Home » Modeling » GMF (Graphical Modeling Framework) » Add problem view
Add problem view [message #157090] |
Thu, 25 October 2007 12:12 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: ijerez2001.gmail.com
I need problem view to my gmf editor, that it´s a rcp application.
I have looked up and I have found that I can add in teh
DiagramEditorPerspective, but when a run the editor it doesn´t appear.
Do anyone know the solution?
Thanks.
Re: Add problem view [message #157182 is a reply to message #157098] |
Fri, 26 October 2007 08:32 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I have declared the org.eclipse.ui.ide.plugin.
The problem is that in the class DiagramEditorPerspective that contain
public void createInitialLayout(IPageLayout layout) {
layout.setEditorAreaVisible(true);
layout
.addPerspectiveShortcut(DiagramEditorWorkbenchAdvisor.PERSPE CTIVE_ID);
IFolderLayout right = layout.createFolder(
"right", IPageLayout.RIGHT, 0.6f, layout.getEditorArea()); //$NON-NLS-1$
right.addView(IPageLayout.ID_OUTLINE);
IFolderLayout bottomRight = layout.createFolder(
"bottomRight", IPageLayout.BOTTOM, 0.6f, "right"); //$NON-NLS-1$//$NON-NLS-2$ bottomRight.addView(IPageLayout.ID_PROP_SHEET);
bottomRight.addView(IPageLayout.ID_PROBLEM_VIEW);
never run this code, because I write outputs to watch the execution and here
not work.
I would like to be able to open the Problem_View when i want, but I don´t
know how
to get the IPageLayout. Also I could have the menu like eclipse,
Window->Show view...
Thanks.
"Boris Blajer" <boris.blajer@borland.com> escribió en el mensaje de
noticias:ffq767$9vp$1@build.eclipse.org...
> Hi Iván,
> Problem view is declared in the org.eclipse.ui.ide plugin. You will need
> to import this plugin into your configuration, otherwise the view will not
> be available.
> However, it does not seem too much rcp-like to add ide plugins, so
> probably you might want to reconsider the rcp-ness in the first place.
> Best regards,
> Boris
> Iván Jerez wrote:
>> Hello,
>> Thanks.
Re: Add problem view [message #157223 is a reply to message #157182] |
Fri, 26 October 2007 12:10 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Boris Blajer![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=boris.blajer%40gmail.com) Messages: 217 Registered: July 2009 |
Hi Iván,
This method is called only when you first open the perspective or after
"Reset Perspective" menu item is invoked (which might not be accessible
in RCP). Start with a clean workspace and the problems view should appear.
Note however, that the user will be able to close it manually. I believe
that in this case, a call to IWorkbenchPage.showView(...) will reopen it
in the location specified by the createInitialLayout (or at least where
it was the last time it was visible in the perspective).
Boris
> layout
> here not work.
> don´t know how
> Thanks.
>> Hi Iván,
>> need to import this plugin into your configuration, otherwise the view
>> will not be available.
>> Best regards,
>> Boris
>> Iván Jerez wrote:
>>> Hello,
>>> Thanks.
Re: Add problem view [message #157285 is a reply to message #157223] |
Fri, 26 October 2007 15:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thanks.
noticias:ffslgd$htg$1@build.eclipse.org...
> Hi Iván,
> "Reset Perspective" menu item is invoked (which might not be accessible in
> in the location specified by the createInitialLayout (or at least where it
> Best regards,
> Boris
>> layout
>> here not work.
>> know how
>> Thanks.
>>> Hi Iván,
>>> not be available.
>>> Best regards,
>>> Boris
>>> Iván Jerez wrote:
>>>> Hello,
>>>> Thanks.
Current Time: Thu Jul 18 04:28:37 GMT 2024
Powered by FUDForum. Page generated in 0.03459 seconds
