two diagram views on one model [message #157190] |
Fri, 26 October 2007 09:58 |
Originally posted by: benholtz.gmx.de
Hello to all,
I have one MetaModel which contains all elements. At the end I will have one
editor which has one model file and two diagram files. In both diagram files
I want to see another view of the model. The model file contains all
elements of the two diagram files.
Now I have two gmftool, gmfmap and gmfgen files in one project. Both gmfgen
files generate the diagram code into the .diagram project. I think, they
have to be generated into different projects, because the plugin.xml is
always overwritten if I start one of the generation processes.
In the diagram files are some elements pointing to the same model element in
the model file.
Is there a workaround about this problem? Or a tutorial? I didn't find
anything belongs to this topic.
Benjamin Holtz
Re: two diagram views on one model [message #157239 is a reply to message #157231] |
Fri, 26 October 2007 13:11 |
I think, all diagrams will have the same tools when they are initialized in
this case. But I want, that each instance has got his own tooling
definition.
I think I will let two model and two diagram files in the editor and will
reference the model files among each other.
Benjamin
"Boris Blajer" <boris.blajer@borland.com> wrote in message
news:ffslo5$ifr$1@build.eclipse.org...
> Ho Benjamin,
> You may also use the generated menu item "Initialize XYZ diagram file" to
> create a diagram based on an existing model file.
> Best regards,
> Boris
FUDForum. Page generated in 0.03544 seconds
