Debugger is fine but steps are not visible [message #157369] |
Wed, 05 May 2004 13:27  |
Originally posted by: marzagao.yahoo.com
I have looked at this newsgroup archives and the bug database but could
not find this problem. I am running Eclipse 2.1.3 with jdk 1.4.2_04.
For some reason, when running the JDT debugger, it stops fine at the
breakpoints (I am able see the current methods and line numbers in the
Debug threads view), but the source editor does not follow the flow of the
running program.
I am able to step over and see the line numbers changing and the variables
getting updated but I can't see the actual code being highlighted in the
editors at all.
I thought it might have been one of the plugins but I have uninstalled and
reinstalled Eclipse with no plugins and I am still having this problem.
Any ideas?
Thanks.
Re: Debugger is fine but steps are not visible [message #159091 is a reply to message #157580] |
Mon, 17 May 2004 11:04  |
Not aware of any problems here. Works OK for me.
Darin
"Thompson Marzagao" <marzagao@yahoo.com> wrote in message
news:c7dv2m$sih$1@eclipse.org...
> Hi all,
> Could it be a problem with Eclipse 2.1.3? I switched back to 2.1.2 and now
> everything works fine... Is anyone using the debugger on 2.1.3 with no
> problems or is it just me? :)
> Thompson
> Thompson Marzagao wrote:
> > Hi,
the
> > running program.
variables
> > editors at all.
and
> > Any ideas?
> > Thanks.
FUDForum. Page generated in 0.03267 seconds
