Re: Occurrences in File context menu item in 3.0 [message #171824 is a reply to message #157383] |
Wed, 04 August 2004 16:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: daniel.megert.gmx.net
Daniel Abraham wrote:
>Hi,
> I'm trying out 3.0 (M8? (Build id: 200403261517)) and I really like a
>lot of the changes, but I'm missing the search > Occurrences in File...
>context menu item from 2.1. I know that it's there in the menu bar, I
>know that I could type Ctrl-Shift-U, but I'd like to put it back into my
>context menu.
In R3.0 you can enable it via Window > Preferences > Java - Use reduced
search menu
Dani
> How do I do that? I've googled, I've looked through the help file, I've
>poked around the UI (It looks like it should be in either Customize
>Perspective, or Preferences, but I can't find it).
> Thank you very much.
> Daniel Abraham
FUDForum. Page generated in 0.03588 seconds
