Home » Language IDEs » Java Development Tools (JDT) » get subpackages from IPackageFragment
get subpackages from IPackageFragment [message #157311] Wed, 05 May 2004 07:16 Go to next message
Originally posted by: jochen.kressin.artnolgoy.com
how is it possible to get all subpackages from an IPackageFragment? As far as I
can see the method getChildren() only returns ICompilationUnits and IClassFiles
and I cannot find something like getSubpackes() (despite of the existance of the
method hasSubpackes). I am using Eclipse 3.0, Milestone 8.
Jochen
Re: get subpackages from IPackageFragment [message #171816 is a reply to message #157311] Wed, 04 August 2004 12:13 Go to previous messageGo to next message
Originally posted by: daniel.megert.gmx.net
Jochen Kressin wrote:
You cannot since Java has no concept of sub-packages. You can get the
package fragment root via getParent() and then its children using
getChildren().
Dani
> As far as I can see the method getChildren() only returns
> ICompilationUnits and IClassFiles and I cannot find something like
> getSubpackes() (despite of the existance of the method hasSubpackes).
> Jochen
Re: get subpackages from IPackageFragment [message #189517 is a reply to message #171816] Mon, 13 December 2004 09:59 Go to previous message
* @return List[PackageFragment]
private static List getSubPackages(IPackageFragment p) throws Exception
List result = new ArrayList();
IJavaElement[] packages= ((IPackageFragmentRoot)p.getParent()).getChildren();
String[] names =((PackageFragment)p).names;
int namesLength = names.length;
newPackage: for (int i= 0, length = packages.length; i < length; i++)
String[] otherNames = ((PackageFragment) packages[i]).names;
if (otherNames.length <= namesLength)
continue;
for (int j = 0; j < namesLength; j++)
if (!names[j].equals(otherNames[j]))
continue newPackage;
result.add(packages[i]);
System.out.println("Subpackage found:"+packages[i].getElementName());
return result;
Greetings
Andreas
Note: The most of the code is 'ripped' from PackageFragment.hasSubpackages();
Previous Topic:WTK22 JAD problem
Next Topic:Creating a project programmatically
Current Time: Tue Nov 04 19:44:58 EST 2025
Powered by FUDForum. Page generated in 0.56839 seconds
