Home » Language IDEs » Java Development Tools (JDT) » Disappearing JRE
Disappearing JRE [message #156733] Thu, 29 April 2004 16:44 Go to next message
hi all
I'm a newbie. I'm on Eclipse 2.1.1 (SUSE 9.0 operating system).
I have been playing with eclipse all day, doing various tutorials etc.
Now I am going through the JUnit tutorial and something is busted.
Earlier today Windows - Preferences - Installed JRE's found 4 JRE's.
Now it finds none, and my builds fail because there is no
java.lang.Object. No matter what search path I give it for the JRE,
no JRE. But I can compile and run outside of Eclipse fine.
For example if I give the search query
the result of $JRE_HOME which is /usr/lib/java/jre
it doesn't find it.
If I give the search query
/usr/lib/SunJava2-1.4.2 or /usr/lib/SunJava2-1.4.2/jre
/usr/lib/SunJava2-1.4.2/lib
etc, nothing works.
Do I need to re-install? what gives?
thanks!! rt.
Re: Disappearing JRE [message #156742 is a reply to message #156733] Thu, 29 April 2004 17:33 Go to previous messageGo to next message
Here is more information on my query.
When I delete the Junit project and make it again, the Package Explorer
tree has the message 'Could not resolve class path entry.'
The class path file has the contents
<classpath>
<classpathentry kind="src" path=""/>
<classpathentry kind="con"
path="org.eclipse.jdt.launching.JRE_CONTAINER"/>
<classpathentry kind="output" path=""/>
</classpath>
What is this JRE_CONTAINER? is this malfunctioning or did the config
somehow break? I can't find documentation on this.
thanks, rt.
Robert Talent wrote:
> hi all
> it doesn't find it.
> etc, nothing works.
> thanks!! rt.
Re: Disappearing JRE [message #156793 is a reply to message #156742] Fri, 30 April 2004 11:09 Go to previous messageGo to next message
> <classpath>
> </classpath>
Containers are collections of libs, basically. The JRE_CONTAINER is the
one that contains all the standard JRE libraries, including things like
java.lang.Object.
It was not clear from your previous post if you have tried or been able
to add a new JRE to your Eclipse configuration. (Preferences > Java >
Installed JREs > Add button). You should be able to browse to the JRE
home directory and when you select it Eclipse should fill in the JRE
Libraries box automatically.
Is this what you've tried? If so, what exactly were the results?
HTH,
Eric
>> hi all
>> it doesn't find it.
>> etc, nothing works.
>> thanks!! rt.
For Sale: parachute, used once, never opened, small stain.
Re: Disappearing JRE [message #157238 is a reply to message #156793] Tue, 04 May 2004 16:37 Go to previous message
hi & thanks for your replies, I found this as a bug in my version and
updated and it went away.
rt
>> Explorer tree has the message 'Could not resolve class path entry.'
>> <classpath>
>> </classpath>
> java.lang.Object.
> HTH,
> Eric
>>> hi all
>>> etc. Now I am going through the JUnit tutorial and something is busted.
>>> it doesn't find it.
>>> etc, nothing works.
>>> thanks!! rt.
Previous Topic:Java Breakpoint Properties dialog
Next Topic:No local variables when debugging java.lang.Integer
Current Time: Thu Oct 30 13:16:30 EDT 2025
Powered by FUDForum. Page generated in 0.03422 seconds
