Extract data from diagram [message #156250] |
Thu, 18 October 2007 12:10 |
Originally posted by: giuseppeloprete.gmail.com
Hi all, I create an editor with GMF. When I create a file I can add nodes
and connections, they have some attributes to set and i set it. How can I
extract this attributes from the file generated with this editor? (when I
create a diagram I have 2 file: ".example" and ".example_diagram", I need
to extract data from ".example")
Thanks all,
Cheers
Re: Extract data from diagram [message #156370 is a reply to message #156302] |
Fri, 19 October 2007 06:53 |
Originally posted by: dennis.huebner.gmail.com
In "Workflow Definition"- Part,
but not just attributes hole model (locate in ${modelFile}) will be
readed, so you can easy access all instances (also attributes) in your
template files.
Dennis.
giuseppe schrieb:
> In which part of tutorial they extract attributes from diagram?
FUDForum. Page generated in 0.03914 seconds
