Home » Newcomers » Newcomers » How Do I Create A Non UI Plugin ?
How Do I Create A Non UI Plugin ? [message #156260] Sun, 11 June 2006 13:45 Go to next message
I have written a package having no user interface that I currently
simply include on the classpath of my mission plugin, but I'd like to
make it a plugin too, so that I can use the trace facility on it
conveniently (which requires that it become a plugin).
I tried creating a plugin project, specifying in the new project
wizard that that the plugin would make no contribution to the UI,
but the resulting project did not contain a plugin manifest which
seems a bit radical. I looked into org.eclipse.core.commands_3.1.0.jar,
and it does have a plugin.xml, albeit abbreviated:
<?xml version="1.0" encoding="UTF-8" ?>
<?eclipse version="3.0"?>
<plugin />
I've looked in the help and on the net for an article or help
on the issue, but have not found anything specific about creating
non-UI (core?) plugins. Should I post this as a bug, or is there
something I am doing wrong?
Bill.
Re: How Do I Create A Non UI Plugin ? [message #156412 is a reply to message #156260] Sun, 11 June 2006 23:38 Go to previous messageGo to next message
> <plugin />
> Bill.
I should have mentioned that I'm running
Version: 3.1.0
Build id: I20050627-1435.
Bill
Re: How Do I Create A Non UI Plugin ? [message #156869 is a reply to message #156412] Wed, 14 June 2006 18:14 Go to previous messageGo to next message
>> <plugin />
>> Bill.
> Version: 3.1.0
> Bill
I've seen a working non-UI plugin and it has no plugin.xml. But it does
contain a MANIFEST.MF stating which Java-packages are exported.
hope this helps
Re: How Do I Create A Non UI Plugin ? [message #156885 is a reply to message #156869] Wed, 14 June 2006 19:35 Go to previous message
>>> <plugin />
>>> Bill.
>> Version: 3.1.0
>> Bill
> hope this helps
Thanks Joe, you are correct. I got the same info from the platform
group. Its good to know that is not a problem.
Previous Topic:removed a update site hookup
Next Topic:callisto
Current Time: Fri Nov 07 02:21:43 EST 2025
Powered by FUDForum. Page generated in 0.09129 seconds
