Home » Archived » BIRT » how can I prepare data set inside of code and insert into report?
how can I prepare data set inside of code and insert into report? [message #157026] Fri, 28 April 2006 05:34 Go to next message
Hi all,
My problem is about reaching rptdesign/rpttemplate files inside of my
code. What I want to do is preparing a template report and updating it
inside of code(I want to add data set which is about computed variables
into the report).
I cant find any way for doing this. I have examined dedemo sample, but it
didnt work.
Now, I can see just one way (a bit silly): I will compute my data set
inside of my code and revert to xml format after than I will open
rptdesign or rpttemplate file lastly I will insert the xml code which I
have produced into rtpreport or rpttemplate (necessary position) files.
Also there is another problem, I dont know whole xml format of birt
reports.
Is there any one who could solve this problem or has some idea.
Thanks a lot,
Onder.
Re: how can I prepare data set inside of code and insert into report? [message #157118 is a reply to message #157026] Fri, 28 April 2006 09:14 Go to previous message
I think could fix my problem with scripted data set. There is an sample
http://download.eclipse.org/birt/downloads/examples/scriptin g/scripteddatasource/scripteddatasource.html
but I need it for chart. Is it posible for someone to send me sample
scripted data set for chart.
Onder.
Previous Topic:Parameter binding on chart as subreport
Next Topic:International characters in PDF
Current Time: Wed Apr 16 04:02:31 EDT 2025
Powered by FUDForum. Page generated in 0.03677 seconds
