Plugin - compiles but failes on library call [message #156226] |
Sat, 10 June 2006 12:32 |
Originally posted by: sparky.flo.com
hy, i am currently writing a plugin for eclipse and here is my problem:
i have included two libraries, one for xslt-transformation and one for
writing xml-documents, they are stored in a folder called "libs"
if i start my application while developing (via run / eclipse application)
everything works fine, but if i export it as an .jar file and copy it to the
eclipse-pluginfolder, restart eclipse and start my application, it works
until i do something, that uses functions / classes of one of the .jar libs
=> then it failsit just fails (suddenly the app-window is gone) whenever i
do something, that uses one of the two .jar libs.
of course i have configured my plugin properly using the "build" page:
- i have encluded the "libs" folder in the binary build
- i have created extra classpath entries for both .jar files
if i extract the class files from the .jar files and zip them together with
the class files of my plugin, it works!
so why does it not work, if i just include the .jar files ? can somebody
help me with that?
thanks in advance!
FUDForum. Page generated in 0.07966 seconds
