Compiling one file without building the project [message #157092] |
Fri, 14 November 2003 20:27 |
Originally posted by: arajwani.lehman.com
How do I compile just one file without building the whole project. Just
saving the file is not compiling it. When I build the project it takes
very long. Is there a menu item or popup to request one file compilation.
Re: Compiling one file without building the project [message #157323 is a reply to message #157092] |
Sat, 15 November 2003 17:06 |
Eclipse uses an incremental compiler. If you enable auto-build then it
will build the file upon save. If auto-build is disabled then you can
simply use Build All (Ctrl+B) which will build all necessary resources.
There's no command to explicitly build a single file.
Dani
FUDForum. Page generated in 0.03129 seconds
