mac os X, gmf editor [message #157313] |
Fri, 26 October 2007 16:58 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: anaaceb.gmail.com
I'm writing because i'm having an execution error that is driving me crazy.
My working settings are:
Operating System: Mac Os X version 10.4.10 (Intel)
Eclipse version:
Eclipse Platform 3.3.2
GMF europa 2.0.1
Java version 1.5.0_07
The error log is the following:
Error
Fri Oct 26 18:21:53 CEST 2007
execute
org.eclipse.core.commands.ExecutionException: While executing the
operation, an exception occurred
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:519)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:205)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:168)
org.eclipse.gmf.runtime.diagram.ui.parts.DiagramCommandStack .execute(DiagramCommandStack.java:155)
at org.eclipse.gef.tools.AbstractTool.executeCommand(AbstractTo ol.java:388)
org.eclipse.gef.tools.AbstractTool.executeCurrentCommand(Abs tractTool.java:400)
org.eclipse.gmf.runtime.diagram.ui.tools.CreationTool.perfor mCreation(CreationTool.java:133)
at org.eclipse.gef.tools.CreationTool.handleButtonUp(CreationTo ol.java:178)
at org.eclipse.gef.tools.AbstractTool.mouseUp(AbstractTool.java :1053)
at org.eclipse.gef.EditDomain.mouseUp(EditDomain.java:259)
org.eclipse.gef.ui.parts.DomainEventDispatcher.dispatchMouse Released(DomainEventDispatcher.java:374)
org.eclipse.draw2d.LightweightSystem$EventHandler.mouseUp(Li ghtweightSystem.java:538)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:206)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1495)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1519)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1504)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 295)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3350)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2954)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: java.lang.NullPointerException
shapes.diagram.edit.parts.TaskEditPart.addFixedChild(TaskEdi tPart.java:120)
shapes.diagram.edit.parts.TaskEditPart.addChildVisual(TaskEd itPart.java:138)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:197)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.addChild(GraphicalEditPart.java:1292)
org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(A bstractEditPart.java:727)
org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractE ditPart.java:677)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh( AbstractGraphicalEditPart.java:564)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.access$3(GraphicalEditPart.java:1)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt$3.run(GraphicalEditPart.java:836)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.runExclusive(TransactionalEditingDomainImpl.java:262)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.refresh(GraphicalEditPart.java:826)
org.eclipse.gef.editparts.AbstractEditPart.addNotify(Abstrac tEditPart.java:235)
org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotif y(AbstractGraphicalEditPart.java:212)
org.eclipse.gef.editparts.AbstractEditPart.addChild(Abstract EditPart.java:198)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.handleNotificationEvent(GraphicalEditPart.java:1437)
org.eclipse.gmf.runtime.diagram.ui.editparts.GraphicalEditPa rt.notifyChanged(GraphicalEditPart.java:1411)
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.fireNotification(DiagramEventBroker.java:500)
org.eclipse.gmf.runtime.diagram.core.listener.DiagramEventBr oker.resourceSetChanged(DiagramEventBroker.java:395)
org.eclipse.gmf.runtime.diagram.ui.internal.DiagramEventBrok erThreadSafe.resourceSetChanged(DiagramEventBrokerThreadSafe .java:72)
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain.postcommit(DiagramEditingDomainFac tory.java:213)
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl.deactivate(TransactionalEditingDomainImpl.java:475)
org.eclipse.emf.transaction.impl.TransactionImpl.close(Trans actionImpl.java:517)
org.eclipse.emf.transaction.impl.TransactionImpl.commit(Tran sactionImpl.java:358)
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:140)
org.eclipse.gmf.runtime.common.core.command.CompositeCommand .doExecuteWithResult(CompositeCommand.java:406)
org.eclipse.gmf.runtime.common.core.command.AbstractCommand. execute(AbstractCommand.java:134)
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:511)
.... 40 more
Thank you very much for your help,
ANA
FUDForum. Page generated in 0.03272 seconds
