Home » Language IDEs » Java Development Tools (JDT) » What will AST ultimately support?
What will AST ultimately support? [message #155456] Wed, 21 April 2004 17:37 Go to next message
Will(does) AST handle code formatting, taking into account the user's
coding style preferences?
Will current refactorings (like generate getters and setters) be ported
to use AST instead of plain string concatenation?
Guillaume
Re: What will AST ultimately support? [message #155474 is a reply to message #155456] Wed, 21 April 2004 19:33 Go to previous messageGo to next message
Originally posted by: akiezun.to.reply.remove.whats.unneeded.mit.edu
Guillaume Pothier wrote:
> Guillaume
fyi,
'generate getters and setters' is not implemented as a refactoring
https://bugs.eclipse.org/bugs/show_bug.cgi?id=37820
yes, use ASTRewrite and your prefs should be respected. if not, enter a
bug report.
a.
Re: What will AST ultimately support? [message #155568 is a reply to message #155474] Thu, 22 April 2004 08:07 Go to previous messageGo to next message
Yeah, I should have said code manipulation instead of refactorings.
Thanks for the pointer to ASTRewrite.
So, is the new AST designed to handle all code manipulation? Or will
there sill be a need for plain-text code assembly?
g
>> ported to use AST instead of plain string concatenation?
>> Guillaume
> fyi,
> bug report.
> a.
Re: What will AST ultimately support? [message #155591 is a reply to message #155568] Thu, 22 April 2004 13:18 Go to previous messageGo to next message
I have been doing some custom refactorings myself in my plug-in and i
work exclusively with ASTs. It is so much easier IMO.
However there is an issue. You can't "Edit-->Undo" a whole refactoring
with AST. You only Undo AST modifications. So if you do 10 AST
modifications for a refactoring, you will have to do "Edit-->Undo" 10
times to completely undo the refactoring/structure modification.
Charles
> g
>>> Hi,
>>> Guillaume
>> fyi,
>> a bug report.
>> a.
Re: What will AST ultimately support? [message #155640 is a reply to message #155591] Thu, 22 April 2004 16:47 Go to previous messageGo to next message
Ok, that's good news. Can you point me to an example of AST code
manipulation? I am currently struggling to find an IDocument instance to
apply the changes generated by ASTRewriter... But maybe there is another
way?
Guillaume
> Charles
>> g
>>>> Hi,
>>>> user's coding style preferences?
>>>> Guillaume
>>> fyi,
>>> a bug report.
>>> a.
Re: What will AST ultimately support? [message #155720 is a reply to message #155640] Fri, 23 April 2004 06:08 Go to previous message
Hi Gui
I have been told to do that
import org.eclipse.jface.text.Document;
IDocument idoc= new Document(icu.getSource());
where icu is an ICompilationUnit.
Otherwise you can get an IDocument from the active EditorPart
AbstractTextEditor ate = (AbstractTextEditor) _part;
FileEditorInput fe = (FileEditorInput) _part.getEditorInput();
IDocument idoc = ate.getDocumentProvider().getDocument(fe);
But that only works for me when inside the Java Editor (ie _part is not
null)
> way?
> Thanks
> Guillaume
>> Charles
>>> g
>>>>> Hi,
>>>>> Guillaume
>>>> fyi,
>>>> enter a bug report.
>>>> a.
Re: What will AST ultimately support? [message #155728 is a reply to message #155720] Fri, 23 April 2004 05:49 Go to previous message
Hehe thanks!
> Hi Gui
> null)
>> to apply the changes generated by ASTRewriter... But maybe there is
>> another way?
>> Thanks
>> Guillaume
>>> refactoring with AST. You only Undo AST modifications. So if you do
>>> 10 AST modifications for a refactoring, you will have to do
>>> "Edit-->Undo" 10 times to completely undo the refactoring/structure
>>> modification.
>>> Charles
>>>> g
>>>>>> Hi,
>>>>>> Guillaume
>>>>> fyi,
>>>>> enter a bug report.
>>>>> a.
Previous Topic:Run Ant... Error: Config file is not of expected XML Type
Next Topic:CDT install error in eclipse
Current Time: Tue Sep 16 05:35:53 EDT 2025
Powered by FUDForum. Page generated in 0.09133 seconds
