PaletteModeDialog in LogicExample [message #156651] |
Wed, 03 November 2004 10:57 |
Originally posted by: dyx.gmx.net
Ihave been playing aroun with the logic example a lot lately and i notic=
ed =
the following:
The PrintModeDialog in the logic example is never used!
The editor supports print via the workbenchs global print action and not=
its own LogicPrintAction,
as that one is never registered. Just FYI...
Re: PaletteModeDialog in LogicExample [message #156659 is a reply to message #156651] |
Wed, 03 November 2004 16:18 |
Check the plugin.xml file for usage of this action. It's too bad a
constructor search doesn't find this hit.
Right-click on a .logic file to see the dialog
"Frank Dyck" <dyx@gmx.net> wrote in message news:opsgvx1wdr0i05et@celeron...
Ihave been playing aroun with the logic example a lot lately and i noticed
the following:
PrintModeDialog in LogicExample [message #156719 is a reply to message #156659] |
Thu, 04 November 2004 09:08 |
I see. If i right click on a *.logic file in the package explorer the =
print action that is run is the logic-print action. But the one in the =
file menu and on the tool bar are not.
Wouldn`t it be consistent to override the eclipse print action there too=
Can this be done by simlpy setting OverrideAction ID in the plugin.xml?
Or would it have to be registered manuall with the menu and toolbar in t=
he =
contributor class?
> "Frank Dyck" <dyx@gmx.net> wrote in message =
> Ihave been playing aroun with the logic example a lot lately and i =
> noticed
> the following:
> The editor supports print via the workbenchs global print action and n=
ot
Re: PrintModeDialog in LogicExample [message #156806 is a reply to message #156719] |
Thu, 04 November 2004 16:04 |
We are extending the context menu. The package explorer controls the
File->Print global action. Talk to platform-UI team if you think new
extension points are needed. I don't think people expect those actions to
map to views.
"Frank Dyck" <dyx@gmx.net> wrote in message news:opsgxnnuk40i05et@celeron...
Wouldn`t it be consistent to override the eclipse print action there too?
Or would it have to be registered manuall with the menu and toolbar in the
contributor class?
> noticed
> the following:
Re: PrintModeDialog in LogicExample [message #156969 is a reply to message #156806] |
Fri, 05 November 2004 12:35 |
I see. At least for editors i would say that _users_ would expect exact=
ly =
that.
I.e. in the logic editor example the context menu`s print item offers th=
e =
printmode dialog which makes sense and is a nice feature for a graphical=
editor. But the more easily accessible file->print and toolbar->print =
action don`t.
So when the editor i active and the user selects print hewould expect al=
l =
the print actions to be the same.
(He probably wouldn`t even know that the print action from the context =
menu differs from the one in the toolbar or filemenu and so use the more=
easily accessible one)
But isn`t this what overrideActionId in the plugin.xml is for?
> extension points are needed. I don't think people expect those action=
s =
> to map to views.
> print action that is run is the logic-print action. But the one in the=
> Wouldn`t it be consistent to override the eclipse print action there t=
oo?
> Can this be done by simlpy setting OverrideAction ID in the plugin.xml=
> Or would it have to be registered manuall with the menu and toolbar in=
> the
> contributor class?
>> noticed
>> the following:
>> The editor supports print via the workbenchs global print action and =
not
Using Opera's revolutionary e-mail client: http://www.opera.com/m2/
FUDForum. Page generated in 0.04614 seconds
