CCE during Annotated Java Import [message #14653] |
Mon, 22 May 2006 15:25 |
Originally posted by: anil.samuel.gmail.com
--------------040905010505020602050702
I get the following ClassCastException when I try to create a model using
File->New->EMF Model->Annotated Java
I have one java source on the src tree which is attached here. This
source is exactly same as in case of Derby where Synonym is added to
Derby model.
Anyone tried creating a EMF model for DTP from Annotated Java source ?
Anthos
!ENTRY org.eclipse.emf.importer.java 2 0 2006-05-23 05:08:05.640
!MESSAGE org.eclipse.emf.ecore.impl.EFactoryImpl
!STACK 0
java.lang.ClassCastException: org.eclipse.emf.ecore.impl.EFactoryImpl
at org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.used( JavaEcoreBuilder.java:485)
at org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.used( JavaEcoreBuilder.java:508)
at org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.analy seProject(JavaEcoreBuilder.java:306)
at org.eclipse.emf.importer.java.builder.JavaEcoreBuilder.compu teEPackages(JavaEcoreBuilder.java:456)
at org.eclipse.emf.importer.java.JavaImporter.doComputeEPackage s(JavaImporter.java:82)
at org.eclipse.emf.importer.ModelImporter.computeEPackages(Mode lImporter.java:482)
at org.eclipse.emf.importer.java.ui.JavaPackagePage.computeEPac kages(JavaPackagePage.java:106)
at org.eclipse.emf.importer.java.ui.JavaPackagePage$2.execute(J avaPackagePage.java:81)
at org.eclipse.ui.actions.WorkspaceModifyOperation$1.run(Worksp aceModifyOperation.java:101)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1737)
at org.eclipse.ui.actions.WorkspaceModifyOperation.run(Workspac eModifyOperation.java:113)
at org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 851)
at org.eclipse.emf.importer.java.ui.JavaPackagePage.computeEPac kages(JavaPackagePage.java:96)
at org.eclipse.emf.importer.java.ui.JavaPackagePage$1.run(JavaP ackagePage.java:59)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3325)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2971)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2968)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:400)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:177)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
name="MaterializedView.java"
Content-Disposition: inline;
filename="MaterializedView.java"
package oracle.dbtools.modelbase;
import org.eclipse.datatools.modelbase.sql.schema.SQLObject;
import org.eclipse.datatools.modelbase.sql.tables.ViewTable;
* @model
public interface MaterializedView extends ViewTable, SQLObject {
* @model
ViewTable getView();
* @model
void setView(ViewTable value);
--------------040905010505020602050702--
FUDForum. Page generated in 0.04370 seconds
