Re: Sysdeo Eclipse Preferences Now Broken? [message #157432 is a reply to message #157390] |
Thu, 06 May 2004 08:30 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: thomas_maeder.ch.ibm.com
I figure the change is not binary compatible. The sysdeo plugin is using
internal classes; you'll have to wait for an updated version of the
plugin, sorry.
Thomas
R.J. Lorimer wrote:
> Has anyone else noticed that in the recent Eclipse builds the preferences
> page for the Sysdeo tomcat plugin no longer works?
> I investigated; here is the log statement:
> java.lang.NoSuchMethodError:
> org.eclipse.jdt.internal.ui.wizards.dialogfields.ListDialogF ield.setElements
> (Ljava/util/List;)V
> at
> com.sysdeo.eclipse.tomcat.editors.ProjectListEditor.updatePr ojectsList(Proje
> ctListEditor.java:65)
> at
> com.sysdeo.eclipse.tomcat.editors.ProjectListEditor.<init>(ProjectListEditor
> .java:39)
> at
> com.sysdeo.eclipse.tomcat.TomcatPreferencePage.createContent s(TomcatPreferen
> cePage.java:123)
> at
> org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.jav
> a:217)
> ..... // etc.
> The strange thing is that the latest revisions of ListDialogField in Eclipse
> CVS still has the setElements(java.util.Collection) method which should
> support the above perfectly fine. I thought it may be because Eclipse is
> starting on JRE 1.5 on my local environment, so I started with JRE 1.4 using
> the -vm tag - no luck though.
> Does anyone have any bright ideas? As a workaround I installed Eclipse 2.1
> in another directory and copied the Tomcat pref_store info over to the
> .plugins directory under my .metadata directory. The 2.1 -> 3.0 conversion
> code picked up the changes from there.
> R.J.
FUDForum. Page generated in 0.03262 seconds
