Home » Newcomers » Newcomers » Openning source file in editor programmatically
Openning source file in editor programmatically [message #157272] Sat, 17 June 2006 15:08 Go to next message
Originally posted by: sbederml.gmail.com
I have a source file. How can I open it in the java editor *on a
specific line*. The problem is that JavaUI.openInEditor() method does
not give me the option to set the wanted line.
Thank you in advance,
Michael
Re: Openning source file in editor programmatically [message #157341 is a reply to message #157272] Mon, 19 June 2006 06:12 Go to previous message
Michael Beder wrote:
You first open the editor and then check whether the editor you get is
an ITextEditor. If so, you an use its API to compute the offset and
length of your line and then select and reveal it. Look at
GotoLineAction if you don't know how to code it.
Dani
> Michael
Previous Topic:eclipse freezing
Next Topic:PHP IDE Feature Update Error
Current Time: Tue Nov 04 19:44:01 EST 2025
Powered by FUDForum. Page generated in 0.12054 seconds
