Re: Image Hyperlink Error... [message #155842 is a reply to message #155772] |
Mon, 24 April 2006 20:45 |
Trent,
Put the hyperlink in quotes.
Jason
"Trent Ohannessian" <tohann@gmail.com> wrote in message
news:e2irbj$lke$2@utils.eclipse.org...
> Sorry, I forgot to mention I am running BIRT 2.0.0 on Eclipse 3.1.0.
> Trent Ohannessian wrote:
>> Hello,
>> I am trying to add a hyperlink to an image on a report I'm running. It
>> seems simple enough but I'm running into an error. When I specify the
>> URI the image should go to, the report gets the following error when it's
>> run:
>> Error0 : Error.ScriptEvaluationError ( 1 time(s) )
>> detail : org.eclipse.birt.report.engine.api.EngineException: There are
>> errors evaluating script "www.sitename.com". at
>> org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:508)
>> at
>> org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:471)
>> at
>> org.eclipse.birt.report.engine.data.dte.DteDataEngine.evalua te(DteDataEngine.java:321)
>> If I go into the Layout mode and choose the image's Hyperlink, the URL
>> looks fine except that it shows up when I press the Expression Builder
>> button. This is obviously not a valid expression so I was wondering why
>> the URL is getting put in there.
>> Thanks!
>> Trent
FUDForum. Page generated in 0.03435 seconds
