Re: Bundles are really there but!!!! [message #156238 is a reply to message #156201] |
Sat, 10 June 2006 17:44 |
Antonel Ernest Pazargic Messages: 69 Registered: July 2009 |
Member |
When I get this error I verify the run configuration for application =
or/and product.
1. In main tab I
1.1 check if program to run is correct (in an unexplained way many time=
s =
I found there a helpApplication ... weird :( );
1.2 Check "Clear workspace data before lunching";
2. In plug-ins tabs:
2.1 Select "Choose plug-ins and fragments to lunch from the list";
2.2 Select "Deselect all";
2.3 Select your plugin(s) from workspace;
2.4 Select "Add Required Plug-ins";
2.5 Select "Validate Plug-in Set" to see if all is oki;
For me these actions solve this ugly error "No application id has been =
found".
If application throws this error again check "the target" =
(Window>Preferences>Plugin Development>Target Platform);
I hope these help.
Respect, JTONIC.
On Sat, 10 Jun 2006 07:02:54 +0300, Radix <roche161@charter.net> wrote:
> Greetings,
> The Bundles are really there but I get these messages.................=
> !MESSAGE Bundle update@plugins/org.eclipse.ui.win32_3.1.0.jar [52] was=
> not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2006-06-09 15:51:09.805
> !MESSAGE Missing host org.eclipse.ui.ide_[3.0.0,4.0.0).
> !SESSION 2006-06-09 15:51:05.930 =
> eclipse.buildId=3Dunknown
> java.version=3D1.5.0_04
> java.vendor=3DSun Microsystems Inc.
> BootLoader constants: OS=3Dwin32, ARCH=3Dx86, WS=3Dwin32, NL=3Den_US
> Command-line arguments: -os win32 -ws win32 -arch x86 -data .
> !ENTRY org.eclipse.core.runtime 2006-06-09 15:51:09.602
> !MESSAGE Product org.jlibrary.client.product could not be found.
> !ENTRY org.eclipse.osgi 2006-06-09 15:51:09.680
> !MESSAGE Application error
> !STACK 1
> java.lang.RuntimeException: No application id has been found.
> at =
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActi=
vator.java:204)
> at =
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.jav=
a:376)
> at =
a:163)
> at =
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.j=
ava:39)
> at =
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccess=
orImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:585)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
> at org.eclipse.core.launcher.Main.run(Main.java:942)
> at org.eclipse.core.launcher.Main.main(Main.java:926)
> !ENTRY org.eclipse.osgi 2006-06-09 15:51:09.805
> not resolved.
> !ENTRY org.eclipse.osgi 2006-06-09 15:51:09.852
> !MESSAGE Bundle update@plugins/org.jlibrary.client.nl1_3.0.0/ [72] was=
> not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2006-06-09 15:51:09.852
> !MESSAGE Missing host org.jlibrary.client_[3.0.0,4.0.0).
> !ENTRY org.eclipse.osgi 2006-06-09 15:51:09.914
> !MESSAGE Bundle update@plugins/org.jlibrary.client_3.0.0/ [73] was not=
> resolved.
> !SUBENTRY 1 org.eclipse.osgi 2006-06-09 15:51:09.930
> !MESSAGE Missing required bundle org.eclipse.osgi.util_0.0.0.
> !ENTRY org.eclipse.osgi 2006-06-09 15:51:09.961
> !MESSAGE Bundle =
> update@plugins/org.visualcontent.authentication.jlibrarylistener_0.0.3=
> [77] was not resolved.
> !SUBENTRY 1 org.eclipse.osgi 2006-06-09 15:51:09.961
> !MESSAGE Missing required bundle org.jlibrary.client_0.0.0.
> How do you go about resolving this ????
> Any directions appreciated........
> Cheers
> RMR
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
FUDForum. Page generated in 0.10746 seconds
