionContributionItem$7.handleEven t(ActionContributionItem.java:810)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:800)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2794)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2448)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1529)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1500)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:276)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:144)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:102)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:335)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:273)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:129)
at org.eclipse.core.launcher.Main.basicRun(Main.java:185)
at org.eclipse.core.launcher.Main.run(Main.java:704)
at org.eclipse.core.launcher.Main.main(Main.java:688)
!ENTRY org.eclipse.core.runtime 4 2 2005-11-07 10:17:17.674
!STACK 0
java.lang.NoSuchMethodError:
org.eclipse.ui.IWorkbench.getHelpSystem()Lorg/eclipse/ui/hel p/IWorkbenchHelpSystem;
org.eclipse.cdt.internal.ui.preferences.AppearancePreference Page.createControl(AppearancePreferencePage.java:95)
org.eclipse.jface.preference.PreferenceDialog$13.run(Prefere nceDialog.java:1104)
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1098)
Re: CDT installation problem (Windows XP , Eclipse 3.1, CDT 3.0) [message #157423 is a reply to message #157414] |
Mon, 07 November 2005 14:44 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Norbert Plött![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=norbert.ploett%40siemens.com) Messages: 233 Registered: July 2009 |
Maybe you should try to open the C/C++ perspective first, before going to
Preferences. To make sure that the central CDT plug-ins are initialized
properly.
Can you open the perspective?
Norbert
"Irina" <Irina.Transky@expand.com> schrieb im Newsbeitrag
news:dkn9s8$dl4$1@news.eclipse.org...
> See log file"
> I use
> CDT: 3.0
> Irina
> !SESSION 2005-11-07
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> at
> at
> at
> at
FUDForum. Page generated in 0.02539 seconds
