WTP and Tomcat 3.0.28 [message #156431] |
Fri, 13 January 2006 14:08 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: francois.vandewalle.powerconv.alstom.com
On my configuration, I can write servlets and jsps using Tomcat and ant
(tomcat version 3.0.28). When I start Tomcat using its batch file, I am
also able to test the application using my internet browser.
In eclipse I tried to make the tutorial "Creating a Bottom Up Web Service"
using wtp 1.0. Everything seems to happen well but the application is not
loaded on tomcat.
Also when I start tomcat from eclipse, I can access only the first page.
All the other pages (for example "status" or "tomcat administration")
return an http 404 error.
Does somebody know the answer to this problem(s) ?
Thanks in advance,
Francois
Re: WTP and Tomcat 3.0.28 [message #156442 is a reply to message #156431] |
Fri, 13 January 2006 20:26 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Larry Isaacs![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=larryisaacs%40mindspring.com) Messages: 1354 Registered: July 2009 |
Francois,
The default Tomcat configuration is to run with separate catalina.home
and catalina.base settings. The catalina.home setting points to your
installation. The catalina.base (where "conf", "logs", "webapps", etc.
live) setting points to a directory down under the
"<workspace>/.metadata" directory. This allows you to create one or
more Tomcat servers in Eclipse without modifying your Tomcat
installation in any way. A side effect is that the standard webapps
aren't present by default.
If you double-click the Tomcat server in the Servers view, it will open
the server configuration editor view. You can uncheck "Run modules
directly from the workspace..." setting. In that configuration,
catalina.base and catalina.home will both point to your Tomcat
installation and behavior will be more like you seem to be expecting.
Note that in this case, the files found under the Eclipse Servers
project for that Tomcat server become the "master" version of those
files. They will be copied on top of those in your Tomcat installation
whenever you run the server from Eclipse.
Larry
Francois Vandewalle wrote:
> Hello,
> Service" using wtp 1.0. Everything seems to happen well but the
> application is not loaded on tomcat.
> Thanks in advance,
> Francois
Re: WTP and Tomcat 3.0.28 [message #157117 is a reply to message #156442] |
Wed, 18 January 2006 09:03 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Hello Larry,
Thank you very much for this information and tip !
I really like working with the views editors of the wtp package, but up to
now I always had to switch to prompt, compile with ant an have tomcat
running "externally".
Now I have the complete effectivity !
François
FUDForum. Page generated in 0.02795 seconds
