Home » Modeling » GMF (Graphical Modeling Framework) » creating a link the target is always null
creating a link the target is always null [message #156136] Wed, 17 October 2007 13:53 Go to next message
Originally posted by: bmoros.um.es
Hi all,
I am completely frustrated!! I have been trying to create a element and a
link programmatically for some weeks with no success. Although I have
followed the example provided in the GMF tutorial (MindMap example) I only
have been able to create the element but not the link.
I am trying to create them in the handleNotificationEvent-method of the
ElementEditPart since the new element has to be created when the current
element changes. Once the new element is created, it has to be linked to the
current one. The current element is the source (sourceViewAdapter) of the
DeferredCreateConnectionViewAndElementCommand, and the new element is the
target (targetViewAdapter) of the Command. Consequently, the command is
created as follows:
//Target of the link: the new created element
IAdaptable targetViewAdapter =
(IAdaptable)((List)elementRequest.getNewObject()).get(0);
// Source of the link: the current element
IAdaptable sourceViewAdapter = new EObjectAdapter((EObject)this.getModel());
ICommand createLinkCmd = new DeferredCreateConnectionViewAndElementCommand(
createLinkRequest,
sourceViewAdapter,
targetViewAdapter,
this.getViewer());
Debugging the code, I have realized that the execution of the
doExecuteWithResult-method, in the DeferredCreateConnectionViewAndElement
class, looks for the EditPart corresponding to the targetViewAdapter. The
targetViewAdapter is not a key of the EditPartRegistry (I guess the reason
is that the element has been already created and the registry has not been
updated yet) so the targetEditPart is always null. Then, the command is not
executed and the link is not created.
I do not understand why the creation works when the element and the link are
created in an Action but it does not work when they are created in a method
of an EditPart.
Can anybody explain it to me? can anybody give me a hint?
Bego
Re: creating a link the target is always null [message #156145 is a reply to message #156136] Wed, 17 October 2007 14:50 Go to previous messageGo to next message
I had the same problem. I solved it by executing the command that
creates target first. Have you tired this?
Tomas
Re: creating a link the target is always null [message #156160 is a reply to message #156145] Wed, 17 October 2007 17:05 Go to previous messageGo to next message
Thank you again Tomas. I tried it. I followed the code that you sent me but
it didn
Re: creating a link the target is always null [message #157391 is a reply to message #156136] Fri, 26 October 2007 16:05 Go to previous messageGo to next message
Begoña,
The handleNotificationEvent() method of an editpart is not the correct
place to create a new element for the relationship. This element should
be created by the edithelpers as these are responsible for creating the
semantic elements.
Is your diagram canonical? If so, then if the element is created the
connection should be created automatically.
Cherie
Begoña Moros wrote:
> Hi all,
> created as follows:
> createLinkRequest,
> sourceViewAdapter,
> targetViewAdapter,
> this.getViewer());
> of an EditPart.
> Best regards,
> Begoña
Re: creating a link the target is always null [message #157452 is a reply to message #157391] Sun, 28 October 2007 04:04 Go to previous message
Cherie, thank you very much for your answers!!!
> semantic elements.
I will study about edithelpers, any good reference?
I am using the editors generated automatically by GMF from the ecore and I
am afraid I am still not in control of all the GMF/EMF features.
I really do not know. Is the diagram of the generated GMF editors canonical?
The problem is that the connection is not always created when a node is
created. A node can be created by means of the palette tool or
programmatically under some circunstances. Only when the node is created
programmatically the connection has to be created too.
Bego
Previous Topic:Avoiding Duplicate EditParts?
Next Topic:translation of the diagram as scroll horizontally
Current Time: Thu Oct 23 14:50:01 EDT 2025
Powered by FUDForum. Page generated in 0.04280 seconds
