Home » Language IDEs » ServerTools (WTP) » Fix to bug 123856 in WST 1.0 (Eclipse 3.1.1)?
Fix to bug 123856 in WST 1.0 (Eclipse 3.1.1)? [message #157410] Fri, 20 January 2006 01:18 Go to next message
Walter Lindsay is currently offline Walter LindsayFriend
Bug 123856 causes a null pointer exception when programatically bringing
up an XSD editor. It is fixed in the Eclipse 3.2 code base, but not 3.1.1.
It is threateninig to delay my company's adoption of WST 1.0.
This bug can easily be reproduced from the GUI by:
1. start the workbench with no .xsd files open
2. open a .xsd file using the xsd editor
3. open the same file using the xml editor
Do you know if this bug will be fixed in the 3.1.1 code base?
Walter Lindsay
More: Fix to bug 123856 in WST 1.0 (Eclipse 3.1.1)? [message #157418 is a reply to message #157410] Fri, 20 January 2006 04:48 Go to previous message
Also, this bug can cause the Outline pane to become totally unusble, if
the workbench is shut down when an XSD editor was up. On the next restart
of the workbench, if the error occurs, the workbench environment is really
messed up.
Walter Lindsay
Previous Topic:Servers UI plugin: Why are Server Actions hard-coded?
Next Topic:WTP 1.0 + Cactus + JBoss 4.0.3 Tutorial
Current Time: Wed Jan 15 10:16:09 GMT 2025
Powered by FUDForum. Page generated in 0.03695 seconds
