Source drop build problem? Completing Install splash always on (R-2.1.2-200311030802) [message #156288] |
Thu, 13 November 2003 07:57  |
Originally posted by: rmuniz.novell.com
Hi all,
When I build the drop source for R-2.1.2-200311030802, (no custom code, just what is out in the site) the resulting eclipse always shows the "Please wait...Completing the Install" splash screen when it starts. I searched the newsgroups and I could not find anyone with the same problem (meaning building fresh out of the source and with the splash screen problem.)
Is this normal?, I was expecting to see the usual Eclipse splash screen the second time, I know the "Please wait ... Completing the Install" the install always shows the very first time eclipse is started, and there is no workspace directory. The workspace directory gets created just fine, but if I shutdown eclipse and restart it again the same splash screen comes up, all the time. The correct bmp is found in right in the eclipse directory and in the ...eclipse\plugins\org.eclipse.platform.
I have tried it building both ways, downloading the included source as a zip( eclipse-sourceBuild-srcIncluded-2.1.2.zip), and downloading the build scripts (eclipse-sourceBuild-srcFetch-2.1.2.zip) which get the source from the cvs site, with the same result.
Originally I thought I had done something wrong but after a few times I am thinking either the build is like that or I am missing some piece of info. I have followed the steps in the site to the letter several times with the same result. ( http://download2.eclipse.org/downloads/drops/R-2.1.2-2003110 30802/srcIncludedBuildInstructions.html and http://download2.eclipse.org/downloads/drops/R-2.1.2-2003110 30802/srcFetchBuildInstructions.html)
I have tried building from eclipse and out of eclipse using the console command build -os win32 -ws win32 -install c:\dev\eclipse
I am using the SUN's j2sdk 1.4.1, ant 1.4, and CVS 1.11.1.3 on windows 2k.
Thank you in advance for your help.
- Rene Muniz
Re: Source drop build problem? Completing Install splash always on (R-2.1.2-200311030802) [message #157447 is a reply to message #156288] |
Sun, 16 November 2003 08:26  |
Ok, I think I figure it out, the reason the "Please wait...Completing the Install" splash was always coming up was that there were two files missing from the eclipse root directory, these were the .eclipseproduct file and the install.ini file. Once I copied them to the root dir the normal splash started to show. I do not know why they are not copied there by the build, but I sure learned a lot figuring this out, by the way sincere thanks to Alvin and others who offered their help and knowledge, thanks guys :-)
- rm -
>>> Rene Muniz<rmuniz@novell.com> 11/13/2003 5:57:35 AM >>>
Hi all,
- Rene Muniz
FUDForum. Page generated in 0.04062 seconds
