Unable to debug under Linux [message #157350] |
Sun, 06 November 2005 12:35 |
Henrietta Slack Messages: 63 Registered: July 2009 |
Member |
I have an eclipse java RCP app which calls out to a C++ shared library
created by CDT. I debug a similar setup using Windows and MSVC by adding a
java break point to the loadLibrary() call in an eclipse workspace, and
then attaching the MSVC debugger to the eclipse process. I then have an
MSVC workspace and a java Eclipse workspace that I can debug together,
stepping from one into the other.
To try and accomplish something similar using Linux and CDT I've used the
"C/C++ Attach to Local Application" launch configuration, selected the
appropriate project and the "libXXX.so" c++ application, hit debug and
selected the java eclipse workspace process to attach to, but after a few
seconds CDT hangs with the following:
Previous frame inner to this frame (corrupt stack?)
I'd love for there to be a solution to this problem. I'm using Suse 9.3,
gcc 3.3.3, gdb 6.3, the latest Eclipse 3.2M3 and the latest CDT.
Thanks for any consideration,
Henrietta
FUDForum. Page generated in 0.02980 seconds
