Re: Adding marquee selection to SelectionTool [message #156491 is a reply to message #156475] |
Mon, 01 November 2004 19:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
It sounds like you are attempting to drag your contents editpart. You
should return NULL or the marquee drag tracker in your getDragTracker(req)
method. See LogicDiagramEditPart for an example.
"Cameron Bateman" <cbateman@rim.com> wrote in message
news:cm61bk$h3i$1@eclipse.org...
> Hi Pratik,
> Thanks for your response. I am adding the PanningSelectionToolEntry as
> you say, but when I try to click and drag on my canvass with the tool, it
> just sets the "invalid mode" mouse pointer (circle with a cross through
> it) as though a request is being rejected.
> Is it possible that I'm inadvertently overriding the default behaviour?
> The marquee tool _does_ work. The code that creates the pallette entries
> looks like this:
> _paletteRoot = new PaletteRoot();
> // group the default controls
> PaletteGroup controls = new PaletteGroup("Controls");
> // selection tool
> PanningSelectionToolEntry toolEntry = new PanningSelectionToolEntry();
> controls.add(toolEntry);
> _paletteRoot.setDefaultEntry(toolEntry);
> // Marquee (group selection) tool
> controls.add(new MarqueeToolEntry());
> _paletteRoot.add(controls);
> --Cam
> Pratik Shah wrote:
> > The default behaviour already does that. All you need to do is add a
> > PanningSelectionToolEntry to your palette.
> > news:cm5ric$6iu$1@eclipse.org...
> > > Does anyone have an idea this?
> > > Thanks,
> > > Cameron
> > > Cameron Bateman wrote:
> > > > Greetings,
> > > > I have noticed that the Selection tool used in the logic example
also
> > > > carries "Marquee" drag functionality when you click and drag on a
> > canvas.
> > > > However, the default behaviour doesn't seem to do this. How would I
add
> > > > this? I can't seem to find the example code that does it.
> > > > I tried setting a MarqueeDragTracker on the SelectionTool, but doing
in
> > > > the createTool call on an entry throws an exception in
> > > > AbstractTool.activate, so I assume this approach is either incorrect
or
> > > > being done too early.
> > > > --Cam
Re: Adding marquee selection to SelectionTool [message #156503 is a reply to message #156491] |
Mon, 01 November 2004 20:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Cameron Bateman![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=cbateman%40rim.com) Messages: 39 Registered: July 2009 |
Member |
Yep, that did it! Thanks. One follow-up: with the selection tool working
in this way, is there any further functionality in the Marquee tool that
makes it worth keeping on my palette?
--Cam
> > Hi Pratik,
> > looks like this:
> > // selection tool
> > --Cam
> > > > Thanks,
> > > > Cameron
> > > > > Greetings,
> also
> > > canvas.
> add
> in
> or
> > > > > --Cam
FUDForum. Page generated in 0.04161 seconds
