Name not being updated [message #156242] |
Thu, 18 October 2007 12:02 |
Originally posted by: trommas.yahoo.com
My model element (ClassNode) wraps an object from an OWL file. When I
run several editors, the object can be wrapped by multiple ClassNodes
(in different editors). getName() returns the wrapped object's name -
But this will differ from it's own name variabel if some other ClassNode
has edited it.
What I was thinking was to use an if. If the wrapped object's name has
changed, the model element should display the new name. I have tried to
fire a notification without success.
The properties tab gets the correct name, and normally I would use a Set
request.. But I can't since the change is detected in the getName()
method of ClassNode.
Any ideas?
Tomas
Re: Name not being updated [message #156286 is a reply to message #156270] |
Thu, 18 October 2007 13:37 |
Thanks. I've checked out my ClassNodeNameEditPart. There don't seem to
be happening anything (I checked with the getLabelText() method).
However, if I duplicate a model element, the new element (the dup) picks
up the correct name.
Tomas
SKuhn wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> first check if the 'label'editPart receives the notification.
> - -stefan
>> has edited it.
>> Any ideas?
>> Regards,
>> Tomas
> -----BEGIN PGP SIGNATURE-----
> Version: GnuPG v2.0.7 (GNU/Linux)
> Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org
> iD8DBQFHF1ghIYVWjMSpDwwRAsgsAKCdg02ZT+fI+zMxe66luvU+yLa5FQCg 5DYK
> XlvdQ/IqJU2fPRZ0Cs4sHcg=
> =qFXZ
> -----END PGP SIGNATURE-----
Re: Name not being updated [message #156294 is a reply to message #156286] |
Thu, 18 October 2007 14:20 |
Stefan Kuhn Messages: 355 Registered: July 2009 |
Hash: SHA1
your ClassNodeNameEditPart should listen to changes in the semantic
model. Normally, they're doing this through EditPolicies installed on
the editPart. The default generated EditParts should to this
automatically. I would take a look at the adapters which are listening
to your property/EObject, your ClassNodeNameEditPart or one of his
EditPolicies should be there.
- -stefan
> Tomas
> -stefan
>>>> has edited it.
>>>> Any ideas?
>>>> Regards,
>>>> Tomas
iD8DBQFHF2uZIYVWjMSpDwwRAmn4AKDZl97Zkb0THoI00C3x1Hvr/x6QQwCe OU9U
Jh9nNUZBcfj8Lv0BK4QQjbc=
=rUTJ
FUDForum. Page generated in 0.03654 seconds
