Problem with debugger - "File /mydir/.settings does not exist". [message #156668] |
Sun, 23 October 2005 20:35  |
Originally posted by: pretzel_n_g.hotmail.com
I'm using CDT 3.0.0 and Cygwin/gcc/g++ or WinXP.
When I try to debug my c++ application, the debugger stops at the
appropriate lines where breakpoints have been set (as indicated in the
"Debug" tab - says "Thread[1] (Suspended) |->1 main() at
...\blahblah.cpp:24" etc. etc.) however, it doesn't point to which line
in the source code listing.
In fact when I fire up the debugger I get a panel which says the following:
This panel also comes up whenever I right-click the "Debug" panel and
select "Lookup source".
When I examine the directory structure of the project, a directory
called ".settings" exists but no file.
Would anyone please be able to help me to get the debugger working
properly please?
Thanks very much for your help.
PretzelX.
Re: Problem with debugger - "File /mydir/.settings does not exist". [message #167681 is a reply to message #167673] |
Sat, 08 April 2006 14:54  |
Originally posted by: shea08.eastlink.ca
Shea Martin wrote:
> I am seeing the same problem. I build the debug version with -g3. Then
> hit debug. I believe the program stop at my break point, but the editor
> shows not indication of where it stopped. Also, stepping into a funtion
> does not update the editor. The output on the console tab is this:
> <output>
> No registers.
> No source file named main.cpp.
> Stopped due to shared library event
> Single stepping until exit from function main,
> which has no line number information.
> Single stepping until exit from function __libc_start_main,
> </output>
> I am using eclipse 3.1.2, with latest cdt. gcc4.0.3, and gdb 6.4.
> Thanks.
I figured it out. Just run Debug... and make sure it is pointing out
the Debug binary, not the release. Stupid me...
~S
FUDForum. Page generated in 0.06931 seconds
