Home » Language IDEs » C / C++ IDE (CDT) » New to CDT - Having problems with C++ project build
New to CDT - Having problems with C++ project build [message #157334] Sun, 06 November 2005 02:05 Go to next message
Hi All,
I have installed the latest CDT. I am Using g++ compiler of Cygwin on
WinXP. I have set the path of g++ compiler in the system environmental
variables.
Even after doing this I am not able to build and run a simple "Managed Make
C++ project". The project has just one source file with main
method with some cout. Whenever I build the project eclipse throws following
error:
Build error
(Exec error:Launching failed)
P.S. I am able to compile and run the same source file through command line.
Any help in this regards is appreciated.
Shrinivas Joshi.
Re: New to CDT - Having problems with C++ project build [message #157342 is a reply to message #157334] Sun, 06 November 2005 02:19 Go to previous message
Please ignore this. I have got the solution.
For those who had the same problem : In my case I was missing the "make"
utility in cygwin which I updated (can be found in Devel category) through
cygwin setup.
-Shrinivas Joshi
"Shrinivas Joshi" <sjoshi@cc.gatech.edu> wrote in message
news:dkk9vd$cmn$1@news.eclipse.org...
> Hi All,
> variables.
> Make C++ project". The project has just one source file with main
> following error:
> Build error
> line.
> Thanks
> Shrinivas Joshi.
Previous Topic:Compile order in a project
Next Topic:Unable to debug under Linux
Current Time: Wed Mar 12 00:46:57 EDT 2025
Powered by FUDForum. Page generated in 0.05479 seconds
