Pop Up Menus in eclipse plug ins [message #157388] |
Mon, 19 June 2006 13:03 |
Originally posted by: jebinjohanson.gmail.com
While enabling popup action for my plugin, in the Plugin.xml file i
added the following entry.
<extension
point="org.eclipse.ui.popupMenus">
<objectContribution
objectClass="org.eclipse.core.resources.IFile"
nameFilter=*.*
Here The plugin doesnt work. if i change the filter to either "*.java or
*.xml" then it works. Can anyone please explain.
When I added the following entry to plugin.xml
<extension point="org.eclipse.ui.popupMenus">
<viewerContribution
id="org.eclipse.ui.articles.action.contribution.popup.editor "
targetID="#TextEditorContext">
The popup action is executed only for a text editor. What i have to do in
order to make it work for Java editor also. Also please explain the meaning
of "#TextEditorContext"
Any help will be highly appreciated.
Thanks in advance,
Jebin
Attachment: tag_a.jpg
(Size: 0.89KB, Downloaded 85 times) -
Attachment: tag_b.jpg
(Size: 0.90KB, Downloaded 100 times)
Re: Pop Up Menus in eclipse plug ins [message #157420 is a reply to message #157388] |
Mon, 19 June 2006 14:20 |
Originally posted by: newcome.gmail.com
I got a similar problem: trying to activate the action only for IFolder
object with name = XXX_ABC_YYY using nameFilter = "XXX_*_YYY" doesn't work
properly.
Could someone explain this too?
Re: Pop Up Menus in eclipse plug ins [message #158185 is a reply to message #157420] |
Fri, 23 June 2006 04:50 |
One solution is not to use the namefilter at all. i know its not the correct
way...but u can try it..
Jebin
"newcome" <newcome@gmail.com> wrote in message
news:2f29154c39a241b7d078adc7b8b66a10$1@www.eclipse.org...
>properly.
FUDForum. Page generated in 0.08415 seconds
